Using a Timer for Soft clock instead of 32768 kHz xtal
Goto page 1, 2  Next
KenHorse
PostPosted: Wed Feb 19, 2020 1:52 am    Post subject: Using a Timer for Soft clock instead of 32768 kHz xtal Reply with quote
So I've found several examples using SEARCH but Bascom is throwing a Label Not Found (Error : 61 Line : 23 Label not found [_SOFT_CLOCK] , in File
$regfile = "m2561def.dat"
$hwstack = 600
$swstack = 450
$framesize = 245
$Baud = 57600
Dim Tick As Byte
Config Clock = User
Config Date = MDY , Separator = .
Date$ = "02.03.20"
Time$ = "23:59:45"
Config Timer3 = Timer , Prescale = 256 , Clear Timer = 1
Compare3a = 6250
Timer3 = 0
On OC3A SECTICTENTHS
Enable OC3A
Start Timer3
Enable interrupts
SECTICTENTHS:
Incr Tick
If Tick >= 10 Then
    Tick = 0
    !JMP  _SOFT_CLOCK
Settime:
Getdatetime:
Setdate:
I've even tried "!CALL _SOFT_CLOCK" with the same error
What am I missing?
PostPosted: Wed Feb 19, 2020 7:36 am    Post subject: Reply with quote
As clock is configured for 'user' the softclock time keeping routines are not required, thus not compiled.
KenHorse
PostPosted: Wed Feb 19, 2020 7:56 am    Post subject: Reply with quote
4th post down
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=6127&highlight=softclock
PostPosted: Wed Feb 19, 2020 9:25 am    Post subject: Reply with quote
@KenHorse Read carefully - in that code you have "Config clock = Soft" where in your code it is "User"
There is another solution for clock. Look. It works even in the simulator.
$hwstack = 600
$swstack = 450
$framesize = 245
$Baud = 57600
$sim                                  'remark this line for real device, this is for simulator
Dim Tick As Long , Prev_tick As Long
Dim Strtime As String * 8
Dim Strdate As String * 8
Config Clock = User
Config Date = Mdy , Separator = Dot
Strtime = "23:59:45"
Strdate = "02.03.20"
Tick = Syssec(strtime , Strdate)
Config Timer3 = Timer , Prescale = 256 , Clear_timer = 1
Compare3a = 62499                                            '1s @16MHz/256 [EDITED]6249->62499
On Oc3a Sectic
Enable OC3A
 If Prev_tick <> Tick Then
  Prev_tick = Tick
  Strtime = Time(tick)
  Strdate = Date(tick)
  Print Strdate ; "   " ; Strtime
Sectic:
 Incr Tick
Settime:
Getdatetime:
Setdate:
PostPosted: Wed Feb 19, 2020 9:33 am    Post subject: Reply with quote
KenHorse wrote:
4th post down
If you found a sample, what is the reason you don't follow it?
My sentence answered your question, looks you did not understand what it said, here's the long version:
I know how to to it, thus I answered to your question why you can not call _SOFT_CLOCK with:
In your code clock is not configured for 'soft' as in the sample, it is configured for 'user'.
With 'user' the _SOFT_CLOCK-routines are not required, thus not compiled in, as time-keeping is done by the routines
Settime:
Getdatetime:
Setdate:
which are preferably used for external RTC purposes.
In your linked sample you will notice:
Config Clock = Soft
and also reconfiguring the timer to disconnect from external 32kHz xtal.
Does this give you some insight?
KenHorse
PostPosted: Wed Feb 19, 2020 9:49 pm    Post subject: Reply with quote
Indeed, I did miss that he was defining it as Soft and not User
My bad (and it makes perfect sense)
Last question.
Is it possible to change the value of Compare3a (currently set to 6250) "on the fly" to compensate for a crystal that isn't exactly on frequency? Perhaps by stopping the timer, setting the new value and restarting it?
PostPosted: Wed Feb 19, 2020 9:57 pm    Post subject: Reply with quote
Yes. You can change COMPARE3A anytime. One thing can happen if Timer will be, for example at 6400, and you set COMPARE3A to 6000 then compare will not fire once and timer will simply overflow at 65535 but this is not big deal in this case. Stopping and Restarting the Timer is not needed.
Some Timers modes have dual buffering and value is updated when Timer reach TOP or BOTTOM but this is not valid for Clear_timer I think.
You can always update OCR3A in the interrupt routine but this will increase you interrupt code.
KenHorse
PostPosted: Wed Feb 19, 2020 10:32 pm    Post subject: Reply with quote
I was thinking about that as any change would really be part of a calibration procedure and afterwards be rarely used. But having the possibility to make that change may be invaluable
PostPosted: Thu Feb 20, 2020 12:06 am    Post subject: Reply with quote
The value of Compare3 can only be set in integer amounts. If its around 6000, then the smallest increment is about 1:6000, thats about 14 secs per day. So its not a very fine adjustment. Thats huge in terms of 'normal' crystal accuracy.
Adrian Jansen
KenHorse
PostPosted: Thu Feb 20, 2020 12:23 am    Post subject: Reply with quote
Current value is 6250, which gives a (nominal) tic of .1 second.
Bascom doesn't seem to object of any value (for example, 6251 or 6249). I'm testing the difference that makes but you're saying it will make a bigger one than I'm looking for. I'll let you know in 12 hours whether it makes a significant difference! Very Happy
PostPosted: Thu Feb 20, 2020 3:40 am    Post subject: Reply with quote
A few other thoughts, reaching back into ancient history:
You might be able to use a lower base frequancy, like near 1Hz, rather than 0.1Hz, by setting the timer3 compare up near 62000 ( dont go over 65535 or you will overflow ! ). That will get you 1 digit better resolution, so smaller adjustment steps, on the compare setting.
Typical computer clock crystals up in the MHz range have significant temp coeffs. So you might find that the temp drifts will upset the accuracy. Also the drive power can affect the frequency. There are usually two settings in the fuses to select which is better for the application. In general lower drive power is better for stability, if it can be used.
The 32KHz crystals used for eg watches are a different cut, with about as low a TC as possible. Thats why they are used for timekeeping, and Atmel offer a second crystal connection to be able to use them on many chips.
Adrian Jansen
PostPosted: Thu Feb 20, 2020 12:07 pm    Post subject: Reply with quote
The formula for OCx is (F_CPU/PRESCALER/FREQ) - 1 because uC will execute interrupt minimum after one tick.
Till now I dont see typo in my example. COMPARE3A should have value 62499 not 6249. Because it is not my first time typo I always describe in the comment what I want to achieve (1s @16MHz/256)
KenHorse
PostPosted: Thu Feb 20, 2020 4:39 pm    Post subject: Reply with quote
As my target period is .1 sec and not 1 sec, 6250 is correct I believe
PostPosted: Thu Feb 20, 2020 4:45 pm    Post subject: Reply with quote
You forget to substract one Wink Even Windows Calculator can do that math Very Happy
Value 24999 with Prescaler 64 should work too Wink
KenHorse
PostPosted: Thu Feb 20, 2020 4:58 pm    Post subject: Reply with quote
https://eleccelerator.com/avr-timer-calculator/
Goto page 1, 2  Next
Page 1 of 2
