Per Svensson
Joined: 03 Oct 2004 Posts: 238 Location: Gothenburg, Sweden
Posted: Mon Jan 06, 2020 5:16 pm Post subject: CAN-bus library for general CAN-bus controller chip MCP2515 |
If you are interested in communication over a CAN-bus, this might be a thread for you.
My ambition has been to create a Bascom include library for a general CAN controller chip rather than the one that exists in a few of the AVR-chips.
Thus, making CAN available for virtually all members of the AVR family. I have chosen the MCP2515 controller as it seem to be widely spread and well proven
It is also rather cheap. Both as a chip and mounted on a PCB.
I have used an Arduino UNO with a CAN-shield from RobotDyn or Spark-fun during my development. This combination will have access so all necessary pins over the standard Arduino pinning,
so no extra wires are necessary. You can find these shields from Ali-baba, e-bay or Spark-fun. They are all very similar.
For bus testing I have used the "CAN bus Analyser" from Microchip. A simple tool that still can handle most CAN tasks and log the results.
If you don't want to invest in this there is also a possibility to put the MCP2515 in "loopback mode". It will allow testing of most functions without actually hooking up to a real bus at all.
The first library version 1.2 that I publish here is a little more than just an embryo for a finished and well proven lib, but certainly nothing you can trust yet. My hope is that we together can make it
better, and more solid.
I suggest that you start having a look in the functional description file "CAN library description - Revision 1.2.txt". Here is the syntax for the various function calls and a short description of what they do.
I also recommend that you skim through the MCP2515 data-sheet to get a good understanding of the internal chip structure and how buffers are handled. (there are three for transmission and two for reception. Message filtering is also a vital part of the communication.)
Next, try to compile the example file "MCP2515 Simple CAN R1.2.bas". It will call all necessary routines from the INC-file "CAN_MCP2515_package.inc"
This example will allow you to send and receive CAN messages in loopback or normal mode. The default baudrate is 125kbit/s but you can chose any of the rates recommended by the CAN_OPEN interest group "CiA". I will do all I can to make this lib as compatible as possible to CAN-OPEN. Type "?" for a menu of a few commands that will come in handy during your evaluation.
There is also an auto-baud function is the lib, that should make life easier as it tries to automatically hook up to an existing bus by listening to ongoing traffic (is there is any) and adapt to that rate.
This is invoked during boot-up, but is not really tested since I had no bus with already talking devices.
I hope this contribution will fill a gap and make CAN-communication easier and more understandable. I also hop that you will contribute to the refinement of this "embryo". Either by issuing your own updated lib, or by sending me new enhancements or bug reports so I can generate updates.
Have fun!
/Per |
Posted: Wed Jan 08, 2020 11:52 am Post subject: |
Hi Per,
That is excellent work !
It seems a nice chip and indeed it is convenient when you can use any AVR without CAN hardware.
When i have time i will study this chip some more. When this matures i can have a look at possible integration when it makes sense.
Thanks for sharing ! _________________ Mark |
Per Svensson
Posted: Wed Jan 08, 2020 12:44 pm Post subject: |
Thanks Mark!
I think it can be useful, but I also wonder how many Bascom'ers that really use CAN?
Besides from car diagnostics I have a feeling that it is not used that much among hobbyists.
It is a robust bustype so it deserves more attention.
Could be interesting to get some "hands up" here..
One interesting feature in this chip is the ability to send a message for "transmit request"
It will offer instant reply of data that is already loaded in the remote data registers (up to eight bytes).
This is not tested yet, but is on the todo list. However, It is in principle already supported by the CAN_TRANSMIT function by setting param RW to 1.
The chip is rather simple but the use of multiple bit mapping of certain flags maked it sometimes confusing.
The message masking and filtering is also rather complex so I will ty to hide as much of this handling and let the lib sort it out on the higher level.
My ambition is also to stick to CAN_OPEN as much as possible, as there are lots of profiles for various equipment already defined. Especially for talking
to sensors of all kinds.
Did you try to compile the example I attached?
/Per
//PS. How do I apply for HTML code to be allowed? I cannot format my text. Can you fix it? //DS |
Posted: Wed Jan 08, 2020 2:15 pm Post subject: |
I also think that CAN is more for the profi. But there are lot of profi bascom users.
your code compiles ok but there are some things you can improve.
for example : Data() , the code explorer will flag this because DATA is also a reserved word.
I also needed to change the absolute inc path to relative. but no problem
tomi
Posted: Wed Jan 08, 2020 2:52 pm Post subject: |
Per Svensson wrote: |
HTML tags are not allowed but for formatting text you can use BBtags in editor, they provide enough options to format your post. _________________ Best regards,
/Tomi |
Posted: Wed Jan 08, 2020 4:01 pm Post subject: |
I was download the library and take a look for the code. I`ve saw the two links. First was for polish forum where in 2012 this Bascom related CAN topic was started and some part of the your library is ported. You are onest man.
My previous job was mechatronic so I have plenty of car cables and steel sentiment for cars electronics.
So I have two VCDS cable. One is broken and maybe I dont try to fix it by simple repair because it have Mega162, FT323BL and topic chip MCP2515
Ofcourse every CAN needs transceiver like AVR needs too. They are two popular and this cable have PCA82C250.
