njepsen
Posted: Tue Apr 21, 2020 7:21 am Post subject: Possible bug with endif / end if |
I was looking at some code today, and noticed that one of my functions did not appear in the code explorer function list. Some testing revealed a typo in the 1st function, which did not cause a compile error. I'm not sure if there were any other problems. The code is several thousand lines long, but I wrote a short test program that demonstrates the issue.
This compiles OK, and both functions appear in the code explorer list.
Code: | $regfile = "m1284pdef.dat"
$crystal = 9830400
$framesize = 500
$hwstack = 500
$swstack = 500
dim x as byte
dim y as byte
dim z as byte
declare function testone() as string
declare function testtwo() as string
x = testone()
y = testtwo()
if z =1 then
'do nothing
end if
end function
if z= 2 then
'do nothing
end if
end function |
On the other hand, this typo does compile OK also, BUT the second function is now missing from the code explorer list. There are several output changes also which led me to finding the typo.
$crystal = 9830400
$framesize = 500
$hwstack = 500
$swstack = 500
dim x as byte
dim y as byte
dim z as byte
x = testone()
y = testtwo()
if z =1 then
'do nothing
endif 'THIS IS THE TYPO THAT CAUSED THE ISSUE
end function
if z= 2 then
'do nothing
end if
end function
(BASCOM-AVR version : 2.0.8.2 ) _________________ Neil |
Posted: Tue Apr 21, 2020 8:37 am Post subject: |
you best use the Code Explorer to check your code.
you probably did not read what was written about Code Explorer : it uses a different new parser to check code. it is independent of the compiler. (at the moment of writing).
the compiler is forgiving : it will assume things, but that is not convenient in all cases.
in case of endif it will change that during compiling into end if.
when you turn on 'format code' the 'endif' will be changed to 'end if' automatic.
your function return a string. the compiler will happy transform that to a byte you assign, but it is not really good practice. _________________ Mark |
njepsen
Posted: Tue Apr 21, 2020 8:42 am Post subject: |
Thsnks Mark. Im not at work now; what hapoens to #endif ? I assume that remains unchanged? _________________ Neil |
Posted: Tue Apr 21, 2020 9:02 am Post subject: |
#endif remains as it is. and is something totally different. _________________ Mark |
njepsen
Posted: Wed Apr 22, 2020 11:14 pm Post subject: |
Thanks Mark. that has been a big help. I DID read the forum discussions on errors in code explorer but errors was turned off and I hadn't got into the habit of looking.
It has enabled me to find a number of error such as a couple of "exit sub" inside a function, and declaring a string var in a function decl, then using a byte var inside the function !!.
These were not picked up by the assembler.
However I have one error in code explorer which has me beat, and I attach the relevant code here:
$crystal = 9830400
$framesize = 800
$hwstack = 550 '
$swstack = 550
$frameprotect = 1
config submode = old
$include "config_mmcsd_hc.bas"
$include "config_AVR-DOS.BAS"
$PROG &HFF , &HC7 , &HD0 , &HFD
Declare Function Cleanupstring(byval Sourcestring As String) As String
Declare Function Davis_wind_direction() As String
Declare Function Davis_wind_speed() As String
declare function find_bootloader() as string
Declare Function Get_rssi() As String
Declare Function Getmeterresponse(byval metercommandstr As String) As String
declare function mic_check() as string
Declare Function Mypi_battery_soc() As Single
Declare Function Noise_profile(byval Parameterstr As String) As String
Declare Function pi_response(byval picommandstr As string) As string '<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Code explorer doesnt like this
declare Function quick_sd_card_check() As Byte
Declare Function Send_http_head(byval Serveraddr As String) As String
Declare function TCP_connect(byval Myserver As String * 50 , byval Myport As Integer) as byte
declare function verify_SLMtime(byval slmtime as string) as string
Declare Function Verify_time(byval Responsestr As String) As String
Declare function Waitfortelitresponses_sec(byval Respstr As String * 30 , byval Resptimeoutb As Byte) as byte
Declare Function Waituntil(byval Respstr1 As String , byval Respstr2 As String , byval Abortstr As String , byval Resptimeoutb As Byte) As String
Declare Function Whoru() As String
Declare Sub Append_dummynoise()
Function pi_response(picommandstr As String) As String
Local Q As Byte 'number of char received
Local Tempstr7 As String * 100
Local Td As Long
#if Pi_fitted = 1
This function runs a command and returns the response to the caller
******* VALID PI COMMANDS *********
upload,1 pi free to send audio files to the server
upload,0 inhibit uploads to server
status? get status. bloody slow response from pi
shutdown tell pi to shutdown in an orderly manner. takes 30s
pitakeboth take camera image + audio recording
ssh,0
ssh,1
ppp,0
ppp,1
startrecord,xx start a recording xx seconds long
stoprecord
bitrate,nn nn = 8,12,16,24,
register,phonenumber in format "%2b64275404773"
Philips terminators:
after all echos $$ <CR>
after all data ## <CR>
Tempstr7 = ""
Td = Local_secl + 10 '10 secs
If picommandstr <> "" Then
Print #7 , picommandstr 'send cmd to pi ser port
Rxbyte = Inkey(#8) '#8 is pi sw uart ser port
If Rxbyte <> 0 Then
Tempstr7 = Tempstr7 + Chr(rxbyte)
Loop Until rxbyte = 35 or Local_secl >= Td ' 35 = # expected terminator
Delchars Tempstr7 , 32 'remove spaces
If Tempstr7 <> "" Then
Print #1 , ">> Pi said:" ; Tempstr7
Print #1 , ">> no response from pi"
Tempstr7 = "no response from pi"
pi_response = Tempstr7 'return the response
end if
#endif
End Function
The code explorer complains about the declaration arrowed, and says "parameter not same as declared .... line 382 posn 30." This is the ONLY error that code explorer finds, and the program compiles and runs correctly. There are 15 other functions all with the same pi_ prefix to the name, but changing the name (or the parameter) to something else doesn't remove the error./quote] _________________ Neil |
Posted: Thu Apr 23, 2020 6:37 am Post subject: |
What happens if the byval is added to the function itself? |
njepsen
Posted: Thu Apr 23, 2020 7:37 am Post subject: |
ahhhhhh that made the problem go away. If I could, I'd buy you a beer. Thanks MWS. _________________ Neil |
Posted: Fri Apr 24, 2020 12:45 am Post subject: |
That would be a far traveling beer
But thanks for the offer. |
