Micha
Posted: Fri Feb 12, 2021 8:53 am Post subject: Data-Lines in Lib and Inline-Asseembler |
Hello
I use a registered Version of Bascom and my interrest is on programming assembler, too.
With Directive
.db
you can store Databytes in Inline-Assembler and Libs.
Is there a way to store Word, Long and String like this?
.dw wordvalue
.dl longvalue
.db "String",0
Or must i use basic-command like Data to do this?
In Lib
*Basic: Data "Hallo" ; for String
*Basic: Data 1%, &h10, $10 ; for numeric
And how can i dim variables and array in assembler?
(BASCOM-AVR version : 2.0.8.3 ) |
laborratte
Posted: Fri Feb 12, 2021 1:44 pm Post subject: Re: Data-Lines in Lib and Inline-Asseembler |
Micha wrote: |
.dw wordvalue
.dl longvalue
.db "String",0
no.
Micha wrote: |
In Lib
yes.
BASCOM's assembler is not a full featured one like avrasm2. The idea is to support basic in cases where assembler code makes more sense, most likely in terms of size or speed.
Micha wrote: |
Use Basic.
An assembler does not have the concept of "dimming variables". You are loading or storing values into memory cells byte-wise, either directly or with a pointer. That's it. Everything else is up to the programmer. |
Micha
Posted: Sat Feb 13, 2021 6:00 am Post subject: |
If the compiler does not (yet) support it, it is clear that it does not work.
Thanks for the answer |
Posted: Sat Feb 13, 2021 12:13 pm Post subject: |
for a custom project (6502 to avr) it was required to have .dw and .ds so the next update has this support :
.dw for integer/words
.ds for strings "abc"
no support for single/double/long/dword
but could be added if users like that.
to dim a var is not possible.
but you can access it using {}
lds r24,{myvar} _________________ Mark |
Micha
Posted: Tue Feb 16, 2021 5:44 pm Post subject: |
Hello Mark
That would be great if double, long, single etc. were also supported.
Mitch |
AdrianJ
Posted: Tue Feb 16, 2021 11:56 pm Post subject: |
I still cant see the point in assigning high level data in assembler. Assembler has no direct commands for handling any form of data other than bytes. Anything else, you have to code subroutines for. So to get data to feed the subs, you can either just specify lists of bytes as .db statements, or use Bascom data statements to put in the high level numbers, then access them with the lds reg, {myvar} construction, or one of the ld indirect type commands. The whole point of being able to use asm within Bascom is to take advantage of both types of language, not to duplicate stuff which already exists. _________________ Adrian Jansen
Posted: Wed Feb 17, 2021 1:30 am Post subject: |
Micha wrote: | That would be great if double, long, single etc. were also supported. |
Which is rather clueless.
Quote: | ... and my interrest is on programming assembler, too. |
I don't doubt your interest, but you need to improve your basics first.
As Adrian correctly wrote, for assembler and especially for an 8bit AVR data like single, long a.s.o. are only a certain number of bytes, nothing more.
That's why it makes no sense to create such data types.
If you want to create a bridge between Bascom code and ASM-libs, you have already all the tools at hand.
As then simply declare the function prototypes, dimension the vars and add data to store in flash in Bascom code and acess everything from the lib. This is your only option anyway, as anything else would need to be programmed into the compiler. |
Posted: Wed Feb 17, 2021 9:59 am Post subject: |
i can see usage for long/dword.
but MWS and AdrianJ have good points for single/double.
So before doing that, send some example where it would be required that you can access this data. _________________ Mark |
Posted: Wed Feb 17, 2021 1:44 pm Post subject: |
albertsm wrote: | i can see usage for long/dword. |
.db, .dw, .dl would be constants (in case .CSEG, .DSEG, a.s.o. aren't implemented), do you intend to create a larger ASM-environment, which would also allow dimensioning of variables?
