' Test sensirion SHT11
' r.0 21/11/03
$regfile = "Reg51.dat"
'$map
'$sim
$crystal = 11059200
$large
$noramclear
' uso Port
'P1.0
'P1.1
'P1.2 Rs display
'P1.3 En "
'P1.4 Db4 "
'P1.5 Db5 "
'P1.6 Db6 "
'P1.7 Db7 "
'P3.0 Rx
'P3.1 Tx
'P3.2 SHT_clock
'P3.3 SHT_data
'P3.4 Led
'P3.5
'P3.6
'P3.7
' constant
Const P1dis = &B11111111 'disattiva port P1
Const P3dis = &B11111111 'disattiva port P3
' addr command r/w
Const STATUS_REG_W = &B00000110 '000 xxxx x
Const STATUS_REG_R = &B00000111 '000 xxxx x
Const MEASUR_TEMP = &B00000011 '000 xxxx x
Const MEASUR_HUMI = &B00000101 '000 xxxx x
Const SOFT_RESET = &B00011110 '000 xxxx x
Const Maxtim = 150 'timeout SHT answer 300ms
Const C1 = -4 'humidity x 12bit
Const C2 = 0.0405
Const C3 = -0.0000028
Const T1 = 0.01
Const T2 = 0.00008
Const D1 = -40 'temperature x 14bit @ 5v
Const D2 = 0.01
Dim Fl_Err As Bit
Dim Ack_ret As Bit
Dim Tmp1 As Byte
Dim Txx As Byte
'Dim Crc As Byte
Dim TmpW As Word
Dim TmpSing As Single
Dim Tmp2Sin As Single
Dim Result As Single
Dim Strin As String * 5 'usato per display lcd
'RoLed Alias P3.4
SHT_data Alias P3.3
SHT_clk Alias P3.2
Config Lcd = 16 * 2
Config LCDPIN = PIN,DB4=P1.4,DB5=P1.5,DB6=P1.6,DB7=P1.7,E=P1.2,RS=P1.3
P3 = P3dis 'predispone stato iniziale
P1 = P1dis
waitms 100
cls
waitms 2
cursor off
waitms 2
lcd "Test SHT11"
wait 2
Stay:
call SHT_reset
call SHT_Txstart
Acc = SOFT_RESET
call SHT_write
if Ack_ret = 1 then goto Wrong
waitms 50 'tempo per soft reset
cls
waitms 2
Txx = MEASUR_TEMP 'send temperature read command
call Read_SHT
if Fl_Err = 1 then exit do 'no ack
TmpSing = TmpW * D2
TmpSing = TmpSing + D1
Result = TmpSing 'save x Humidity
Strin = fusing(TmpSing,###.#)
lcd "T. "; Strin
locate 1,11
waitms 2
lcdhex TmpW
waitms 100
locate 2,1
waitms 2
Txx = MEASUR_HUMI 'send Humidity read command
call Read_SHT
TmpSing = TmpW * C3
TmpSing = TmpSing + C2
TmpSing = TmpSing * TmpW
TmpSing = TmpSing + C1 ' RHlinear
Result = Result - 25
Tmp2Sin = TmpW * T2
Tmp2Sin = Tmp2Sin + T1
Tmp2Sin = Tmp2Sin * Result
TmpSing = TmpSing + Tmp2Sin
Strin = fusing(TmpSing,##.#)
lcd "H. "; Strin
locate 2,11
lcdhex TmpW
wait 3
Wrong:
cls
waitms 2
lcd "Err";
if Ack_ret = 1 then
lcd " NACK"
endif
If Txx > Maxtim then
lcd " Timeout"
endif
wait 4
goto Stay
' PROCEDURE
Sub Read_SHT
Fl_Err = 1 'default error ON
TmpW = &HFFFE
call SHT_reset
call SHT_Txstart
Acc = Txx 'passa comando
call SHT_write
if Ack_ret = 1 then exit sub 'uscita per NACK
call SHT_answer
if Txx > Maxtim then exit sub 'uscita per timeout
call SHT_read 'riceve high byte
high(TmpW) = Acc
call SHT_ack 'invia ack di risposta
call SHT_read 'riceve low byte
low(TmpW) = Acc
call SHT_ack
' P3.4 = 1
call SHT_read 'riceve crc
' Crc = Acc
call SHT_nack 'chiude comunicazione
' P3.4 = 0
Fl_Err = 0 'no errors
End sub
Sub SHT_answer
Txx = 0
if SHT_data = 0 then exit sub
incr Txx
waitms 2
loop until Txx > Maxtim '300ms per rispondere
End sub
$asm
SHT_reset:
push b
clr {SHT_clk} 'clock pin low
setb {SHT_data} 'data pin high
mov b,#9
res1:
setb {SHT_clk} 'clock = 1
nop
nop
clr {SHT_clk} 'clock = 0
nop
djnz b,res1
pop b
ret
SHT_TXstart:
setb {SHT_data} 'data = 1
nop
nop
clr {SHT_data} 'data = 0
nop
push acc
pop acc
nop
nop
ret
'scrittura dato in A su sht
SHT_write:
push b
mov b,#8
Wr1:
rlc a 'db7 > Cy
mov {SHT_data},c
nop
nop
djnz b,Wr1
mov c,{SHT_data} 'read ack
mov {Ack_ret},c 'return ack value
pop b
ret
'lettura dato da SHT
SHT_read:
push b
mov b,#8
clr a
Rd1:
mov c,{SHT_data}
rlc a 'cy > db7
nop
djnz b,Rd1
'ritorna dato in acc
pop b
ret
SHT_nack:
setb {SHT_data} 'data = 0
sjmp SHT_na
SHT_ack:
clr {SHT_data} 'data = 1
nop
SHT_na:
nop
nop
ret
$end asm
