Function added to OLED library 'glcdSSD1306-I2C.lib'
Goto page 1, 2  Next
O-Family
PostPosted: Thu Dec 06, 2018 8:24 am    Post subject: Function added to OLED library 'glcdSSD1306-I2C.lib' Reply with quote
The following functions have been added to the I2C OLED display library "glcdSSD1306-I2C.lib".
1. Added option to rotate display 180 degrees.
Const Ssd1306_rotate = 1 'Display rotation. [connection cable is lower side = 0, upper side = 1]
2. Control byte added to the "GLCDCMD" instruction.
Normal/Inverse Display [A6:Normal , A7:Inverse]
Display ON/OFF [AE:OFF(sleep mode) , AF:ON(normal mode)]
3. Contrast can be changed.
_contrast = 0 : Glcdcmd &H81 'Change contrast of the OLED [0:dark - 255:bright]
4. Underline option added to the "LCDAT" instruction. [2:Solid , 3:dotted]
'                       SSD1306-I2C_V2.BAS
'                     (c) MCS Electronics 1995-2015
'          Sample to demo the 128x64 I2C OLED display [V2]
$regfile = "m88pdef.dat"
$hwstack = 32
$swstack = 32
$framesize = 32
Config Clockdiv = 1                                         ' make sure the chip runs at 8 MHz
Config Scl = Portc.5                                        ' used i2c pins
Config Sda = Portc.4
Config Twi = 400000                                         ' i2c speed
I2cinit
$lib "i2c_twi.lbx"                                          ' we do not use software emulated I2C but the TWI
$lib "glcdSSD1306-I2C_V2.lib"                               ' override the default lib with this special one
#if _build < 20784
  Dim ___lcdrow As Byte , ___lcdcol As Byte                 ' dim these for older compiler versions
#endif
Dim _contrast As Byte                                       ' Contrast value of OLED. [0-255]
'Const Ssd1306_rotate = 1                                    ' Display rotation. [connection cable is lower side = 0, upper side = 1]
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
Setfont Font8x8tt                                           ' select font
   Lcdat 1 , 1 , "BASCOM-AVR"
   Lcdat 2 , 10 , "1995-2015"
   Lcdat 3 , 5 , "MCS Electronics" , 1                      ' Optional invert
   Lcdat 5 , 1 , " ABCDefg012345678 " , 2                   ' Optional solid underline
   Lcdat 7 , 1 , " ABCDefg012345678 " , 3                   ' Optional dotted underline
   Wait 3
   Glcdcmd &HA7                                             ' Normal/Inverse Display [A7:Inverse]
   Wait 3
   Glcdcmd &HA6                                             ' Normal/Inverse Display [A6:Normal]
   Wait 3
   _contrast = 0 : Glcdcmd &H81                             ' Change contrast of the OLED [0:dark - 255:bright]
   Wait 3
   _contrast = 255 : Glcdcmd &H81                           ' Change contrast of the OLED [0:dark - 255:bright]
   Wait 3
   Glcdcmd &HAE                                             ' Display ON/OFF [AE:OFF(sleep mode) , AF:ON(normal mode)]
   Wait 3
   Glcdcmd &HAF                                             ' Display ON/OFF [AE:OFF(sleep mode) , AF:ON(normal mode)]
   Wait 3
   Showpic 0 , 0 , Plaatje
   Wait 3
$include "font8x8TT.font"                                   ' this is a true type font with variable spacing
Plaatje:
   $bgf "ks108.bgf"                                         ' include the picture data
PostPosted: Sun Dec 09, 2018 1:38 pm    Post subject: Reply with quote
Thanks for adding these useful options and sharing them Very Happy
BoA
PostPosted: Tue Jan 15, 2019 5:11 pm    Post subject: Reply with quote
Thanks a lot... it work .. Wink)
mrak
PostPosted: Mon Sep 09, 2019 11:03 pm    Post subject: Library support for two SSD1306 displays on I2C bus Reply with quote
The SSD1306-I2C displays enable configuration to have two devices on the same I2C bus under different addresses. Does the current "glcdSSD1306-I2C.lib" can be configured for such a setup? If no, do you plan to include such functionality?
O-Family
PostPosted: Tue Sep 10, 2019 9:22 am    Post subject: Reply with quote
I think that is possible by adding and modifying the library.
I will consider a fix when I have time.
mrak
PostPosted: Tue Sep 10, 2019 4:23 pm    Post subject: Library support for two SSD1306 displays on I2C bus Reply with quote
That would be excellent!
