kaeferdressierer
Posted: Thu Apr 13, 2006 1:44 pm Post subject: TCP/IP Test Board Proplem |
Hallo !
I use:
Bascom 1.11.8.2
if i input a crystal with 16mhz, the sampe WEBSERVER dos not work.
Only Ping and serial DEBUG is ok. ( I have set the $crystal to 16 mhz in the compiler)
It works with 4mhz and 8Mhz(RC-Oszill.) very good.
Where are the limits for the board bzw is it a compiler-Proplem ???
Thanks for answering ! |
kaeferdressierer
Posted: Fri Apr 14, 2006 6:40 am Post subject: Further details |
Hallo !
I have tries today again. 16mhz do not work.
I get only with the serial DEBUGING:
init W3100A
If working (4-8Mhz) i get:
init W3100A
closed
Listening on socket 0
Thanks for ansering ! |
Frankeman
Posted: Fri Apr 14, 2006 4:13 pm Post subject: |
The WizNet module resides in the external memory space.
If the module is slower than the busspeed it will not work.
Go To "options - compiler - chip" and check "XRAM waitstate".
Maybe that will help.
Frank. |
kaeferdressierer
Posted: Sat Apr 15, 2006 9:04 am Post subject: |
Thank you Frank !
I will try it on Tuesday.
Best one greets
Bernhard |
kaeferdressierer
Posted: Wed Apr 19, 2006 2:18 pm Post subject: |
I have tryed and it works !
With 16mhz i can send and recive with 2 TCP-IP-Boards 12765 Bytes/sec.
I need more network POWER. ( lower Delay )
I need to send 2Bit and recive 2Bit over network in lower then 10µs.
What can i do ? Other network Modules ?
Please help !
Thank you very !!!!!! |
Frankeman
Posted: Wed Apr 19, 2006 4:03 pm Post subject: |
The waitstate function in Bascom is all or nothing.
Most AVR's have four different settings but you must set the bits yourself.
Look for the registerbits named SRW, play with them and maybe your system runs a little faster.
No waitstates isn't working you allready know that, and max waitstates works.
But there are two delays between them.
Frank. |
