Watchdog not stopping
altron
PostPosted: Thu Nov 19, 2020 1:26 am    Post subject: Watchdog not stopping Reply with quote
Hi
I had a problem with the Watchdog not stopping with the STOP WATCHDOG command with a XM128a1.
Example of not working.
Disable Jtag
$prog &HFF , &HFF , &H00 , &HFE , &H00 , &HFF , &HFB        ' generated. Take care that the chip supports all fuse bytes.
$regfile = "xm128a1def.dat"
$crystal = 32000000                                         '32MHz
$hwstack = 128
$swstack = 128
$framesize = 128
Config Osc = Enabled , Pllosc = Disabled , Extosc = Disabled , 32khzosc = Disabled , 32mhzosc = Enabled , 32khzpowermode = Low_power       '32MHz
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1  '32MHz
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled , Hi = Enabled
Config Eeprom = Mapped
Active_led Alias Portf.5
Config Active_led = Output
Waitms 500
Active_led = 1                                                   'led
Waitms 2000
Config Watchdog = 4000                                      'reconfig to 4 sec
Start Watchdog
Active_led = 0
Stop Watchdog   '<<<<<<This dosent stop the watchdog
Active_led = 1
   Toggle Active_led
   Waitms 100
The watchdog takes sometime to sync with the system clock after being enabled. You need to wait till the SYNC bit is reset before stopping.
Example of working:
Disable Jtag
$hwstack = 128
$swstack = 128
$framesize = 128
Waitms 500
Active_led = 1
Waitms 2000                                                 'led
Config Watchdog = 4000                                      'reconfig to 2 sec
Start Watchdog
Active_led = 0
Gosub Stop_watchdog
Active_led = 1
   Toggle Active_led
   Waitms 100
Stop_watchdog:
      If Wdt_status.0 = 0 Then
         Exit Do
      Waitms 1
   Loop                                                     'Until Wdt_status.0 = 0
   Stop Watchdog
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.3 )
PostPosted: Thu Nov 19, 2020 11:25 am    Post subject: Reply with quote
thanks, i will check it and change it when required.
