Compile problem - Incorrect Number Of Paremeters
syndetic1
PostPosted: Thu Feb 25, 2021 12:09 am    Post subject: Compile problem - Incorrect Number Of Paremeters Reply with quote
When I try to compile the code below I get this error
Error : 130 Line : 19 Incorrect number of parameters. The number of parameters must be [ 3] , in File : "
As far as I can see I have 3 parameters and yet the compiler tells me I need 3.
I have tried putting byref in front of each of them and that does not work.
$regfile = "m128def.dat"
$sim                    ' Comment this out for real program
Dim p as byte
p=10
Dim  A as string * 16
A = "default string"
Dim B as string * 16
B = "123456789012345"
Declare sub read_token(pointer As byte, result As String, Abc As String)
   pointer = 2
   result  = "im changed"
   Abc = "changed too"
end sub
read_token(p, B , A)    ' <-----THIS LINE COMPILE ERROR
Print p
Print B
Print A
loop_forever:
goto loop_forever
end
PostPosted: Thu Feb 25, 2021 1:29 am    Post subject: Reply with quote
Remove the braces.
Only functions are called with braces, sub calls go without.
PostPosted: Thu Feb 25, 2021 7:57 am    Post subject: Reply with quote
Or simply...
Call Read_token(p , B , A)
will fix it too.
syndetic1
PostPosted: Thu Feb 25, 2021 11:08 pm    Post subject: Solved - Thank you Reply with quote
Thanks guys - greatly appreciated.
