sh1106-i2c
krolikbest
PostPosted: Wed Jan 01, 2020 7:03 pm    Post subject: sh1106-i2c Reply with quote
Hi
first of all- Happy New 2020 Smile and perhaps first question in 2020 Smile
have graphic lcd 1.3 inch with driver sh1106 i2c.It has 4 pins:
-vcc (3.3v to 5v) ->connected to 5v of arduino
-grnd ->connected to grnd of arduino
-sda -> connected to sda of arduino
-scl -> connected to scl of arduino
I got it run with arduino uno but noticed that when I use routine wait/waitms in loop lcd get blank screen and reset of arduino doesn't help.
Below my simply code i tested lcd with
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 40
$swstack = 40
$framesize = 40
$lib "i2c_twi.lbx"
$lib "glcdSH1106-I2C.lib"
Config Twi = 400000
Config Scl = Portc.5
Config Sda = Portc.4
Config Portc.3 = Output
I2cinit
Lcd_reset Alias Portc.3
Lcd_reset = 0
Waitms 100
Lcd_reset = 1
Waitms 100
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
cls
  Setfont Font8x8tt
  Lcdat 1 , 1 , "103"
  Lcdat 2 , 2 , "222"
  'wait 1 [b]<-that simply hang up...[/b]
  Lcdat 3 , 2 , "whatever" ; i
$include "Font8x8TT.font"
It looks like "wait" cannot cooperate with some routines from glcdSH1106-I2C library... maybe..
Regards,
Martin
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.2 )
PostPosted: Thu Jan 02, 2020 10:15 am    Post subject: Reply with quote
did you see the help about GLCDdSSD1306-I2C ?
is it working for you ?
do you have pull up R 4.7k on line SDA SCL ?
Happy new year
Wink
jp
PostPosted: Thu Jan 02, 2020 10:21 am    Post subject: Reply with quote
this small prog work for me i add only the first lines
'-----------Microcontroleur------------------------------------------------------------------------------------------------
$regfile = "attiny85.dat"
$crystal = 1000000
$hwstack = 40
$swstack = 40
$framesize = 40
'---- config------------------------------------------------------------------------------------------------------------------
Config Clockdiv = 8
Config Submode = New
 '-------------------------------- I2C bus  Tiny85--------------------------------------------------------------------------
Config Sda = Portb.0
Config Scl = Portb.2
I2cinit
Waitms 5
' -------les ports------------------------------------------------------------------------------------------------------------
Vote Alias Portb.1
Raz Alias Portb.3
Config Vote = Input
Config Raz = Input
Set Vote                                                    'activation des pull up
Set Raz
 'display---------------------------------------------------------------------------------------------------------------------
$lib "glcdSSD1306-I2C.lib"
Dim Lcd_auto As Byte
Lcd_auto = 1
'----var-----------------------------------------------------------------------------------------------------------------------
Dim Compteur As Integer
Dim Regb As Byte
Dim Memoire As Eram Integer
Dim Fxmem As Integer
Dim Stcomp As String * 3
Dim Flagzero As Byte
'---prog----------------------------------------------------------------------------------------------------------------------
Compteur = 0
Fxmem = Memoire                                             'lecture mémoire
If Fxmem => 0 Then Compteur = Memoire
Setfont Font12x16
   Cls
   Lcdat 4 , 1 , " LONGPONT"
krolikbest
PostPosted: Thu Jan 02, 2020 2:38 pm    Post subject: Reply with quote
Thank for your reply. Yes I've read about ssd1306-i2c but I use library for sh1106-i2c. basically it works but when it comes to execute "wait" statement then oled screen is blank and rest of the program seems to stop. Without "wait" i can even make animation and it looks very good.
There is no difference if I use or not 4.7K resisors. Actually i don't use, but using them the effect is the same- on "wait" statement program stops.
Regards,
Martin
PostPosted: Thu Jan 02, 2020 2:53 pm    Post subject: Reply with quote
you should check this : $crystal = 16000000
Is the clock actual 16 Mhz ?
Instead of wait, use waitms and see how long it actually takes.
first try waitms 1
then 10, 100 and finally 1000
krolikbest
PostPosted: Thu Jan 02, 2020 5:36 pm    Post subject: Reply with quote
Hi Mark,
tested this code:
$crystal = 16000000
$hwstack = 40
$swstack = 40
$framesize = 40
$lib "i2c_twi.lbx"
Config Twi = 400000
I2cinit
Lcd_reset = 0
Waitms 100
Lcd_reset = 1
Waitms 100
cls
  waitms 1
  cls
  Setfont Font8x8tt
  Lcdat 8 , 5 , "test test"
it seems that there is no difference between 10 or 1000 ms. For waitms=1 ms or waitms=2 ms it seems to work, but higher values make screen blank. if "waitms" i commented it works.
Regards,
Martin
PostPosted: Fri Jan 03, 2020 11:27 am    Post subject: Reply with quote
you best display a counter which you increase inside the loop.
this way you can detect a reset.
it really does not make any sense that waitms does not work so it is most likely some hardware problem. a reset for example.
PostPosted: Fri Jan 03, 2020 4:54 pm    Post subject: Reply with quote
in my little program I use wait
   Regb = Liresw()
    If Regb = 1 And Compteur = 0 Then Cls
   Select Case Regb
      Case 1
         Compteur = Compteur + 1
         Stcomp = Str(compteur) : Stcomp = Format(stcomp , "000")
         Lcdat 1 , 50 , Stcomp
         Memoire = Compteur                                 'mise en EEprom
      Case 2                                                'raz
         Compteur = 0
         Cls
         Lcdat 1 , 1 , "RAZ:" ; Compteur
         Wait 1
         Cls
         Goto 0                                             'reinitialise le µp
   End Select
So as Mark I think is is not a Bascom problem
krolikbest
PostPosted: Fri Jan 03, 2020 9:03 pm    Post subject: Reply with quote
Hello,
actually i'm a bit confused. I lowered crystal to 8MHz (normally 16MHz) and then I could use waitms till 300 ms. if crystal is 16MHz i couldn't use waitms higher than 2ms.
I noticed that if in program now I use waitms > 300, e.g.
   cls
   Setfont Font8x8
   Lcdat 7 , 6 , "test test" , 0
   waitms 400
it can work normally but after some time the text is displayed in random positions instead x,y, sometimes presumably above an acceptable range (128x64), that is why screen is blank then. The higher waitms value the more often screen is blank. So it is not a "wait" problem, now it looks like the problem is really on the display side strictly speaking with data transfer through i2c service. Anyway I'll work around it. Thank you for helping me.
Regards,
Martin