Users could get the most out of the "glcdSSD1306-I2C.lib" library and enjoy the experience of having full capability provided by two SSD1306 displays working in pair when one display is insufficient, like in my project.
PostPosted: Tue Sep 10, 2019 11:39 pm    Post subject: Reply with quote
There are also I2C switces that enable multiple devices with the same address on a buss
I am using one with two ADCs that only have one address.
Regards paul
O-Family
PostPosted: Fri Sep 20, 2019 3:40 am    Post subject: 2-Displays version Reply with quote
A version that controls two displays was created at the request of the user.
Enter the I2C slave address in the variable [I2c_addr] and specify the device. [&H78 or &H7A]
The OLED on the left side of the image is not a color, it is two fixed color types.
'                       SSD1306-I2C_V2x2.BAS
'                        (2-Displays version)
$hwstack = 32
$swstack = 32
$framesize = 32
Config Scl = Portd.2                                        ' When using software I2C.
Config Sda = Portd.3
Config I2cdelay = 1
I2cinit
'$lib "i2c_twi.lbx"                                          ' we do not use software emulated I2C but the TWI
'Config Scl = Portc.5                                        ' used i2c pins
'Config Sda = Portc.4
'Config Twi = 400000                                         ' i2c speed
'I2cinit
Dim I2c_addr As Byte                                        ' I2C slave address selection. [&H78 or &H7A]
$lib "glcdSSD1306-I2C_V2x2.lib"                             ' override the default lib with this special one
I2c_addr = &H78                                             ' Select device [1]
I2c_addr = &H7A                                             ' Select device [2]
Lcdat 5 , 1 , "    Device [1]    " , 2                      ' Optional solid underline
Lcdat 7 , 1 , "    Device [1]    " , 3                      ' Optional dotted underline
Lcdat 5 , 1 , "    Device [2]    " , 2                      ' Optional solid underline
Lcdat 7 , 1 , "    Device [2]    " , 3                      ' Optional dotted underline
PostPosted: Fri Sep 20, 2019 9:40 am    Post subject: Reply with quote
excellent work. thanks !
Memen
PostPosted: Fri Sep 20, 2019 8:19 pm    Post subject: Reply with quote
Fine! 1995 - 2019 amendment)))
timbak
PostPosted: Mon Jan 18, 2021 3:33 am    Post subject: Reply with quote
O-Family can you pls help with run this lib on Xmega?
Trying to run this on atxmega32a4u and getting errors:
Dim Twi_start As Byte
Open "twic" For Binary As #2
Config Twic = 400000
I2cinit #2
Setfont Font8x8tt
Error : 5 Line : -625 No more space for BIT [_CONTRAST] , in File : C:\MCS\BASCAVR2083\LIB\GLCDSSD1306-I2C_V2.LIB
Error : 320 Line : 104 [syntax error, token = '{'] , in File : C:\MCS\BASCAVR2083\LIB\GLCDSSD1306-I2C_V2.LIB
O-Family
PostPosted: Mon Jan 18, 2021 9:53 am    Post subject: Reply with quote
Declare _contrast as described in the test program I posted.
timbak
PostPosted: Mon Jan 18, 2021 12:39 pm    Post subject: Reply with quote
O-Family thank You for quick response. Now it works!
I use 0.66" 64x48 display, and have some offset in coordinates, and this is different in rotation modes
my code:
Config Graphlcd = Custom , Cols = 64 , Rows = 48 , Lcdname = "SSD1306"
Setfont Font8x8tt
Glcdcmd &HA7
Lcdat 1 , 33 , "1234567#1"
Lcdat 2 , 33 , "1234567#2"
Lcdat 3 , 33 , "1234567#3"
Lcdat 4 , 33 , "1234567#4"
Lcdat 5 , 33 , "1234567#5"
Lcdat 6 , 33 , "1234567#6"
it need set second coordinate to 33 for correct string drawing
this is what i get when Ssd1306_rotate is changed:
O-Family
PostPosted: Tue Jan 19, 2021 3:02 am    Post subject: Reply with quote
SSD1306 is a 128x64 Dot controller and I think your OLED has different address pin connections.
I don't have this OLED so I'm not sure if it works, but try this library.
timbak
PostPosted: Tue Jan 19, 2021 10:06 am    Post subject: Reply with quote
O-Family, it works perfect! Thank You so much for the fiix
Goto page 1, 2  Next
Page 1 of 2