Maybe someone will be interrested how proffesionall cable was made so I attach PDF with schematic. GAL on this circuit is for some protocol/pin switching.
Also it is good to look how K-Line can be driven with specialized chip L9637.
To the point.
I have some CAN gateway devices and car ECU`s . Maybe with your work I try to ask them with Bascom language
I appreciate your work. I always want to do this but nobody have time for everything  |
Per Svensson
Posted: Wed Jan 08, 2020 10:50 pm Post subject: |
Thanks Tomi
I'll try to prettify my future text from now.
Thanks for your CAN design contribution. Now we can make our own CAN-links if we like.
However, I suppose most people would avoid the hazzle of soldering and get an Arduino shield. (just like I did)
They are really cheap and you get a lot of extras with them. Like SD-card, joystick and GPS-plug in my case.
Nevertheless, your L-line is extra so that is a bonus. I have never tried that bus though...
I hope your enthusiasm will spred. Thanks again!
/Per |
enniom
Posted: Fri Jan 10, 2020 6:34 pm Post subject: |
For the purpose of CAN interface to OBD, I have used ELM323/327 chips with AVR.
Very easy.
E |
nicofer
Posted: Wed Jan 15, 2020 11:33 am Post subject: |
Hi
I have a project that require 2 CAN bus 'ports'
One way is to use more powerful dual can port ARM chips .
But I prefer the BASCOM route with one channel a AT90 CAN 128 - the other channel the MCP 2515 .
Is the above library available ?
Regards
Nico |
andro
Posted: Thu Feb 06, 2020 12:12 pm Post subject: |
That's realy great job!
Question: does this library support Xmega familly?
Br
Andrej |
Per Svensson
Posted: Thu Feb 06, 2020 2:01 pm Post subject: |
It is not yet tested on Xmega.
However, I have not used any specific Xmega features,so I see no reason why it should not work.
It you test it on Xmega, please report the result here.
/P |
andro
Posted: Thu Feb 06, 2020 7:41 pm Post subject: |
Hi
The major difference is in "SPI".
Therefore I would have to change the part off the library where SPI is actually in use.
Is it ok, if I try to change your lib?
Br
Andrej |
Posted: Thu Feb 06, 2020 7:54 pm Post subject: |
you can use _XMEGA constant :
#IF _XMEGA
config spic
#ELSE
config spi
#ENDIF _________________ Mark |
andro
Posted: Thu Feb 06, 2020 9:30 pm Post subject: |
Hello!
Yes, Mark, I'll do as You suggested. Now I also see it is an .inc file, not a .lib, so the workaround is (for me) much simpler.
As far as I have 'investigated' in last few minutes, I (only) have to change these part of code:
Code: | '**************************************************************************
'********************** SUBS AND FUNCTIONS ********************************
Sub Mcp2515_bitmodify(byval Reg_addr As Byte , Byval Reg_mask As Byte , Byval Reg_val As Byte)
'Write to certain bits in a MCP2515 register via SPI
'This command ensures that certain bits in a complete register can be changed without affecting the other bits.
'Unlike the "Write" command, this does not change the entire contents of the register. Only the masked bits.
Local Cmd As Byte
Reset Mcp2515_cs
Cmd = Cmd_bit_modify
Spiout Cmd , 1
Spiout Reg_addr , 1
Spiout Reg_mask , 1
Spiout Reg_val , 1
Set Mcp2515_cs
End Sub
Function Mcp2515_read(byval Reg_addr As Byte ) As Byte
'Read from a MCP2515 register via SPI
Local Cmd As Byte
Reset Mcp2515_cs
Cmd = Cmd_read
Spiout Cmd , 1
Spiout Reg_addr , 1
Spiin Mcp2515_read , 1
Set Mcp2515_cs
End Function
Sub Mcp2515_write(byval Reg_addr As Byte , Byval Reg_val As Byte)
'Write to a MCP2515 register via SPI
'Some registers can only be written in CONFIGURATION MODE
'These are:
' • CNF1, CNF2, CNF3 registers
' • Txrtsctrl Register
' • Filter Registers
' • Mask Registers
Local Cmd As Byte
Reset Mcp2515_cs
Cmd = Cmd_write
Spiout Cmd , 1
Spiout Reg_addr , 1
Spiout Reg_val , 1
Set Mcp2515_cs
End Sub
Sub Mcp2515_write_array(byval Startaddr As Byte , Data() As Byte , Byval N As Byte)
'Write to N consecutive register addresses
Local I As Byte
Reset Mcp2515_cs
I = Cmd_write
Spiout I , 1
Spiout Startaddr , 1
Spiout Data(i) , N
Set Mcp2515_cs
End Sub
I have done this before, so I think in a few days I might post some results.
BR
Andrej. |
Per Svensson
Posted: Thu Feb 06, 2020 9:59 pm Post subject: |
Hi Andro!
Yes of course you are welcome to modify and contribute to the code.
Especially if you, like mark suggests, does so in a generic way by using compiler directives and keywords.
If modifications are done to make the code more adaptive to a particular use or project, then I suggest that
you make a drop off branching, but if you make it more versatile but still generic, I suggest that you (or anyone)
updates the Revision code.
Good spirit! More of same!
/Per |
