2.0.8.2 installation don't will work
P_Santos
PostPosted: Mon Jan 13, 2020 8:14 pm    Post subject: 2.0.8.2 installation don't will work Reply with quote
I download the new version 2.0.8.2 and installed, after that, copied all *.dll files from the folder of the 2.0.8.1 and start the new version, but it not work and show the error message: "Application error"
The procedure dpConver2082 could not be located in the DLLBAS-AVR.DLL
What make i wrong, try to run the wizard too, but it don't run
P_Santos
P_Santos
PostPosted: Mon Jan 13, 2020 9:12 pm    Post subject: Reply with quote
It works, uninstalled and installed again, and now itīs fine
P_Santos
PostPosted: Wed Jan 15, 2020 11:10 am    Post subject: Reply with quote
your problem was that you copied the 2081 files over the 2082 files.
you only need the bscavrl.dll file
P_Santos
PostPosted: Wed Jan 15, 2020 11:14 am    Post subject: Reply with quote
Hello albertsm,
You are right, thank you, it's solved
P_Santos
kartmanne
PostPosted: Sat Feb 22, 2020 1:57 pm    Post subject: Reply with quote
HI,
I did the same procedure to install 2082. It runs.
But the compiler doesn't find the specified xm128a1.dat. But it is in the path of bascavr.exe (2082).
In the chip settings I couldn't choose any chip.dat the list is empty. Looks like the path for the *.dat is wrong. But I do not find an option to adjust that path.
PC (WiN XP) restart after installation doesn't help.
Can you advise how to get this solved?
THX
Manfred
CU
Manfred
PostPosted: Sat Feb 22, 2020 3:29 pm    Post subject: Reply with quote
DAT files should now be in ..\BASCAVR2082\DAT\ directory
kartmanne
PostPosted: Sat Feb 22, 2020 4:00 pm    Post subject: Reply with quote
HI,
ah - ok. I did a clear install and so I found the *.dat are at new location.
works.
THX
CU
Manfred
