odemmo
Posted: Thu Jan 21, 2021 12:59 pm Post subject: |
O-Family wrote: | You can create four types of ports for the program you copied and worked on, and call each of them.
Code: | Hx711_clk Alias Portd.2
Hx711_dat Alias Pind.3
' * Subroutine to retrieve A/D data from channel A of HX711 with a gain of 128 * (Hx711ad = 2's complement format 24bit)
Hx711get:
Hx711ad = 0
For Hx711count = 23 To 0 Step -1 'Extract 24-bit data.
Set Hx711_clk 'Set the [PD_SCK] pin of the HX711 to [H].
Waitus 1 'Period of [H]. (T3 = 1uS)
Hx711ad.hx711count = Hx711_dat 'Place the data of the [DOUT] pin of HX711 in each bit.
Reset Hx711_clk 'Set the [PD_SCK] pin of the HX711 to [L].
Waitus 1 'Period of [L]. (T4 = 1uS)
Next Hx711count
' * Send the 25th clock pulse (set channel A and gain to 128 for the next conversion) *
If Hx711ad.23 = 1 Then 'Is the 24-bit value of A/D a negative value?
Hx711ad = Hx711ad Or &HFF000000 'Set to a negative value of 32 bits.
Return |
Assign 4 types of ports directly to 4 types of subroutines as shown below.
Code: | Hx711get1:
Hx711ad = 0
Set Portd.2 'Set the [PD_SCK] pin of the HX711 to [H].
Hx711ad.hx711count = Pind.3 'Place the data of the [DOUT] pin of HX711 in each bit.
Reset Portd.2 'Set the [PD_SCK] pin of the HX711 to [L].
Next Hx711count
Hx711get2:
Hx711ad = 0
Set Portd.4 'Set the [PD_SCK] pin of the HX711 to [H].
Hx711ad.hx711count = Pind.5 'Place the data of the [DOUT] pin of HX711 in each bit.
Reset Portd.4 'Set the [PD_SCK] pin of the HX711 to [L].
Next Hx711count
Hx711get3:
Hx711get4: |
If your technology makes it difficult to create a complete program, please contact me directly on the bulletin board on my site. (English is also acceptable) |
Thanks, but where / how to call up these subroutines?
Oddvar |
Posted: Thu Jan 21, 2021 3:10 pm Post subject: |
hi,
do you know what is a sub ?
see the help for Gosub
I prefer use call subxxxxx() or using function
that is the fondamental of basic language.
I did an help about starting with Basic langage in french, if you need it let me your mail
odemmo
Posted: Thu Jan 21, 2021 7:33 pm Post subject: |
I am aware of Gosub but where in my code should I insert Gosub Hx711get1, Gosub Hx711get2, Gosub Hx711get3 abd Gosub Hx711get4.
I am aware of the principle of Basic since the 80's with CBM64 but Bascom Basic is more advanced Basic than what I learned then.
I really need this gadget that reads all 4 weights one by one.
I speak only Norwegian and google English  |
Posted: Thu Jan 21, 2021 8:32 pm Post subject: |
there are multiple solutions.
the most simple would be when you use a full port for example PORTB.
Say portb.0 and portb.1 for the first device, portb.2 and portb.3 for the next, etc.
code becomes :
Code: | For Hx711count = 23 To 0 Step -1 'Extract 24-bit data.
Set PORTB.0 'clock of first device
SET PORTB.2 'clock of second device
SET PORTB.4
SET PORTB.6
Hx711ad1.hx711count = PINB.1
Hx711ad2.hx711count = PINB.3
Hx711ad3.hx711count = PINB.5
Hx711ad4.hx711count = PINB.7
Reset PORTB.0
Reset PORTB.2
Reset PORTB.4
Reset PORTB.6
Next Hx711count
this is just a partial sample to show the idea where you perform the operations on 4 devices at once. this also requires 4 variables to contain the data.
you could also make a sub routine where you pass the bit numbers of the port.
and you can simple copy the code and then assign 4 different ports as the author suggested. _________________ Mark |
Posted: Thu Jan 21, 2021 8:35 pm Post subject: |
- you should start with the code you have for 1 device.
