atmega64
Posted: Fri Mar 06, 2020 4:01 pm Post subject: Bug BASCOM AVR 2.0.8.2 version? |
why does the following code work only with BASCOM version 2.0.8.1 and not with version 2.0.8.2?
Code: |
$regfile = "m1284def.dat"
$crystal = 16000000
$baud = 19200
Config Portb.4 = Output 'BUZZER
Buzzer Alias Portb.4
Declare Sub Bip
On Urxc Rxcom1_isr
Enable Urxc
Open "COM1:" For Binary As #1 'open channel
Dim Rxdata1$ As String * 254 , Rxcmd As String * 254 , Id As String * 2
Dim Comchar1 As Byte
Dim Rxdata1 As Bit
'ID DEVICE
Id = "06"
Reset Rxdata1
Rxdata1$ = ""
Bip
If Rxdata1 = 1 Then
Reset Rxdata1
If Left(rxdata1$ , 1 ) = "[" And Right(rxdata1$ , 1 ) = "]" And Len(rxdata1$) > 5 Then 'comando corretto
If Id = Mid(rxdata1$ , 2 , 2) Then
'Rxcmd = Mid(rxdata1$ , 4 , 2)
Select Case Mid(rxdata1$ , 4 , 2)
Case "GM" : Bip
Waitms 500
Print "OK GM";
Case "GS" : Bip
Waitms 500
Print "OK GS";
Case "SM" : Bip
Waitms 500
Print "OK SM";
End Select
Rxdata1$ = ""
Rxcom1_isr:
Comchar1 = Inkey()
Rxdata1$ = Rxdata1$ + Chr(comchar1)
If Comchar1 = 93 Then '] the closed square bracket ends command reading
Set Rxdata1
Sub Bip
Buzzer = 0
Waitms 20
Buzzer = 1
End Sub
End |
While if I modify the code as follows, it works with both versions
Code: | Rxcmd = Mid(rxdata1$ , 4 , 2)
Select Case Rxcmd |
(BASCOM-AVR version : 2.0.8.2 ) |
Posted: Fri Mar 06, 2020 9:48 pm Post subject: |
According to help, 'select case' expects a var and not another function. Thus it is not guaranteed that it works with a newer version, even it works with an older one.
Second, declarations for stack and frame are missing in the shown code. In such case the IDE's values are used, which may differ between the versions.
Too small values for stack and frame may create surprising effects. |
Posted: Mon Mar 09, 2020 12:40 pm Post subject: |
MWS wrote: | Too small values for stack and frame may create surprising effects. |
Indeed. And that is the problem here. there is not sufficient frame space to create a temp string of the MID result.
when you have a string with a length of 100, the maximum data it can contain is 100 chars/bytes.
when you do an operation on that string which requires a full copy, you need enough frame space. that is where temp data is stored.
simple sample :
s="abc"
s= s + "x" ' ok no need to have a temp copy since we add to the end of the string
s="klm" + s 'this is where we need a copy of S because S is overwritten with new data + the old data
using SELECT with a function that returns a string works similar. _________________ Mark |
atmega64
Posted: Mon Mar 09, 2020 2:03 pm Post subject: |
ok...
but how do you explain that with v.2.0.8.1 it works? |
Posted: Mon Mar 09, 2020 8:53 pm Post subject: |
atmega64 wrote: | but how do you explain that with v.2.0.8.1 it works? |
Already said, one more time:
Quote: | In such case the IDE's values are used, which may differ between the versions. |
Did you at least try if your code works with any version and proper stack/frame values? |
atmega64
Posted: Tue Mar 10, 2020 8:08 am Post subject: |
Obviously I had already checked that IDE's values were the same ...
Quote: | Did you at least try if your code works with any version and proper stack/frame values? |
I will try soon ... |
atmega64
Posted: Tue Mar 10, 2020 8:55 am Post subject: |
I confirm that even increasing the stacks / frame values it only works with the BASCOM version 2.0.8.1
Code: | $regfile = "m1284def.dat"
$crystal = 16000000
$hwstack = 48
$swstack = 40
$framesize = 48 |
Posted: Tue Mar 10, 2020 12:00 pm Post subject: |
I tested with 2082 and it seems to work just fine.
I did mod your code a bit. it is not a good idea to have variables with the same base name.
$crystal = 16000000
$baud = 19200
$hwstack = 48
$swstack = 40
$framesize = 48
Declare Sub Bip
On Urxc Rxcom1_isr
Enable Urxc
Dim Rxdata2$ As String * 254 , Rxcmd As String * 254 , Id As String * 2
Dim Rxdata1 As Bit
'ID DEVICE
Id = "06"
Reset Rxdata1
Rxdata2$ = "[06GM TEST]"
'Bip
If Rxdata1 = 1 Then
Reset Rxdata1
If Left(rxdata2$ , 1 ) = "[" And Right(rxdata2$ , 1 ) = "]" And Len(rxdata2$) > 5 Then 'comando corretto
If Id = Mid(rxdata2$ , 2 , 2) Then
Select Case Mid(rxdata2$ , 4 , 2)
Case "GM" : Bip
Waitms 500
Print "OK GM";
Case "GS" : Bip
Waitms 500
Print "OK GS";
Case "SM" : Bip
Waitms 500
Print "OK SM";
End Select
Rxdata2$ = ""
Rxcom1_isr:
Comchar1 = Inkey()
Rxdata2$ = Rxdata2$ + Chr(comchar1)
Set Rxdata1
Sub Bip
Buzzer = 0
Waitms 20
Buzzer = 1
End Sub
i would not recommend to work on a variable inside an int and in the main program without disabling interrupts in the main code.
in your code it might work but take in mind that when you do : Rxdata2$ = "" in the main code
and the ISR adds data, it will depend on where the main code is executing if you get that data or not. _________________ Mark |
Posted: Tue Mar 10, 2020 12:38 pm Post subject: |
atmega64 wrote: | Obviously I had already checked that IDE's values were the same |
To make it 'obvious' for the reader, you would need to write that you have checked it.
