adding a null to a string
Tiny
PostPosted: Mon Mar 02, 2020 4:53 pm    Post subject: adding a null to a string Reply with quote
Is there as possibility the add manually a "null" to a string
for example
$regfile = "m88pdef.dat"
$crystal = 4000000
$hwstack=40
$swstack=16
$framesize = 32
Dim Mystring As String * 40
Dim Aa As Byte
For Aa = 1 To 10                                            'fill the string with 10 chars
   Mid(mystring , Aa , 1) = "a"
Next Teller
Print Len(mystring)
'result = 10
For Aa = 1 To 4                                             'fill the string with 4 chars
   Mid(mystring , Aa , 1) = "b"
Next Teller
Print Len(mystring)
'result = 10
'after the fourth  "b" there must be a "null"to terminate the string
regards Tiny
PostPosted: Mon Mar 02, 2020 7:05 pm    Post subject: Reply with quote
Your code won't compile.
Beside this, overlay mystring with a byte-array and assign the 0 there.
Tiny
PostPosted: Mon Mar 02, 2020 10:27 pm    Post subject: Reply with quote
Sorry for the wrong sample code
Your solution for using an array as overlay works, Thanks
$crystal = 4000000
$hwstack=40
$swstack = 16
$framesize = 32
Dim Bytes(40) As Byte At Mystring Overlay
Dim Aa As Byte
Next Aa
Print Len(mystring)
'result = 10
Next Aa
Bytes(5) = 0
Print Len(mystring)
'result = 10
PostPosted: Tue Mar 03, 2020 2:28 am    Post subject: Reply with quote
Next Aa
Bytes(5) = 0
You can also do it without the overlay:
Next Aa
' then:
Mid(mystring,5,1) = 0
'note this is NOT the same as:
Mid(mystring,5,1) = "0"
Certainly the overlay works, and for some things, its a very elegant solution, but it is a bit obscure.
Adrian Jansen
PostPosted: Tue Mar 03, 2020 9:20 am    Post subject: Reply with quote
For "same characters strings" you can use String function instead, nonefficient here, For-Next loop.
Mystring = String(10 , 97)                                  '10x "a"
Print Mystring
Mystring = String(4 , 98)                                   '4x "b"
Print Mystring
Tiny
PostPosted: Wed Mar 04, 2020 7:46 am    Post subject: Reply with quote
Hey,
thanks everyone for the solutions provided.
Regards Tiny