- then show us which pins you have for the other 3 devices. _________________ Mark |
odemmo
Posted: Thu Jan 21, 2021 11:56 pm Post subject: |
I use this code when I have only one HX711
$regfile = "m8def.dat"
$crystal = 3686400
$baud = 9600
$hwstack = 64
$swstack = 10
$framesize = 24
Hx711_clk Alias Portb.0
Hx711_dat Alias Pinb.1
Dim Hx711ad As Long
Dim Hx711avg As Long
Dim Hx711count As Byte
Dim Average(16) As Long
Dim Avgpoi As Byte
Dim Avgsum As Long
Dim Zeroadj As Long
Dim Stablecount As Byte
Dim Lastvalue As Long
Dim Sensorcal As Long
Dim Temp1 As Byte
Dim Temp2 As Byte
Dim Templ1 As Long
Dim Tempstr As String * 40
Dim Dummy As Eram Long
Dim Eepprgid As Eram Long
Dim Eepsensorcal As Eram Long
Config Hx711_clk = Output
Reset Hx711_clk
Config Hx711_dat = Input
If Eepprgid <> &H31375848 Then
Eepprgid = &H31375848
Eepsensorcal = 30065
Sensorcal = Eepsensorcal
For Temp1 = 1 To 20
Loop Until Hx711_dat = 0
Gosub Hx711get
Gosub Hx711movavg
Locate 2 , 1
Print Hex(hx711avg)
Next Temp1
Zeroadj = 0 - Hx711avg
Stablecount = 0
Lastvalue = 0
Temp2 = 0
Main:
If Hx711_dat = 0 Then
Gosub Hx711get
Gosub Hx711movavg
Templ1 = Hx711avg + Zeroadj
Templ1 = Templ1 * 100
Templ1 = Templ1 / Sensorcal
Temp2 = Temp2 + 1
If Temp2 > 10 Then
Temp2 = 0
waitms 100
Tempstr = Str(templ1)
If Templ1 < 0 Then
print Format(tempstr , " 0")
If Temp2 = 0 Then
Print Format(tempstr , " 0")
If Temp2 = 0 Then
If Templ1 = Lastvalue Then
Stablecount = Stablecount + 1
If Stablecount > 5 Then
Stablecount = 5
Lastvalue = Templ1
Stablecount = 0
Goto Main
Hx711get:
Hx711ad = 0
Set Hx711_clk
Waitus 1
Reset Hx711_clk
Waitus 1
Next Hx711count
Set Hx711_clk
Waitus 1
Reset Hx711_clk
Waitus 1
Hx711movavg:
Avgsum = Avgsum - Average(avgpoi)
Average(avgpoi) = Hx711ad
Avgsum = Avgsum + Hx711ad
Avgpoi = Avgpoi + 1
If Avgpoi > 16 Then
Avgpoi = 1
Hx711avg = Avgsum
Shift Hx711avg , Right , 4 , Signed
end
but now I want to use there more HX711 on port b2 to port b7
Thanks |
O-Family
Posted: Fri Jan 22, 2021 12:11 am Post subject: |
If the questioner has a high level of programming, we can also suggest simplifying the program.
For example, the [PD_SCK] pin is shared by all four ports and connected to one port, and only the [DOUT] pin is received individually by the four ports.
However, since many modifications of the provided test program are required, I proposed a method to make the four easiest subroutines by copying.
Even so, the questioner often doesn't understand the BASIC language.
You'll have to learn a little more and then ask questions or ask for all the programming.
It also does not provide any hardware information such as the power supply voltage (AVDD) for the HX711 load cell or the characteristics of the load cell used. |
odemmo
Posted: Fri Jan 22, 2021 12:29 am Post subject: |
Thanks.
I understand simple basic programming but this is too complicated for an old man like me and therefore I wants lots of help, help with the whole program is of course invaluable help and thanks.
To learn this I think will be very time consuming for a hobby project.
Thanks |
O-Family
Posted: Fri Jan 22, 2021 1:27 am Post subject: |
Yes, I think it takes some effort.
The coefficient calculation of the program changes depending on the power supply voltage (AVDD) for the load cell of the HX711 and the characteristics (resistance value and output voltage) of the load cell.
Also, for each of the four load cells, error adjustment and zero adjustment are required, so simply speaking, the program is quadrupled.
It corresponds to the idea of measuring with four separate AVR circuits and summarizing the four results obtained.
Simply asking only the subroutine part of a program can be difficult to solve if you don't know how the entire program works.
