Alexander-Dan
Posted: Fri Sep 11, 2020 8:30 am Post subject: an array of values "word" |
hi!
Help me read the 1 record "word" from the array.
I only need to read 1 record, but my program reads two records at the same time.
Dim W1 As Word
Dim temp As Byte
Restore Tab
For Temp = 0 To 51
Read W1
Print W1 ; ", ";
Tab:
Data 2248 , 2446 , 2641 , 2830 , 3011 , 3184 , 3345 , 3494 , 3629 , 3748 , 3852 , 3938 , 4005 ,
Data 4054 , 4084 , 4094 , 4084 , 4055 , 4006 , 3939 , 3853 , 3750 , 3631 , 3496 , 3348 , 3186 , 3014 , 2833 , 2644 ,
Data 2449 , 2251 , 2050 , 1850 , 1651 , 1456 , 1267 , 1085 , 913 , 751 , 602 , 467 , 347 , 244 , 158 , 89 ,
Data 40 , 10 , 0 , 9 , 38 , 87 , 154 , 239 , 342 , 461 , 596 , 744 , 905 , 1077 , 1258 , 1447 ,
Data 1641 , 1840 , 2040 '
The terminal gives me this data.
that is, the program reads two records at once in the array and puts both records in one variable.
38600, 6225, 31683, 45841, 45613, 28940, 58789, 3572, 59124, 29350, 46349, 46639, 32532, 7366, 39764, 2763, 31290, 63664, 38205, 23791, 23763, 40692, 10329, 10, 9737, 39511, 22255, 21965, 35816, 60981, 28327, 65328, 11918, 11935, 38152, 11752, 11769, 38152, 59040, 57525, 37261, 9096, 61457, 53260, 53243, 38152, 37902, 263, 11648, 61457, 53253, 53242,
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.3 )
Last edited by Alexander-Dan on Sat Sep 12, 2020 5:03 pm; edited 1 time in total |
laborratte
Posted: Fri Sep 11, 2020 10:30 am Post subject: |
From Help:
Integer and Word constants must end with the %-sign.
So use
Code: | Tab:
Data 2248% , 2446% , 2641% , 2830% , 3011% 'etc.
| [/quote] |
Posted: Fri Sep 11, 2020 10:33 am Post subject: |
Quote: | wasted a lot of time due to the peculiarities of the compiler. |
Just read the help for DATA. And/or look at the sample.
But to blame the user ignorance and laziness of not consulting/reading the help on the compiler is a shame.
I hope this was just a quote and not your own writing.
The time i wasted in my life on users that never read a thing and then contact support is not to count in hours but years.
Also, if you post for other users here, make sure they have a license. And tell them to read the help. google translate can do a great job.
edit note : i see that after i posted, laborratte was before me. So my reply was for the original poster.[/quote] _________________ Mark
Posted: Fri Sep 11, 2020 10:34 am Post subject: |
According the help file:
Quote: | Integer and Word constants must end with the %-sign.
Long and Dword constants must end with the &-sign.
Single constants must end with the !-sign.
Double constants must end with the #-sign. |
you must add % at the data word
Tab:
Data 2248% , 2446% , 2641% , 2830% , 3011% , 3184% , 3345% , 3494% , 3629% , 3748% , 3852% , 3938% , 4005% ,
i prefer use lookup than read
Dim W1 As Word
Dim Tbyte As Byte
Restore Tab
For Tbyte = 0 To 5
' Read W1
W1 = Lookup(tbyte , Tab)
Print W1 ;
Print " tbyte: " ; Tbyte;
Print " ";
Tab:
' Data 4054 , 4084 , 4094 , 4084 , 4055 , 4006 , 3939 , 3853 , 3750 , 3631 , 3496 , 3348 , 3186 , 3014 , 2833 , 2644 ,
' Data 2449 , 2251 , 2050 , 1850 , 1651 , 1456 , 1267 , 1085 , 913 , 751 , 602 , 467 , 347 , 244 , 158 , 89 ,
' Data 40 , 10 , 0 , 9 , 38 , 87 , 154 , 239 , 342 , 461 , 596 , 744 , 905 , 1077 , 1258 , 1447 ,
' Data 1641 , 1840 , 2040
it works with simulator
Alexander-Dan
Posted: Fri Sep 11, 2020 2:05 pm Post subject: |
believe me, I've written too many BASIC programs. Therefore, it did not occur to me that the data needed to be additionally marked somehow.
And to be honest, I read the help, but I didn't find it.
On top of that, English is not my first language ...
sorry, I didn't mean to offend anyone ... |
Posted: Fri Sep 11, 2020 8:32 pm Post subject: |
both DATA and READ have a sample that show that DATA requires type info.
that you dont read it ok, but when something does not work and you still do not read it, and then blame it on the software, that is not ok.
this data/read/restore is there since 1995 or so. i have seen your amazing projects so i can almost not believe you did not knew about it.
so why does DATA need type info? when you have a PC you can store data with lot of bytes. but storing type info inside the data uses data which is precious on a small micro.
so only the actual data is stored. now if you have a value of 123, how should the compiler know that this is a byte? or a word, or dword, integer, etc. ?
it could figure out that the data would fit into a byte and then just store the byte. but what if you have 123, 1024, that would not work, and requires 3 bytes. these bytes are not aligned anymore.
And then nice routines like lookup() would not work any more. and also code that read data in a loop would not work.
ok, we could store run type info in the data but that would also complicate code like lookup() and even worse it would be slow. Now it is very fast because it can index.
anyway you best check out read/data/restore, lookup, lookupstr, lookdown _________________ Mark |
Alexander-Dan
Posted: Sat Sep 12, 2020 11:42 am Post subject: |
albertsm wrote: | i have seen your amazing projects so i can almost not believe you did not knew about it. |
thank. That's right, for all the decades I have never used Data of type "word" in your compiler
Yes, I have not met the requirements for marking the parameters of the data block anywhere in other compilers. I worked with different computers (ZX-Spectrum, IBM, Soviet computers...) and compilers, but there was no such need.
albertsm wrote: | so only the actual data is stored. now if you have a value of 123, how should the compiler know that this is a byte? or a word, or dword, integer, etc. ? |
yes, this is a logical decision. I completely agree with you.
albertsm wrote: | I hope this was just a quote and not your own writing. |
this is a poorly translated phrase,
I wrote the text, translated it in the translate.google and sent it, but I did not check the quality of the translation.
This phrase from a book for beginner programmers. The author is Hungarian or Pole, I do not remember.
Completely this phrase sounds like this: (I specifically checked the translation several times. The meaning of the phrase is now translated correctly):
"Having received a new compiler, my old experience of work with past compilers made me make stupid mistakes and wasted time learning new things." |
Posted: Sat Sep 12, 2020 2:34 pm Post subject: |
like you I am very unhappy with my poor English, I use Deepl as a translator, I find it much better than google
Как и ты, я очень недоволен своим бедным английским, я использую "Deepl" в качестве переводчика, я нахожу это намного лучше, чем "Google".
I hope Deepl do a good translation  _________________ pleasure to learn, to teach, to create |
Alexander-Dan