Did not notice that, where in this thread did you write it?
The help mentions %&#! as suffixes for numeric variables, but I see nowhere in the help the dollar-sign suggested.
Help for 'Dim' shows the dollar sign used as compiler-directive prefix or as hex notifier, but I don't see and neither saw it in Bascom used for strings..
I would not use special characters as variable-names unless I know them as save.
Btw., to name a bit var rxdata1 and and a string val rxdata1$ is also not the brightest idea around.
Easier reading and less error-prone it's with self explaining names, for example rx1_data and rx1_received.
If you want to know where's the difference, means why the one works while you state the other does not, you need to provide an original string for rxdata1$.
Then it's possible to find out. |
atmega64
Posted: Tue Mar 10, 2020 12:58 pm Post subject: |
Quote: | i would not recommend to work on a variable inside an int and in the main program without disabling interrupts in the main code. |
so I should disable the interrupts before Rxdata2 $ = "" and immediately re-enable them ... right? |
atmega64
Posted: Tue Mar 10, 2020 2:12 pm Post subject: |
Quote: | Btw., to name a bit var rxdata1 and and a string val rxdata1$ is also not the brightest idea around.
Easier reading and less error-prone it's with self explaining names, for example rx1_data and rx1_received. |
ok.. |
atmega64
Posted: Tue Mar 10, 2020 3:28 pm Post subject: |
I modified the code but always the same problem, that is, it doesn't work with the bascom version 2.0.8.2...
$crystal = 16000000
$hwstack = 48
$swstack = 40
$framesize = 48
$baud = 19200
Declare Sub Bip
On Urxc Rxcom1_isr
Enable Urxc
Dim Rxdata1 As String * 254 , Rxcmd As String * 254 , Id As String * 2
Dim Rxdata1end As Bit
'ID DEVICE
Id = "06"
Reset Rxdata1end
Rxdata1 = ""
Bip
If Rxdata1end = 1 Then
Reset Rxdata1end
If Left(Rxdata1 , 1 ) = "[" And Right(Rxdata1 , 1 ) = "]" And Len(Rxdata1) > 5 Then 'comando corretto
If Id = Mid(Rxdata1 , 2 , 2) Then
'Rxcmd = Mid(Rxdata1 , 4 , 2)
Select Case Mid(Rxdata1 , 4 , 2)
Case "GM" : Bip
Waitms 500
Print "OK GM";
Case "GS" : Bip
Waitms 500
Print "OK GS";
Case "SM" : Bip
Waitms 500
Print "OK SM";
End Select
Rxdata1 = ""
Rxcom1_isr:
Comchar1 = Inkey()
Rxdata1 = Rxdata1 + Chr(comchar1)
Set Rxdata1end
Sub Bip
Buzzer = 0
Waitms 20
Buzzer = 1
End Sub
End |
Posted: Tue Mar 10, 2020 4:14 pm Post subject: |
you should also include info about the data you sent.
and if it includes CR , LF or both. _________________ Mark |
Posted: Tue Mar 10, 2020 4:28 pm Post subject: |
i tested with real HW and with the SIM and it works in 2082 as expected.
Code: |
$regfile = "m88def.dat"
$crystal = 8000000
$baud = 19200
$hwstack = 48
$swstack = 40
$framesize = 48
Declare Sub Bip
On Urxc Rxcom1_isr
Enable Urxc
Dim Rxdata1 As Bit
'ID DEVICE
Id = "06"
Reset Rxdata1
'Rxdata2$ = "[06GM TEST]"
'Bip
If Rxdata1 = 1 Then
Reset Rxdata1
Case "GM" : Bip
Waitms 500
Print "OK GM";
Case "GS" : Bip
Waitms 500
Print "OK GS";
Case "SM" : Bip
Waitms 500
Print "OK SM";
End Select
Rxdata2$ = ""
Rxcom1_isr:
Comchar1 = Inkey()
Set Rxdata1
Sub Bip
' Buzzer = 0
Waitms 20
' Buzzer = 1
End Sub |
i send the data using the bascom terminal emu. and i get the expected result printed.
i have no idea what you do but judging from the earlier code i have some doubts. _________________ Mark |
atmega64
Posted: Tue Mar 10, 2020 4:33 pm Post subject: |
Quote: | you should also include info about the data you sent.
and if it includes CR , LF or both. |
The data I send does not include CR and LF
but I repeat, sending the same data, with the bascom version 2.0.8.1 it works ...
Code: | i have no idea what you do but judging from the earlier code i have some doubts. |
why does the following code make you wonder?
$crystal = 16000000
$hwstack = 48
$swstack = 40
$framesize = 48
$baud = 19200
Declare Sub Bip
On Urxc Rxcom1_isr
Enable Urxc
'ID DEVICE
Id = "06"
Reset Rxdata1end
Rxdata1 = ""
Bip
Reset Rxdata1end
Case "GM" : Bip
Waitms 500
Print "OK GM";
Case "GS" : Bip
Waitms 500
Print "OK GS";
Case "SM" : Bip
Waitms 500
Print "OK SM";
End Select
Rxdata1 = ""
Rxcom1_isr:
Comchar1 = Inkey()
Set Rxdata1end
Sub Bip
Buzzer = 0
Waitms 20
Buzzer = 1
End Sub
End |
