Xmega 256a3u, stepper driver using a rotary encoder
sq2eer
PostPosted: Sun Oct 11, 2020 10:17 pm    Post subject: Xmega 256a3u, stepper driver using a rotary encoder Reply with quote
Hello, I would like to ask for help in writing a program that controls a stepper motor using a rotary encoder.
My Bascom :
Don't forget that Serial numbers should not be sent to the user list.
Make sure you sent your email to support and not a public list !
Compiler version :2.0.8.3
Compiler build :2.0.8.3.005
IDE version :2.0.8.3.003
Serial number Madx-xxxx-xxxxx
Windows OS :Windows 7 Ultimate
Company :
Owner :Jacek
Windows dir :C:\Windows
App data dir :C:\Users\Jacek\AppData\Roaming\MCS Electronics
System dir :C:\Windows\system32
the microcontroller is xmega 256a3u, encoder configuration
Config Pina.3 = Input                                       'enkoder osi Z kanał A
Config Pina.4 = Input                                       'enkoder osi Z kanał B
Config Pina.5 = Input                                       'enkoder osi Z kanał Index
Config Xpin = Porta.3 , Outpull = Totem , Sense = Both
Config Xpin = Porta.4 , Outpull = Totem , Sense = Both
Config Xpin = Porta.5 , Outpull = Totem , Sense = Both
Config Event_system = Dummy , Mux2 = Porta.3 , Qd2 = Enabled , Qdi2 = Enabled , Qdirm2 = 0 , Digflt2 = 8
Config Tcd0 = Normal , Prescale = E2 , Event_source = E2 , Event_action = Capture       'Qdec
connecting a stepper motor to xmega
Config Portb.3 = Output                                     'DIR OŚ Z
Config Xpin = Portb.3 , Outpull = Totem
Config Portb.4 = Output                                     'ENABLE OŚ Z
Config Xpin = Portb.4 , Outpull = Totem
Config Portc.0 = Output                                     'STEP OŚ Z
Config Xpin = Portc.0 , Outpull = Totem
program for capturing impulses from the encoder
'odczyt pokrętła osi Z
$nocompile
Sub Z_os_odczyt
   If Tcd0_cnt <> Z_enkoder_tmp Then                        'jesli zawartosc timera TCD0 jest ró&#380;na od naszej zmiennej to
      Z_enkoder_tmp = Tcd0_cnt                              'przepisz now&#261; warto&#347;&#263; z timera TCD0 do zmiennej enkoder_tmp
      Z_enkoder_tmp_1 = Tcd0_cnt / 4                        '  four inpulses per one step of teh encoder  so wee need only one
      If Z_enkoder_tmp_1 <> Z_enkoder_tmp_2 Then            'Je&#347;li zmienna Enkoder_tmp_1 jest ró&#380;na od zmiennej  Enkoder_tmp_2
         Z_enkoder_tmp_2 = Z_enkoder_tmp_1                  'wstaw warto&#347;&#263; zmiennej Enkoder_tmp_1 do zmiennej Enkoder_tmp_2
End Sub
subroutine call
'''Waitms 500
'''Printbin #dwin , &H5A ; &HA5 ; &H04 ; &H83 ; &H140 ; &H01   '[pl] wyslij zapytanie do LCD  [en] sent request to lcd
'#dwin -[pl] numer portu com deklarowany w w prgramie glownym  [en] com port declared in mian file
'&H5a -[pl] naglowek transmisi 1 [en] transmistion header 1
'&Ha5 -[pl] naglowek transmisi 2 [en] transmistion header 2
'&H04 -[pl] ile bajtow wysylamy  [en] nuber of bytes to sent
'&H83- [pl] komenda odczyt       [en] read commnad
'Dwin_ad- [pl] adres w pamieci wyswietlacza [en] memmory adress
'&H01-[pl] ile zimmeych odczytaj (word) [en] numer of words to read
'[pl] tu odczytujemy tyko jednego worda [en] we are reading only one word here
   Call Rpm_odczyt
   Call Z_os_odczyt
   If Tcf0_intflags.0 = 1 Then
      Flaga10ms = 1
      Incr Timer_tikx10
      Tcf0_intflags.0 = 1
   If Timer_tikx10 >= 10 Then
      Incr Timer_tikx100
      Flaga100ms = 1
      Timer_tikx10 = 0
   If Timer_tikx100 >= 5 Then
      Incr Timer_tikx500
      Flaga500ms = 1
      Timer_tikx100 = 0
   If Timer_tikx500 >= 2 Then
      Incr Timer_tikx1000
      Flaga1s = 1
      Timer_tikx500 = 0
  ' Tcc0_cca = 15942                                         '500Hz
'   Wait 5
'   Tcc0_cca = 1595                                          '5kHz
'   Wait 5
'   Tcc0_cca = 750                                           '10,6kHz
'   Wait 5
'   Tcc0_cca = 375                                           '21,2kHz
'   Wait 5
'    Tcc0_cca = 350                                          '22,7 kHz
'   Wait 5
'   Wait 5
'   Wait 5
'   Wait 5
   If Flaga10ms = 1 Then
      Tcd0_cnt = 0
      Flaga10ms = 0
   If Flaga100ms = 1 Then
      Flaga100ms = 0
   If Flaga500ms = 1 Then
      Toggle Portc.5
      Flaga500ms = 0
   If Flaga1s = 1 Then
      Rpm_a = Rpm_enkoder_tmp_2 / 720
      Rpm_c = Rpm_a * 60
      Rpm_r = Rpm_c
      'Print #4 , "wynik " ; Dwin_var_rx
      'Print #4 , "tab_rx 1 " ; Hex(dwin_arr_rx(1))
      'Print #4 , "tab_rx 2 " ; Hex(dwin_arr_rx(2))
      'Print #4 , "tab_rx 3 " ; Hex(dwin_arr_rx(3))          'ile zmiennych 5 defaultowo!
