Writing to external EEPROM fails
MadAl
PostPosted: Tue Dec 22, 2020 9:39 pm    Post subject: Writing to external EEPROM fails Reply with quote
I've been trying to write data in a simple test program to an external eeprom (25LC1024) via SPI.
The output I get is:
Written to EEPROM : 84
Read from EEPROM ; 255
Written to EEPROM : 85
Written to EEPROM : 86
Written to EEPROM : 87
Written to EEPROM : 88
Written to EEPROM : 89
And as the spi_result is set to zero at program start and a virgin eeprom has the value 255 on all addresses, I presume the reading (and therefore SPI communication) works.
Can anyone spot the cause of the write fail?
$regfile = "m328pdef.dat"                                   ' specify the used micro
$crystal = 11059200                                         'this crystal allows the max bootloader speed of 115200 baud as all baud rates have zero error
$baud = 115200                                              '115200 baud rate for hardware serial communication
$hwstack = 256
$swstack = 256
$framesize = 24
Waitms 200
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Clockrate = 16 , Master = Yes , Polarity = Low , Phase = 0 , Noss = 1
Spiinit
Dim Spi_control_write As Byte
Dim Spi_control_read As Byte
Dim Spi_address As Word
Dim Spi_data As Byte
Dim Spi_result As Byte
Dim Spi_write_enable As Byte
Spi_write_enable = &B0000_0110
Spi_control_write = &B0000_0010                             'write command
Spi_control_read = &B0000_0011                              'read command
Spi_address = 0
Rotate Spi_address , Left , 8                               'fix address bytes
Spi_data = 64                                               'test data
Mycs Alias Portd.7
Config Mycs = output
Set Mycs
Spi_result = 0
   Incr Spi_address
   Incr Spi_data
   Reset Mycs
   Spiout Spi_write_enable , 1
   Set Mycs
   Waitms 10 'Note, changing this value to zero or higher doesn't solve the issue
   Reset Mycs
   Spiout Spi_control_write , 1
   Spiout Spi_address , 2
   Spiout Spi_data , 1
   Set Mycs
   Print "Written to EEPROM : " ; Spi_data
   Waitms 100
   Reset Mycs
   Spiout Spi_control_read , 1
   Spiin Spi_result , 1
   Set Mycs
   Print "Read from EEPROM ; " ; Spi_result
   Waitms 500
thanks.
MadAl
PostPosted: Tue Dec 22, 2020 10:14 pm    Post subject: Reply with quote
Alternative code, same problem:
$hwstack = 256
$swstack = 256
$framesize = 24
Waitms 200
Spiinit
Dim Adress As Dword
Dim Adre(4) As Byte At Adress Overlay
Spi_control_read = &B0000_0011                              'read command                                               'test data
Mycs Alias Portd.7
Set Mycs
Spi_result = 0
Adress = 0
Spi_data = 0
   Incr Adress
   Incr Spi_data
   Reset Mycs
   Set Mycs
'   Waitms 10
   Reset Mycs
   Spiout Adre(3) , 1                                       'send the write address (in 3 bytes)
   Spiout Adre(2) , 1
   Spiout Adre(1) , 1
   Spiout Spi_data , 1
   Set Mycs
   Print "Written to EEPROM : " ; Spi_data ; "  at address " ; Adress
   Waitms 100
   Reset Mycs
   Spiout Adre(2) , 1
   Spiout Adre(1) , 1
   Set Mycs
   Print "Read from EEPROM ; " ; Spi_result ; "  at address " ; Adress
   Waitms 500
PostPosted: Wed Dec 23, 2020 2:05 am    Post subject: Reply with quote
Either set PB2 as output or pull it high.
PostPosted: Tue Dec 29, 2020 1:41 pm    Post subject: Reply with quote
since you set NOSS=1 it means you will not use the SS pin which is ok. But it also means you will set the pin yourself. In that case you must take care that the designated SS pin is set to output mode. Otherwise the pin is by default an input and it could lead to the master set to input mode. and like MWS says, you can also pull the SS pin high.
