var=PINx dynamic
syndetic1
PostPosted: Wed Mar 03, 2021 12:10 am    Post subject: var=PINx dynamic Reply with quote
To read a port one writes a statement like
MYByte = PINA
or
MYByte = PinC.3
Is it possible to have the C and the 3 be variables?
like MYByte = Readpin Port_Number . bitnumber
Where Port_Number and bitnumber are Varibles?
PostPosted: Wed Mar 03, 2021 1:48 am    Post subject: Reply with quote
For what chip because any may be addressed differently....Mega Xmega? Offset?
O-Family
PostPosted: Wed Mar 03, 2021 4:00 am    Post subject: Reply with quote
   Mybyte Alias Pina
   Mybit Alias 3
   Config Mybyte.mybit = Input
   Set Mybyte.mybit
   Dim Bitnumber As Byte
   Bitnumber = 1
'   Config Mybyte.bitnumber = Input                          'This will result in an error.
   Set Mybyte.bitnumber
   Bitnumber = 2
PostPosted: Wed Mar 03, 2021 4:05 am    Post subject: Reply with quote
I dont investigate it but it is obvious that you cant set PINx.... you can only set PORTx or DDRx
PostPosted: Wed Mar 03, 2021 5:12 am    Post subject: Reply with quote
I make mistake here Very Happy
PostPosted: Wed Mar 03, 2021 10:05 am    Post subject: Reply with quote
only the BIT part can be used with a variable.
The port part is not variable but you could make a function for that.
In the Xmega it would be simple, while in the normal AVR all the ports have different address.
SZTRAD
PostPosted: Wed Mar 03, 2021 11:24 am    Post subject: Reply with quote
I can't imagine what you need it for. Perhaps I can only think of creating a library. It works for output values and I used it but not in Bascom. I assume Bascom assigns translation registers based on the processor's def file. If you would like to do so you can assign the registry address of your variable to the beginning of the program and then work with it. But there is an unpleasant complication in losing the direct address option and turning it into an indirect one. So the advantage of In,Out,SBI,CBI will be lost to you.
RS
