Statement: SEEK #bFileNumber, NewPos
hzz
PostPosted: Tue Nov 24, 2020 12:46 am    Post subject: Statement: SEEK #bFileNumber, NewPos Reply with quote
Has anyone tested SEEK as a statement (To set the file pointer to a desired location)?
I can't make it work even in a simple example:
   If Sd_card_ready = 1 Then
'     Open File
      P_file_handle = Freefile()
      File_name1 = "Test11.bin"                             '********************************************************************** PUT HERE THE DESIRED FILE NAME
      Open File_name1 For Binary As #p_file_handle
'     Set starting at position =20
       Ltemp = 20
       Seek #p_file_handle , Ltemp
        Print #1 , "Gbdoserror=" ; Gbdoserror
'      Write data at position 20
      Btemp1 = 33
      Put #p_file_handle , Btemp1
        Print #1 , "Data_byte pos=" ; Loc(#p_file_handle)       ' This must be  20    but it is 1 ¿?
'     Save data to SD Card and close file
'      Flush #p_file_handle                                  ' flush to disk    (This is not needed. The data is already flushed when Closing the file)
      Close #p_file_handle
What I expected this code to print is:
Test SD Card
SD Card OK
Filesystem = 11
Gbdoserror=0
Data_byte pos=20
However it prints the following when the file is created (the first time I run the program)
Test SD Card
SD Card OK
Filesystem = 11
Gbdoserror=0
Data_byte pos=1 This should be 20!
After this, everytime I run the program with the file is already created in the SD card, it prints the following:
Test SD Card
SD Card OK
Filesystem = 11
Gbdoserror=97 This error is cpFilePositionError
Notes:
- I have tried to create files, subdirectories, write content to files, Dir the files and everything seems to work fine. It is just a problem with Seek as stratement.
- I'm using a XMEGA192A3U
- The complete code is posted at the end of https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=14714
- The SD card has been formatted with SD Card Formatter as suggested in BASCOM Help
- The card is a 4GB SDHC Card
- I have tried with a 16GB SDHC card and the result is the same, except that Filesystem = 12
PostPosted: Tue Nov 24, 2020 9:58 am    Post subject: Reply with quote
The first step is always to read the help topic. In this case for SEEK.
It has an important note : In QB/VB you can use seek to make the file bigger. When a file is 100 bytes long, setting the file pointer to 200 will increase the file with 0 bytes. By design this is not the case in AVR-DOS.
So if you want to create files of certain size, you must do so explicit by writing to the file.
