Atmega328pb - cannot get any LED's to turn on!?
Goto page 1, 2  Next
TSEYFARTH
PostPosted: Wed Jan 06, 2021 11:36 pm    Post subject: Atmega328pb - cannot get any LED's to turn on!? Reply with quote
Hello all.
I have a simple program and all I want to do is to turn on a couple of LED's using the Atmega328PB. Even when I use the sample program and add the code they still wont turn on.
$regfile = "m328pbdef.dat"
$crystal = 16000000
$baud = 19200
$hwstack = 40
$swstack = 40
$framesize = 40
'Config Clockdiv = 1                                         'make sure we get 8 Mhz from internal osc
  'For LED Indicators ***********************
   Snddataled Alias Portd.6
   Config Snddataled = Output                               'Input
   Set Snddataled                                           'Set = High
   Recdataled Alias Portd.5
   Config Recdataled = Output                               'Input
   Set Recdataled                                           'Set = High
   BT_Snddataled Alias Portc.1
   Config BT_Snddataled = Output                               'Input
   Set BT_Snddataled                                           'Set = High
   BT_Recdataled Alias Portc.0
   Config BT_Recdataled = Output                               'Input
   Set BT_Recdataled                                           'Set = High
   Reset Snddataled
   Reset Recdataled
   Reset bt_snddataled
   Reset bt_recdataled
'   Waitms 1000
'   Set Recdataled
'   Set Snddataled
'   set bt_snddataled
'   set bt_recdataled
Print "Scan start"
[img]
   Print "COM1"
   Waitms 1000
A schematic is included here to see too...
Thanks in advance!
Tim
TSEYFARTH
PostPosted: Thu Jan 07, 2021 2:39 am    Post subject: Reply with quote
I've also tried with an ATMEGA88 - which is pin compatible, at least for the pins I am using!
Still no good.
If I bypass the uC and bring ground to the LED, it does turn on, but will not turn on with the uC.
Any help/ideas would be appreciated!
Thank you,
Tim
Printpix52
PostPosted: Thu Jan 07, 2021 3:16 am    Post subject: Reply with quote
Positive anode and negative cathode turn on led and positive anode and positive cathode off led.
   Config Snddataled = Output                               'Output
   Reset Snddataled                                           'Reset = High ;Led ON
   Config Recdataled = Output                               'Output
   Reset Recdataled                                           'Reset = High; Led ON
   Config BT_Snddataled = Output                               'Output
   Reset BT_Snddataled                                           'Reset = High;Led ON
   Config BT_Recdataled = Output                               'Output
   Reset BT_Recdataled                                           'Reset = High;Led ON
   set Snddataled                                                 'Led OFF
   set Recdataled                                                 'Led OFF
   set bt_snddataled                                             'Led OFF
   set bt_recdataled 'Led OFF
Very Happy Very Happy
enniom
PostPosted: Thu Jan 07, 2021 3:22 am    Post subject: Reply with quote
Input?
LED powered from 3v3?
E
[PS: is it COM1 or COM0? ]
PostPosted: Thu Jan 07, 2021 9:32 am    Post subject: Reply with quote
Why not to ground pin 21 on the schematic? Very Happy
Your code copied from this forum is working -> see pics.
PostPosted: Thu Jan 07, 2021 9:36 am    Post subject: Reply with quote
avcc seems unconnected.
when searching for problems :
- check short circuit between gnd and vcc but since the firmware programs that should be no problem
- check short circuit on the output pin
- check voltage. simple way is to to use 2 led with one led reverse connected. and of course with a series resistor
then it is important that the good way to connect is as you did between vcc and the port : making a port pin low will make the led light
of course new avr also allow to connect between the port pin and gnd : making a port pin high will make the led light
the total mA a port/processor can draw you can find in the datasheet.
since that is all ok i assume that avcc is the problem.
you can also do the simple test :
config portd.5=output
do
  toggle portd.5
  waitms 1000
loop
PostPosted: Thu Jan 07, 2021 9:38 am    Post subject: Reply with quote
haha, yes that is essential.
basically ; when the simple led program does not work : check your hardware
SZTRAD
PostPosted: Thu Jan 07, 2021 11:20 am    Post subject: Reply with quote
Unfortunately I don't have AT328PB connected here, but all other atmegs have internally connected GND.
I'm not saying they shouldn't get involved.
A fellow interviewer did not write if the transfer to COM works for him. If not, his chip isn't working. If so, RESET is active (externally or internally).
hgrueneis
PostPosted: Thu Jan 07, 2021 12:51 pm    Post subject: Reply with quote
A 10K pullup on the RESET might also be helpful.
Regards
Hubert
PostPosted: Thu Jan 07, 2021 5:34 pm    Post subject: Reply with quote
And don't use blue or white Leds with a VCC of 3.3V ;D
hgrueneis
PostPosted: Thu Jan 07, 2021 7:19 pm    Post subject: Reply with quote
If you doubt all the help , that very experienced people give you here, then you should go somewhere else.
You do not even attend to the bare essentials of the electronic requirement for these processors.
My advice, study the datasheets and the Bascom Help. When you are through with that and you still have problems, come back here.
Otherwise "Good luck"
Regards
Hubert
TSEYFARTH
PostPosted: Thu Jan 07, 2021 9:18 pm    Post subject: Reply with quote
Hello all and THANK YOU for all of your helpful responses!
I'm trying the suggestions and will get back with you all.
Thank you again,
Tim
PostPosted: Fri Jan 08, 2021 11:34 am    Post subject: Reply with quote
a scope is a a good friend Wink
jp
TSEYFARTH
PostPosted: Fri Jan 08, 2021 10:06 pm    Post subject: Reply with quote
Checked with a scope and meter. The pins at the uC stay at 1.7 Volts. They never go to a true hi (3.3) or low.
Other than what has been suggested already, anything else to look at?
Thanks all!
Tim
TSEYFARTH
PostPosted: Fri Jan 08, 2021 10:15 pm    Post subject: Reply with quote
Also tried toggling a spare set of pins that are not connected to anything. According to the scope, they stayed low and never changed.
Must be something with the PCB or chip? It programs fine so the xtal should be OK, all of the power and grounds are set up now.It is getting 3.3V.
I've never had a situation where the chip did not respond properly.
Any ideas?
Tim
$crystal = 16000000
$baud = 19200
$hwstack = 40
$swstack = 40
$framesize = 40
config portd.3=output
config portd.4=output
do
  toggle portd.3
  toggle portd.4
  toggle portd.5
  waitms 1000
loop
Goto page 1, 2  Next
Page 1 of 2