Kind of this scheme:
Quote: | myVar: .BYTE, 4 ' reserves 4 bytes SRam for variable named myVar |
I'd say post it here, so it can be discussed.
I see no big sense behind, trying to transfer only some of the originally dimensioned and declared stuff from a .bas file into the .lib, if still the lib must be called by Bascom code.
And therefore most likely parameters need to be handed over, and as long there is no scheme to completely integrate new commands into the Bascom compiler, there must be a minimum calling stub.
Take the libDEMO.bas from the samples folder, to call Test, the stub is:
Code: | Declare Sub Test(byval X As Byte , Y As Byte) |
For not having to mix user's main code with lib-environment code, the libDEMO.bas can be already included with minor modifications by:
Code: | $include "libDEMO.bas |
But if you need such a stub-.bas file anyway, then the writer of lib and bas-stub can also use DIM, DATA, CONST, and every other preparation needed by the lib.
Thus your efforts to include constants like .dl are honorable, but wasted time.
I'd love to hear from the TO why exactly he actually feels he can not go this way of an included .bas-file and why he needs the requested extension.
My suspicion in the moment is, that the TO does not know about the already existing possibilities and how to use them.
I may be wrong, but I have often experienced people wishing to have something, without even knowing how to use it.
BUT, this would have some completely different touch, if the .bas-stub can be unified with the .lib to teach the compiler new commands.
Call it .bib maybe
Means a bib would then contain everything, configuration prototype, function prototypes, flash data, dimensioned variables a.s.o.
Including a bib for example:
Quote: | $BIB "myRadio_RDA5807M" |
would allow to use the chip's functionality as for example:
Code: | Config RDA5807M, HighF = 1, PWR = ON, seekISR = OFF
RDA_tune_Up(step = 10)
RDA_tune_Down(step = 10)
RDA_set_Freq(freq = 100.00) |
This would be truly a game-changer, include only a bib and get new and completely contained functionality.
I can even think on a scheme, where bib-makers would get the option to protect their tedious work by encryption.
Not to understand me wrong, I like free software, but if some code takes lots of work, I can understand if the writer of same code doesn't want to hand it out for free.
If the charge is reasonable, both parties will win, if it's too expensive and not worth, another one may do it for less or free.
Back to topic, integrating some assembler options, while leaving out true chances will be a waste of your time.
Do you have time to waste? |
hgrueneis
Joined: 04 Apr 2009 Posts: 902 Location: A-4786 Brunnenthal
Posted: Wed Feb 17, 2021 8:28 pm Post subject: |
Prior to Bascom, I did among others a lot of assembly language, it was the times, but with the Bascom compiler there
is not a lot to gain (maybe in some cases). So, in my opinion, take Bascom or do assembly and be happy, because you spend a year to do the same as Bascom does in ten minutes.
Just my two bits.
Have fun.
Regards
Hubert |
AdrianJ
Posted: Wed Feb 17, 2021 11:49 pm Post subject: |
I agree with hgruensis.
In 20+ years of using both ASM and Bascom, I only found a couple of cases where ASM was significanty faster than Bascom. Now that Bascom has direct use of the registers to save intermediate values, rather than save and load from SRAM, even that time saving is mostly moot.
The only time I got significant saving was one case doing very complex bit-twiddling across a big byte array. Anything using 'ordinary' high level structures like words and longs, the savings are negligible. Bascom routines are VERY efficient - thanks to Mark.
If all you want is to save a bit of effort in writing dw instead of db,db then I cant see the point. You could just as easily use something like Visual Basic on a PC to do a 'translation' of any list of variables in any format you like into a list of .db statements, then insert that into the code. _________________ Adrian Jansen
Posted: Wed Feb 17, 2021 11:55 pm Post subject: |
hgrueneis wrote: | or do assembly and be happy |
The drawback of ASM is, that it is less serviceable and may take more efforts to write.
As we talk about libs and a lib is done only one time, the benefits of optimized speed and smaller flash footprint greatly outweight the drawbacks. |
