Andrei
Joined: 30 Apr 2004 Posts: 24 Location: Ekaterinsburg,Russia
Posted: Mon Feb 10, 2020 4:30 pm Post subject: ATtiny85 doesn't work in USI-TWI slave mode |
Hallo to all!
Sometimes I need to connect sensors and MC. I use 2082 BascomAVR version and I decided to use newest I2C\TWI library as well(of course, I have got them by legal way). I2C slave, TWI slave works very good, if I use a right library in a head of program with a lot of chips. I used one I2C soft master in all experiments - all resuts were good.But I can't get the same result, using USI slave library with ATtiny 85.I begun to work with tiny 85 like I2C slave - reply was 255 only! I repeated the example from I2CSLAVE DATASHEET. I saw ID0 = 255, ID1 = 255, ID2 =255 on master's LCD only (oscilloscope's screen shows 8 ones on SDA, of course).Can I use I2C slave soft master & USI-TWI slave?Why doesn't work tiny85 like USI-TWI slave, who knows? I changed ATtiny85, of course, but the result was the same.I tried to use SELECT CASE and without SELECT CASE - both resuts were negative.
$regfile = "attiny85.dat"
$hwstack = 32
$swstack = 32
$framesize = 40
$lib "I2C_USI_SLAVE.lib"
Config USI = TWIslave, address = &H40
Config Timer0 = Timer, Prescale = 256
Start Timer0
Enable Timer0
On Timer0 Label_1
Dim D As Byte
Dim V As Byte
Dim V1 As Byte
Dim X As Byte
Dim ID As Byte 'BYTE'S IDENTIFICATOR
Dim Tay0 As Byte
Begin:
If ID = 0 Then 'ID BYTE: SLAVE GETS IT FROM MASTER
X = D
End if
If ID = 1 Then
X = V
End if
If ID = 2 Then
X = V1
End if
Goto Begin
Label_1:
Incr Tay0
If Tay0 => 122 Then 'TIME 1 SEC
Incr D
V = D + 1
V1= D + 2
Tay0 = 0
End if
TWI_GOTDATA:
Select Case Twi_btw:
Case 1: ID = Twi 'MASTER SENDS ID - 0,1,2 TO SLAVE
End select
TWI_STOP_RSTART_RECEIVED:
TWI_ADDRESSED_GOWRITE:
TWI_ADDRESSED_GOREAD:
TWI_MASTER_NEEDS_BYTE:
Select Case Twi_btr:
Case 1: Twi = X 'must be 0...255 MASTER GETS D,V,V1 AND PUT THEM ON DISPLAY
End select
Andrei
Posted: Tue Feb 11, 2020 9:23 pm Post subject: |
Hello!I see there reply 255 only!Who has good results, using attiny avr 25,45,85 with I2C_ USI_TWI-slave library(bascom 2082 & the last I2C slave library)? Is it library alive or dead?ATmega8,48,168,328 chips work very good like slaves in I2Csoftslave&twi-slave modes, but they have big sizez and a lot of pins, tiny has small sizez and 8 pins only, that is more better.
This is soft master's I2C program, if it's need:
$regfile = "m32def.dat" ' specify the used micro
$crystal = 16000000 ' used crystal frequency
$baud = 19200 ' use baud rate
$lib "I2c.lib"
Config Sda = Porta.3
Config Scl = Porta.2
Config I2cdelay = 10
I2cinit
Const Addressw = &H40
Const Addressr = &H41
Dim C As Byte
Dim V As Byte
Dim V1 As Byte
Dim D As Byte
Dim X As Byte
Config Watchdog = 2048
Start Watchdog
Config Timer0 = Timer , Prescale = 256
Start Timer0
Enable Timer0
On Timer0 Label_1
Dim Tay0 As Byte
Dim Tay1 As Byte
Config Lcdpin = Pin , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7 , E = Portb.2 , Rs = Portb.3
Config LCD = 20 * 4
Cursor Off Noblink
Reset Watchdog
Begin:
Reset Watchdog
I2cstart
I2cwbyte Addressw
I2cwbyte C 'BYTE'S ID
I2cstop
Reset Watchdog
waitms 1 'SLAVE WORKS WITH VARIABLES
I2cstart
I2cwbyte Addressr
I2crbyte X,Nack
I2cstop
Reset Watchdog
If C = 0 Then
D = X
End if
If C = 1 Then
V = X
End if
If C = 2 Then
V1 = X
End if
Locate 1,1
Lcd "VAR =";D;" ";V;" ";V1;" " 'I SEE 255, 255, 255 ONLY - IT ISN'T REPLY FROM TINY85
Locate 2 , 1
Lcd "C =";C;" " ' CIRCLE - 0,1,2
Goto Begin
Label_1:
Incr Tay0 '4,096 MSEC
If Tay0 => 244 Then
Incr C
If C = > 3 Then
C =0
End if
Tay0 = 0
End if
Return |
