Include version info/date into compilation output
Netzman
PostPosted: Tue Feb 23, 2021 2:23 pm    Post subject: Include version info/date into compilation output Reply with quote
Sometimes, one wants to include the firmware version, build dates etc at a fixed position into the binary output, to be used by bootloaders for example.
In Bascom, there is no equivalent to the assembler instruction .org, which does that.
Also, just placing this info via Data statements before your application code does not work, because there is no control over the generated prologue code.
But you can define the interrupt vector table, which is placed at the very beginning of the compilation output, so by defining the address for an interrupt which is not used in the application (preferably the associated peripheral/interrupt flag is deactivated so it does not generate this interrupt), it is possible to include 2 (3 for devices > 64K) bytes of data/int per hijacked interrupt:
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 48
$swstack = 32
$framesize = 64
Const Firmware_version = &HABBA
On Aci Firmware_version
Results in following .hex-file, I've marked the included version data (byte order reversed):
:100000000C94340018950000189500001895000015
:10001000189500001895000018950000189500002C
:10002000189500001895000018950000189500001C
:10003000189500001895000018950000189500000C
:1000400018950000189500001895000018950000FC
:100050001895000018950000189500000C94BAAB94
:1000600018950000189500008FEF8DBFC0EDE8E8EF
:100070004E2E88E08EBFD8E0F8E05F2EA89584B7BA
:10008000082E877F84BF88E1992780936000909332
:100090006000EEEFF7E0A0E0B1E088278D933197A4
:1000A000E9F76624F894FFCF3197F1F70895689443
:0A00B00062F80895E89462F80895DC
:00000001FF
Maybe this is of help for someone.
Br
LCD Menu | Proportional Fonts
six1
PostPosted: Wed Feb 24, 2021 7:26 am    Post subject: Reply with quote
! .org &H21AB
For technical reasons, the signature is on the back of this message.
Netzman
PostPosted: Wed Feb 24, 2021 8:18 am    Post subject: Reply with quote
$crystal = 16000000
$hwstack = 48
$swstack = 32
$framesize = 64
!nop
!nop
!nop
!nop
!nop
!nop
!nop
!nop
!nop
!nop
!nop
!.org &h52
Data &HAB , &HCD
PostPosted: Mon Mar 01, 2021 9:17 pm    Post subject: Reply with quote
Nice hack indeed. Very Happy . Thanks for sharing.
See also $reduceivr
There is the .org but since the vector table is created before that it is not usable to use that for putting code into the vector table.