      'Print #4 , "tab_rx 4 " ; Hex(dwin_arr_rx(4))          'read
      'Print #4 , "tab_rx 5 " ; Hex(dwin_arr_rx(5))          'address_h"
      'Print #4 , "tab_rx 6 " ; Hex(dwin_arr_rx(6))          'address_l
      'Print #4 , "tab_rx 7 " ; Hex(dwin_arr_rx(7))          'ile word odczyta&#263;
      'Print #4 , "tab_rx 8 " ; Hex(dwin_arr_rx(Cool)          'value_h
      'Print #4 , "tab_rx 9 " ; Hex(dwin_arr_rx(9))          'value_l
      'Print #4 , "Obroty " ; Rpm_r
      'Print #4 , "Z_enkoder_tmp_2 " ; Z_enkoder_tmp_2
      'Print #4 , "Z_enkoder_tmp_1 " ; Z_enkoder_tmp_1
      'Print #4 , "Posuw Z lcd " ; Posuw_z_lcd
      'Print #4 , "Posuw X lcd  " ; Posuw_x_lcd
      'Print #4 , "TCC0_CCA Timer Step Z " ; Tcc0_cca
      'Print #4 , "TCD0_CNT Timer Enkoder Z " ; Tcd0_cnt
      'Print #4 , "TCE0_CNT Timer RPM " ; Tce0_cnt
      Posuw_z_lcd = Dwin_lcd_get_var_value(&H140 )          'wstaw do zmiennej warto&#347;&#263; z adresu hex
      If Posuw_z_lcd <> Posuw_z Then                        'je&#347;li zmienna programu jest ró&#380;na od zmiennej z adresu hex
         Posuw_z = Posuw_z_lcd                              'to do zmiennej programu wstaw warto&#347;&#263; zmiennej z adresu hex
         Posuw_z_eeprom = Posuw_z_lcd                       'warto&#347;&#263; zmiennej z adresu hex wstaw do zmiennej do zapisu zmiennej w eeprom
         Posuw_z_tmp_1 = Posuw_z_lcd / 1000
         Print #4 , "NOWY SKOK POSUWU Z " ; Posuw_z_tmp_1
         Writeeeprom Posuw_z_eeprom , 100                   ' zapisz zmienn&#261; w eeprom w komórce
     'Posuw_x_lcd = Dwin_lcd_get_var_value(&H160 )           'odczytaj z adresu hex
      Call Lcd_var_write(&H120 , Rpm_r)
      Tce0_cnt = 0                                          'Zerowanie Timer'a enkodera RPM
      Flaga1s = 0
I wish it would work like in this movie https://www.youtube.com/watch?v=To7S_rLIJwk&t=115s
5min 05sec.
unfortunately I don't know how to do it to make it work best as a subroutine.
sorry for my english but i use google translator
greetings Jacek.
PostPosted: Tue Oct 13, 2020 9:54 am    Post subject: Reply with quote
The video explains it quite well, however the stepper functionality is encapsulated within a lib called 'AccelStepper', this functionality you have to implement yourself.
For this purpose I suggest to use a timer interrupt, to compare actual with set position and put out step/en/dir.
Code for stepper control is short and can be placed directly into the interrupt service routine.
Motor speed can be controlled by TOP of timer (in combination with config timer CLEAR_TIMER), alternatively a soft timer, as you've tried to implement, is thinkable.
