Bootloader being overwritten during program execution?
KenHorse
PostPosted: Tue Nov 10, 2020 9:51 pm    Post subject: Bootloader being overwritten during program execution? Reply with quote
I'm running the Bascom bootloader in an M2561 and may have experienced the loaded program overwriting (or partially overwriting) the bootloader. And while I have seen loading too large a program into the AVR overwriting the bootloader I have never seen an overwrite (at least what I perceive to be an overwrite as the only way to correct it is to reload the bootloader itself) from the loaded program itself running
PostPosted: Tue Nov 10, 2020 10:07 pm    Post subject: Reply with quote
Are you using $loadersize in your main prog to tell the compiler you are using flash space for the bootloader?
PostPosted: Tue Nov 10, 2020 10:51 pm    Post subject: Reply with quote
You can also set a fuse to disable writing to the bootloader area. Obviously, do this after installing the bootloader !
And for added general security, set another fuse bit to prevent any read access to the bootloader too. Then its extremely difficult for a 3rd party to access your loader and take it over to read your code, or install foreign software.
Adrian Jansen
KenHorse
PostPosted: Wed Nov 11, 2020 12:47 am    Post subject: Reply with quote
Yes but doesn't that just protect that a program won't compile larger than is safe for the bootloader? In other words, if I know the compiled code size won't invade the bootloader memory, isn't that effectively the same thing?
KenHorse
PostPosted: Wed Nov 11, 2020 12:48 am    Post subject: Reply with quote
There's a good idea.......
PostPosted: Wed Nov 11, 2020 9:46 am    Post subject: Reply with quote
all remarks are excellent. i want to add this.
you can limit the write so it will not write into the boot area, or any other area you might want to protect.
depending on the chip you set a constant named maxpages. the writepage will check the value so it will not erase the next page
#if Loaderchip = 88                                         'Mega88
    $loader = $c00                                          'this address you can find in the datasheet
    'the loader address is the same as the boot vector address
    Const Maxwordbit = 5
    Const Maxpages = 96 - 1                                 ' total WORD pages  available for program
#endif
code from the writepage :
 For J = 1 To 128 Step 2                                  'we write 2 bytes into a page
      Vl = Buf(j) : Vh = Buf(j + 1)                         'get Low and High bytes
      !lds r0, {vl}                                         'store them into r0 and r1 registers
      !lds r1, {vh}
      Spmcrval = 1 : Gosub Do_spm                           'write value into page at word address
      Wrd = Wrd + 2                                         ' word address increases with 2 because LS bit of Z is not used
      If Wrd = Maxword Then                                 ' page is full
          Wrd = 0                                           'Z pointer needs wrd to be 0
          Spmcrval = 5 : Gosub Do_spm                       'write page
          Spmcrval = 17 : Gosub Do_spm                      ' re-enable page
          If Page < Maxpages Then                           'only if we are not erasing the bootspace
             Page = Page + 1                                'next page
             Spmcrval = 3 : Gosub Do_spm                    ' erase  next page
             Portd.7 = 0 : Waitms 200
KenHorse
PostPosted: Thu Dec 10, 2020 8:55 pm    Post subject: Reply with quote
So what's the difference(s) between preventing SPM and/or LPM from "accessing" the bootloader?
