ATtiny45 reset
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
atmega64
PostPosted: Tue Jun 30, 2020 8:25 am    Post subject: ATtiny45 reset Reply with quote
it's the first time I use a micro from the ATtiny family ...
I have an ATtiny45, is a 8.2k resistor between the RESET and VCC ok for the reset?
six1
PostPosted: Tue Jun 30, 2020 9:40 am    Post subject: Reply with quote
question has already been answered...
https://bascomforum.de/index.php?thread/2056-attiny45-reset/&postID=33672#post33672
For technical reasons, the signature is on the back of this message.
PostPosted: Tue Jun 30, 2020 10:19 am    Post subject: Reply with quote
hi,
what I'm about to say will startle MWS. Laughing
For years I've been leaving the AVR reset pin unconnected.
I avoid using it except for spi programming and never as an input to avoid unwanted resets.
For Attiny it removes 1 pin as input but this pin can still be used as output or ADC reader.
JP
Wink
atmega64
PostPosted: Tue Jun 30, 2020 10:59 am    Post subject: Reply with quote
I have to generate a 38KHz PWM without using an external clock ...
I managed to set the clock to 8MHz but maximum arrival at 35KHz ...
how can i solve?
atmega64
PostPosted: Tue Jun 30, 2020 1:07 pm    Post subject: Reply with quote
I have to pilot an IR emitter at 38kHz so what do you recommend?
PostPosted: Tue Jun 30, 2020 3:04 pm    Post subject: Reply with quote
for a T85 I use
programmed with Mysmart USB lignt ISP program
to do that : add this line after the end
$prog &HFC , &HE2 , &HDF , &HFF ' generated. Take care that the chip supports all fuse bytes.
for the pwm, I think you must search in the forum
but the pin for pwm is not the reset one Wink
You have fast pwm possibilities with Tiny : see the datasheet
timer are only 8bits
JP
PostPosted: Tue Jun 30, 2020 3:44 pm    Post subject: Reply with quote
for your IR emitter
did you look at GETRC5 function ?
Wink
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
