COMPARATIVE OPERATORS_ARDUINO UNO
Printpix52
PostPosted: Wed Jun 10, 2020 11:00 pm    Post subject: COMPARATIVE OPERATORS_ARDUINO UNO Reply with quote
Hi!!!
I am trying to perform operations inside the Arduino Uno for example:
Comparisons between 2 data A and B and result C by means of serial monitor 1 or 0, true or false.
all works fine as (<, <=, =,>,> =) works fine.
instead this (<>) I get an error why?
I have read with help at bascom to learn and practice.
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Dim A As Byte
Dim B As Byte
Dim C As Byte
A = 100
B = 100
C = A <> B
 Print C
 Waitms 1000
It's wrong?
    Error : 93 Line : 37 Variable not dimensioned [A <> B] , in File : C:\Users\Bienvenido\Desktop\Proyecto_ Bascom_Arduino_ 2020\TIMER\Prueba.bas
Question Question Question Question Question
I am looking forward to your response.
JC
PostPosted: Thu Jun 11, 2020 2:41 am    Post subject: Reply with quote
C = A <> B
That puts two operators on the same line, which will confuse the compiler.
One approach would be:
If A <> B then
  C = 1
Else
  C = 0
JC
Printpix52
PostPosted: Thu Jun 11, 2020 5:37 am    Post subject: Reply with quote
Hi JC !!
Brilliant!! I was going to do this but I already understood and thank you very much JC !!!!!
O-Family
PostPosted: Thu Jun 11, 2020 8:23 am    Post subject: Reply with quote
C = A = B
C = A > B
These arithmetic expressions put True[1] or False[0] of the calculation result in the variable C.
C = A <> B
The above is probably a BASCOM oversight or bug.
However, as JC says, it is possible to directly judge True or False by the IF statement, so the situation where this operator is used is limited.
Printpix52
PostPosted: Thu Jun 11, 2020 6:22 pm    Post subject: Reply with quote
C = A <> B
You have to work but I don't know how strange I get Bascom error
O-Family
PostPosted: Fri Jun 12, 2020 12:49 am    Post subject: Reply with quote
To resolve this issue, please contact MCS Support and ask Mark to update!
enniom
PostPosted: Fri Jun 12, 2020 1:15 am    Post subject: Reply with quote
Dim A As Byte , B As Byte , C As Byte
A = B = C
A = Not A.0
e
Printpix52
PostPosted: Fri Jun 12, 2020 5:29 am    Post subject: Reply with quote
Yes and thank you very much !!!
Printpix52
PostPosted: Fri Jun 12, 2020 6:24 am    Post subject: Reply with quote
A = B = C
A = Not A.0
e
Very easy!!! I'm already learning!!!
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 9600
Config Pinb.5 = Output
Led_5 Alias Portb.5
Config Pind.2 = Output
Led_2 Alias Portd.2
Config Pind.3 = Output
Led_3 Alias Portd.3
Dim A As Byte : Dim B As Byte : Dim C As Byte
A = B = C
A.0 = Led_5
A.0 = 1
A = Not A.0
   If A = 1 Then
    Print "Led_5_ON,Led_2_ON,Led_3_ON"
    Waitms 1000
    Set Led_5
    Set Led_2
    Set Led_3
    Else
    A = 0
    Print "Led_5_OFF,Led_2_OFF,Led_3_OFF"
    Waitms 1000
    Reset Led_5
    Reset Led_2
    Reset Led_3
Printpix52
PostPosted: Thu Jul 16, 2020 7:00 pm    Post subject: Re: COMPARATIVE OPERATORS_ARDUINO UNO Reply with quote
Printpix52 wrote:
Hi!!!
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Dim A As Byte
Dim B As Byte
Dim C As Byte
A = 100
B = 100
C = A <> B
 Print C
 Waitms 1000
It's wrong?
With my new update to 2.0.8.3 it works fine !!! Very Happy
olhexy
PostPosted: Sat Jul 18, 2020 7:51 am    Post subject: Reply with quote
A = B = C
A = Not A.0
e
A= Not A.0 ( A is not A dot zero)
What is de exact meaning of that dot (".") ????
EDIT:
I think I found it.
It is hard to find in the Help, but I got a hint at Set, Reset.
This is how I understand it:
A.0 means bit nr 0 of A.
A can be a byte or word.
The bit nr can be 0, 1, ..., 6, 7 in a byte, or 0, 1, ..., 14, 15 in a word.
