MAX31856 from -210 °C to 1800 °C step 0,0078125 °C.
PostPosted: Wed Jul 15, 2020 12:00 pm    Post subject: MAX31856 from -210 °C to 1800 °C step 0,0078125 °C. Reply with quote
Hello. I made this some time ago but wait to be tested.
This sensor need 200ms to finish the reading after start conversion so like with DS18B20 (750ms) you can make lazy code that wait for the result or fire it first, do some stuff in the meantime, then back for the result. Its your choice.
I attach semi lazy example because I fire "Start measure", then wait 200ms, then "Read result" with functions that not wait for anyting and they should be handled by some timer or so. But in the "library" routines you can find functions that fired once wait for the result (that hold your program for 200ms).
Some info from "info.txt":
You can choose between three types of SPI: Hard, Soft and Shiftin/Shiftout
Choose must be taken i the "MAX31856_routines.inc" file by setting Const Spi_mode
0 - is for Shiftin/Shiftout. It gives you possibility to use any pin.
1 - is for hardware SPI. You should connect to MOSI(SDI), MISO(SDO), SCK(CLK) and optionally CS pins,
that are dedicated for it in your micro.
2 - is for software SPI and you also can connect/choose any pin for it BUT ONLY! if you not use
hardware SPI on your project (hard and soft SPI`s can`t be configured both together for one micro)
PostPosted: Wed Jul 15, 2020 1:49 pm    Post subject: Reply with quote
hi EDC
excellent ! Thanks for sharing.
I like the fact that you support various ways like shift, soft and hard spi. And that you can simply include it.
A nice package complete with PDF Very Happy
PostPosted: Wed Jul 15, 2020 6:22 pm    Post subject: Reply with quote
Hi EDC
Nice work !
Reading a temperature is not easy.
Whatever the sensor is, it is necessary to think that a sensor must be warmed up before asking it to give a result.
It is also necessary to be wary of the environment: infra-red radiation, draught etc... which can interfere and distort the reading. I had a lot of difficulties with sensors of the thermocouple and pt100 probe type.
I see you are also looking for the "right values".
Wink
JP
mediumdavari
PostPosted: Sun Jul 19, 2020 8:01 am    Post subject: Reply with quote
Hi Pro man
great job thanks for sharing this code
