Problems with Print and Bytematch
Goto page Previous  1, 2
PostPosted: Sat Mar 14, 2020 11:25 am    Post subject: Reply with quote
Duval JP wrote:
I realized that if I didn't make small poses (50ms) between the displays one of the four results was not displayed correctly,
If one knows the flaw, one sends display data in single chunks, a timer-tick driven state machine can also handle this without need for using waitms.
My message was about having everything in a flow, leave out any waits and do everything continuously, not that stuttering like run - wait - run - wait.
Compare good code with a chime clock, at each quarter a chime is triggered, but the watch moves on and does not execute a wait-state till the chiming has finished.
Paulvk
PostPosted: Sun Mar 15, 2020 1:28 am    Post subject: Reply with quote
JP
if you put bauds=2400 in the first page’s Preinitialization Event
the baud rate will go to 2400 giving the display more time to react
Valid values are: 2400, 4800, 9600, 19200, 31250, 38400, 57600, and 115200, 230400, 250000, 256000, 512000, and 921600
Note I do not seem to be having problems but you are putting about two times as much
Regards Paul
Page 2 of 2
