Can I use the Easy TCP/IP TWI and a buffered COM port?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive
TGJ
PostPosted: Thu Apr 20, 2006 3:54 pm    Post subject: Can I use the Easy TCP/IP TWI and a buffered COM port? Reply with quote
I am working with an Easy TCP/IP TWI board for a couple of days now. I am trying to realize a virtual com port inside a network. Therefore I use a Easy TCP/IP TWI board together with MEGA163. The program is quite easy. Everything what comes from the TCP/IP gets send to the RS232 port of the MEGA163 and everything what is coming from the RS232 will get send to the TCP/IP port. So far so good. Receiving data from the TCP/IP and sending it to the RS232 works perfect. The problem is the other way around. I have set up a buffer for the RS232, but I am still loosing data. It is just like if the buffer does not work. I thought that maybe the TCP/IP drivers are disabling the RS232 buffer somehow. Here is my program:
[code]$regfile = "m163def.dat" ' specify the used micro
$crystal = 7372800 ' used crystal frequency
$baud = 9600 ' use baud rate
$hwstack = 64 ' default use 32 for the hardware stack
$swstack = 64 ' default use 10 for the SW stack
$framesize = 100 ' default use 40 for the frame space
Const Sock_stream = $01 ' Tcp
Const Sock_dgram = $02 ' Udp
Const Sel_recv = 2
'socket status
Const Sock_closed = $00 ' Status Of Connection Closed
Const Sock_listen = $02 ' Status Of Waiting For Tcp Connection Setup
Const Sock_established = $06 ' Status Of Tcp Connection Established
Const Sock_close_wait = $07 ' Status Of Closing Tcp Connection
Const Etx = 3
Const Atk = 6
Const Etb = 23
Const True = 1
Const False = 0
Config Serialin = Buffered , Size = 80
' before we use config tcpip , we need to enable the interrupts
Config Tcpip = Int1 , Mac = 12.128.12.34.56.78 , Ip = 10.35.20.1 , Submask = 255.255.0.0 , Gateway = 10.35.200.1 , Localport = 1000 , Tx = $55 , Rx = $55 , Twi = &H80 , Clock = 400000
Dim Bclient As Byte ' socket number
Dim Idx As Byte
Dim Result As Word , Result2 As Word ' result
Dim Rx_buff(30) As Byte
Dim Rxbuff As String * 30
Dim Dummy As Integer
Dim Dummy$ As String * 2
Dim T As Integer
'Open "Com1:" For Binary As #1
Idx = 0
Result = Socketstat(idx , 0) ' get status
Select Case Result
Case Sock_established
Result = Socketstat(idx , Sel_recv) ' get number of bytes waiting
If Result > 0 Then
Result2 = Tcpread(idx , Rx_buff(1) , Result)
For T = 1 To Result
Dummy$ = Chr(rx_buff(t))
Print Dummy$;
Next T
Dummy = Len(rxbuff)
If Dummy > 0 Then
Result = Tcpwritestr(idx , Rxbuff , 0)
Home Lower
Lcd "RXBUF:" ; Dummy ; " Send:" ; Result
Rxbuff = ""
Case Sock_close_wait
Closesocket Idx
Case Sock_closed
Bclient = Getsocket(idx , Sock_stream , 5000 , 0) ' get socket for server mode, specify port 5000
Cls
Lcd "Socket" ; Bclient ; " closed "
Socketlisten Idx
End Select
While Ischarwaiting() <> 0
Dummy = Inkey()
Rxbuff = Rxbuff + Chr(dummy)
Wend
End[/code]
It is very simple but it still does not work. Does anyone have an idea?
Thanks in advance
Thomas
Frankeman
PostPosted: Thu Apr 20, 2006 6:45 pm    Post subject: Reply with quote
Hi, and welcome to this friendly forum.
I did not have completely checked your code but the "open com1: for binairy"is not needed.
This is for software uarts.
Frank.
TGJ
PostPosted: Fri Apr 21, 2006 8:04 am    Post subject: Reply with quote
Hi Frank,
thanks for your reply. The open statement is just a comment and it is remarked with a "'". I was just testing every possibility. I have rewritten this program about a hundred times.
By the way, there is one more thing what I did not mention. I am loosing more characters when I use a 115200 Baud com speed. It works better on 9600 Baud. This is even more evidence that the buffer does not work right.
Regards
Thomas
TGJ
PostPosted: Fri Apr 21, 2006 10:33 am    Post subject: Reply with quote
Here are some more information:
I have rewrote the program once more. I wrote my own URXC interrupt routine, so that I can make my own buffer for incoming data. The result was disappointing, since I got the same result. It looks like as if the “Config Tcpip” command blocks the URXC interrupt most of the time and the external interrupts INT0 und INT1 have the higher priority then the URXC interrupt.
Does anyone have a soulution?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive All times are GMT + 1 Hour
