Representing ports numerically?
teccs
PostPosted: Wed Apr 08, 2020 7:05 pm    Post subject: Representing ports numerically? Reply with quote
In my code, I receive a number via serial port. Based on that number the code will turn a port on or off. For example, if 1 is received, turn port G.1 off. If 2 is received, turn port G.1 on.
I have to handle about 30 ports like the above with different numbers coming from the serial port to tell what port to do what with.
My current method to handle this is using a SELECT CASE statement with about 60 cases.
Is there any way to handle this numerically or with an array()?
It would clean up the code a bunch if I could get rid of the huge SELECT CASE setup.
Thank you!
Tim.
PostPosted: Wed Apr 08, 2020 7:10 pm    Post subject: Reply with quote
that can only be done when there is some logic to the system.
for example, all even numbers do something and all odd numbers do something else.
then it depends on the processor used if it can be done simple or not. unfortunately normal AVR processors do not have a logic to the port numbering. Xmega do have.
so as always, you need to show processor and some code in order somebody can help you.
teccs
PostPosted: Wed Apr 08, 2020 7:23 pm    Post subject: Processor is ATMEGA 2560 Reply with quote
Thank you for the reply.
I can use any numbering scheme or logic that would work well.
Code is below.
DO
  FOR X = 0 to 7
    Call ReadADC(X)
    ADCValue(X) = ADCCount
  NEXT
  A = Ischarwaiting(#2)
LOOP UNTIL A = 1
INPUT #2, InstructionReceived   'Get Instruction from PC.
WaitMS 500
SELECT CASE B
  CASE = 1
    PORTG.0 = 0
  CASE = 2
    PORTG.0 = 1
'... That example would be continued below with other ports.
  CASE = 3
  CASE = 4
  CASE = 5
  CASE = 6
  CASE = 7
  CASE = 8
  CASE = 9
  CASE = 11
  CASE = 12
  CASE = 13
  CASE = 14
  CASE = 15
  CASE = 16
  CASE = 17
  CASE = 18
  CASE = 19
  CASE = 21
  CASE = 22
  CASE = 23
  CASE = 24
  CASE = 25
  CASE = 26
  CASE = 27
  CASE = 28
  CASE = 29
  CASE = 31
  CASE = 32
  CASE = 33
  CASE = 34
  CASE = 35
  CASE = 36
  CASE = 37
  CASE = 38
  CASE = 39
  CASE = 40
  CASE = 41
  CASE = 42
  CASE = 43
  CASE = 111
  CASE = 112
  CASE = 113
  CASE = 114
  CASE = 115
  CASE = 116
  CASE = 117
  CASE = 118
  CASE = 119
  CASE = 121
  CASE = 122
  CASE = 123
  CASE = 124
  CASE = 125
  CASE = 126
  CASE = 127
  CASE = 128
  CASE = 129
  CASE = 131
  CASE = 132
  CASE = 133
  CASE = 134
  CASE = 135
  CASE = 136
  CASE = 137
  CASE = 138
  CASE = 139
  CASE = 140
  CASE = 141
END SELECT
PostPosted: Wed Apr 08, 2020 7:42 pm    Post subject: Reply with quote
if you are free to use anything you can consider the following : let the on/off be part of the number. meaning that even numbers means off. and odd numbers mean ON.
but you can also encode things. for example you need 1 bit to turn on/off. then you have port A,B,C,D,E,F,G which are 7 ports. meaning that you need 3 bits to specify the port.
and you have 8 bits which mean you need 3 bits again. thus using 7 bits you can set everything.
0xxx Z yyy
xxx=0- porta, 1-portb etc
yyy=0 bit 0, 7-bit 7
z=0 is off, 1=on
you can work that out on the sending side.
then on the decode :
bState=B.3 ' get state where B is the coded byte, bstate will be on/off
index=b and 7 'get index
prt= b and &HF0
swap prt 'get the port number
select case prt
case 0 : portA.index=bstate
case 1 : portB ....
that is it.
it might have some errors since i did not test and wrote it down. but it is simple to test in the sim.
teccs
PostPosted: Wed Apr 08, 2020 9:36 pm    Post subject: Thanks Albert. Reply with quote
I will give this a try.
