ADC1 & xtiny (ATTINY3217)
Skrivo
PostPosted: Fri Aug 14, 2020 10:43 am    Post subject: ADC1 & xtiny (ATTINY3217) Reply with quote
ATtiny3217 has 2 ADCs (ADC0 and ADC1). In xtiny Bascom "Config ADC0" works and "Config ADC1" is not even recognized. How can I now configure ADC1 (I need to read voltage on pin 19 (ADC1/AIN8))?
"Getadc (n)" command now gives ADC0 value where "n" is from 0 to 11 (mux position). What is the syntax to read from desired pin 19 with ADC1?
P.S. "Getadc (100)" also compiles with no errors reported....I suppose this is not right isn't it?
PostPosted: Fri Aug 14, 2020 10:52 am    Post subject: Reply with quote
you need to wait for the update. the first release only covers the hardware found in xtiny816.
multiple devices are not supported.
like i wrote on the add on page 'you can expect some updates'.
but the good news is that there will be an update for the add on in a few days.
Skrivo
PostPosted: Fri Aug 14, 2020 12:32 pm    Post subject: Reply with quote
I see....ATtiny816 only has ADC0...
I won't dig into registers to run ADC1 as this eats way too much time, I will rather manage other things while waiting for the update Cool
PostPosted: Fri Aug 14, 2020 7:53 pm    Post subject: Reply with quote
i got a long way in the mean time.
At the moment the dat files are updated.
And after that the help need to be updated for the timers. then its ready.
if you need it urgent you can write to support (make sure your email is the same as the one used for registration) and you get a beta when ready.
Skrivo
PostPosted: Fri Aug 14, 2020 8:05 pm    Post subject: Reply with quote
Mark, thank you for great support. I have quite some work to do in the meantime. If I will be done before you release the update, then I will ask for beta, otherwise I will wait for the tested update.