It may take some time, but do your best! |
odemmo
Posted: Wed Jan 27, 2021 1:09 am Post subject: |
Finally I got it, tips from you and lots of copying and pasting, I am not a trained programmer but have tried and failed since CBM64 in my youth but this type of programming is very complicated, but I got it.
$regfile = "m16def.dat"
$crystal = 3686400
$baud = 9600
$hwstack = 64
$swstack = 10
$framesize = 24
Dim Hx711ad As Long
Dim Avgpoi As Byte
Dim Avgsum As Long
Dim Zeroadj As Long
Dim Temp1 As Byte
Dim Temp2 As Byte
Dim Templ1 As Long
Reset Hx711_clk
For Temp1 = 1 To 20
Gosub Hx711get
Gosub Hx711movavg
Locate 2 , 1
Print Hex(hx711avg)
Next Temp1
Stablecount = 0
Lastvalue = 0
Temp2 = 0
Main:
Gosub Hx711get
Gosub Hx711movavg
Temp2 = Temp2 + 1
If Temp2 > 10 Then
Temp2 = 0
waitms 100
If Templ1 < 0 Then
If Temp2 = 0 Then
If Temp2 = 0 Then
Stablecount = 5
Lastvalue = Templ1
Stablecount = 0
Goto Main
Hx711get:
Hx711ad = 0
Set Hx711_clk
Waitus 1
Reset Hx711_clk
Waitus 1
Next Hx711count
Set Hx711_clk
Waitus 1
Reset Hx711_clk
Waitus 1
Hx711movavg:
Avgpoi = Avgpoi + 1
If Avgpoi > 16 Then
Avgpoi = 1
Hx711avg = Avgsum
end |
Posted: Wed Jan 27, 2021 10:15 am Post subject: |
hi
you should use the CODE tags when posting code like this :
Code: | $regfile = "m16def.dat"
$crystal = 3686400
$baud = 9600
$hwstack = 64
$swstack = 10
$framesize = 24
Dim Hx711ad As Long
Dim Avgpoi As Byte
Dim Avgsum As Long
Dim Zeroadj As Long
Dim Temp1 As Byte
Dim Temp2 As Byte
Dim Templ1 As Long
Reset Hx711_clk
For Temp1 = 1 To 20
'Do
'Loop Until Hx711_dat = 0
Bitwait Hx711_dat , Reset 'instead of do loop
Gosub Hx711get
Gosub Hx711movavg
Locate 2 , 1
Print Hex(hx711avg)
Next Temp1
Stablecount = 0
Lastvalue = 0
Temp2 = 0
'Main:
Gosub Hx711get
Gosub Hx711movavg
Temp2 = Temp2 + 1
If Temp2 > 10 Then
Temp2 = 0
waitms 100
If Templ1 < 0 Then
If Temp2 = 0 Then
If Temp2 = 0 Then
Stablecount = 5
Lastvalue = Templ1
Stablecount = 0
' Goto Main
Hx711get:
Hx711ad = 0
Set Hx711_clk
Waitus 1
Reset Hx711_clk
Waitus 1
Next Hx711count
Set Hx711_clk
Waitus 1
Reset Hx711_clk
Waitus 1
Hx711movavg:
Avgpoi = Avgpoi + 1
If Avgpoi > 16 Then
Avgpoi = 1
Hx711avg = Avgsum
End |
Also use the Proper Indent feature so you get automatic indention.
In your code i replaced main: goto main with a Do Loop
And the do loop until with a BITWAIT which is the equivalent.
Your code still uses 1 sensor but when it works as you want it is indeed a matter of copy & paste.
One important thing however : it is always a good idea to invest some time in what the end goal is. It is like making an IKEA furniture : best read all the pages before you start.
Now you have something working you can probably also better understand the commands better and you are able to use one of the methods to enhance with multiple sensors.
- simple copy & rename
- do all the 4 sensors at the same time
- make a sub routine and pass info like the bit number.
for example you have 2 bits you use. these you could pass :
Code: | declare function Something(byval sensorpin0 as byte, byval sensorpin1 as byte) as word 'or what ever you return
'call it like this
myword1=Something(0,1)
myword2=Something(2,3)
and in the sub you have a reference to the pin number :
portd.sensorpin0 = 0 'for example
end function
you best make a small example without the other code and look in the simulator how it will work. _________________ Mark |
