Posted: Tue Jul 14, 2020 12:36 pm Post subject: Power Factor calculator
In AC circuits it is necessary to measure power factor to determine
actual power being used, its normally complicated thing to do.
But there is a old way with meters , resistor and pencil and paper
with help from a calculator to save paper.
Note resistor value only needs to be large enough to get a reasonable reading
its value is not used.
So I thought why not use an AVR even bascom simulator.
I will put together a circuit with an AVR when I get time.
Regards Paul
this is a diagram:
This code provides the power factor from measurements
Cos_phi is the answer
$regfile="m1284pdef.dat"' specify the used micro
Const Xtal =20000000'use constant for baud rate
$crystal= Xtal ' used crystal frequency $baud=9600' use baud rate $hwstack=100 $swstack=100 $framesize=150
Dim Cos_phi AsSingle Dim U1 AsSingle Dim U2 AsSingle Dim U3 AsSingle Dim A1 AsSingle Dim A2 AsSingle Dim A3 AsSingle Dim A4 AsSingle