Controlling the interrupt speed itself will be likely faster, will eat up less power and run smoother than creating an 1/00s timer value and updating steppers in the main loop.
One more (power hungry) way is a fast timer interrupt, wherein a soft timer works, speed is controlled via this soft timer and stepper is updated also from therein, this would be the approach if more steppers need to be taken care of. Speed of the timer decides then over max speed of the motors.
The whole thing will become a bit more complicated if you want to have acceleration ramps, however for this simple experiment with one motor you can likely omit ramps and control directly via timer ISR.
PostPosted: Tue Oct 13, 2020 11:17 am    Post subject: Reply with quote
Cause me and Jacek we are from Poland then we know each other from polish forums.
Jacek`s goal was to use Xmegas bulit in hardware quadrature encoders decoding with using event system.
This gives result in the 16bit timer/counter 0-65535.
Jacek want to control motor with the encoder into the left, stop and right manually for test Very Happy
This is not very complicated when first turn it right because value grow from zero->65535. Difference always can be measured by substract prev value from actual. But when first turn is into the left or we overflow timer turning encoder backward then from 0 we got 65535. This was some challenge Very Happy
So yesterday, after quick scratch my head I came with this simple solution (for test only, without any interrupts).
 Dim Encoder_tmp As Word , Encoder_prev As Word ,  Steps As Integer
       Encoder_tmp = Tcd0_cnt
       If Encoder_prev <> Encoder_tmp Then
             Select Case Encoder_prev
               Case 0
                If Encoder_tmp = 1 Then Incr Steps Else Decr Steps
               Case Else
                Select Case Encoder_tmp
                 Case Is < Encoder_prev : Decr Steps
                 Case Is > Encoder_prev : Incr Steps
                End Select
              End Select
        Encoder_prev = Encoder_tmp
          Print #buart_channel , Steps
'------------------------------------[every 1ms only for some step execute]---
       If 1ms = 1 Then
        1ms = 0
          If Motor_step_pin = 1 Then
           Reset Motor_step_pin
          Else
             Select Case Steps
              Case Is < 0
               Incr Steps
                Call Set_direction_l
               Set Motor_step_pin
              Case Is > 0
               Decr Steps
                Call Set_direction_r
               Set Motor_step_pin
             End Select
This is the first think. Maybe this can be recognized better? Very Happy
There is a DIR bit in the TCD0_CTRLFCLR that maybe I must study and can be helpful here. I dont know yet.
The ramp for speed should not be dificult.
After all yesterday motor works like a slave for the encoder Very Happy but maybe someone have better solution Wink
sq2eer
PostPosted: Tue Oct 13, 2020 8:42 pm    Post subject: Reply with quote
Hello everyone, this is a test control of the Z axis from the lathe in manual mode. The video shows how nicely the motor reacts to turning the encoder https://www.youtube.com/watch?v=uV2L4_Cck_I then I had not yet set the timer division by four (four edges of channels a and b) so the motor did four times as many revolutions as the encoder at the end of the movie, I exaggerated with shooting and a driver error popped up now, when I give thanks, the reading from the encoder for four is very good and all thanks to Bartek EDC, I greet everyone Jacek.
PostPosted: Wed Oct 14, 2020 1:56 pm    Post subject: Reply with quote
Most lathe have no Z-axis, as then they would be called 'mill'. I assume you mean X-axis (horizontal feed)?!
The trick is to be as fast as the encoder (which is given and handled internally by the XMega), while not pushing pulses out faster than the driver hardware can handle. Your sample code shows this flaw, it lacks a mechanism to respect maximum specs of the driver.
As the goal is an electronic gearbox, I do not expect an elevated challenge for speed and change of direction, so this code may work well for its purpose.
But on the other hand you will not be happy, if you just cut a thread on the lathe and the horizontal feed suddenly stalls, because the hardware-driver shuts down with an error.
hgrueneis
PostPosted: Fri Oct 16, 2020 4:02 pm    Post subject: Reply with quote
Just my input on ramps for steppers. I usually use a percentage calculation of the Distance to be accomplished with max. acceleration and start out frequency as limits. This works quite well and does not need a "FUZZY License". Could also be implemented with rotary sensor.
Best regards
Hubert
sq2eer
PostPosted: Fri Oct 16, 2020 9:08 pm    Post subject: Reply with quote
Hello
MWS - we have such a coordinate system in lathes
as EDC wrote earlier this is a test program and needs some fine-tuning.
hgrueneis - can you explain it with some example.
Regards Jacek.
PostPosted: Sat Oct 17, 2020 6:50 am    Post subject: Reply with quote
In my coordinate system, Z is the vertical axis.
