Problem compiling with extensive comment block at the beginn
Zitronenfalter
PostPosted: Mon Aug 03, 2020 8:39 am    Post subject: Problem compiling with extensive comment block at the beginn Reply with quote
If there is an extensive comment block at the beginning of a program (about 500 lines and more no matter what length), the compiler "stumbles" and brings error messages.
If you set the declaration "$regfile = ..." as the first line, the compilation works without errors.
With BasCom version 2.0.8.2 this problem does not occur.
PostPosted: Mon Aug 03, 2020 8:57 am    Post subject: Reply with quote
for me it works ok. but it depend on your settings.
the best you can do is make a copy of the 2082 settings.
you can do that with : Options, Select Settings file
this allows to make a copy of the 2082 settings file and then use that.
the actual setting is : options, einvironment, IDE, use new method.
This is a recommended setting.
unchecked it will use a simple method to check the source for the regfile. it is way faster but it does not allow #if constructions.
it is faster since it uses a simple parser and also only checks the start of your source. and that is the problem too : when you use a lot of text before the $regfile it will fail.
For this reason the new method was added. i guess it was checked in 2082 and not in the 2083.
Zitronenfalter
PostPosted: Mon Aug 03, 2020 9:45 am    Post subject: Reply with quote
Thanks, the new setting parameter works fine.
The idea that this is just a configuration problem I would never have thought of.
