$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 32
$framesize = 128
$baud = 115200
Const Number_of_leds = 45
'* TIMER SETTINGS FOR TIME BASE *
Config Timer0 = Timer , Prescale = 1024 , Clear_timer = 1
'Compare0a = 124 '2ms @16MHz/256
Compare0a = 77 '5ms @16MHz/1024
'Compare0a = 155 '10ms @16MHz/1024
'* MULTIPURPOSE VARIABLES *
Dim Helpb As Byte , N As Byte
'* RAINBOWLEDS SETTINGS *
Config Rainbow = 1 , Rb0_len = Number_of_leds , Rb0_port = Portc , Rb0_pin = 0
Rb_selectchannel 0 'wybierz kanal
Rb_clearcolors : Rb_send 'i czysc po reset
Dim Color(3) As Byte
Const Snow_max = 20
Dim Numleds As Byte
Dim Flash As Byte , Sparked As Byte
Dim Los As Byte , Active As Byte , Running As Byte
Dim Wait_time As Byte , Countdown As Byte
Dim Spark(3) As Byte
Spark(1) = &HFF
Spark(2) = &HFF
Spark(3) = &HFF
Dim Heat(255) As Byte
Numleds = Number_of_leds
If Tifr0.ocf0a = 1 Then
Tifr0.ocf0a = 1
If Running = 0 Then
Running = 1
Color(1) = Snow_max
Color(2) = Snow_max
Color(3) = Snow_max ' define a color
For N = 0 To Numleds -1
Rb_setcolor N , Color(1)
Else
If Flash = 1 Then
Flash = 0
Rb_setcolor Sparked , Color(1)
'Rb_send
Helpb = Rnd(5)
If Helpb > 0 Then
Los = Rnd(numleds)
Color(1) = Rb_getcolor(los)
Helpb = Color(1)
Select Case Heat(los)
Case 0
'If Active < Numleds Then
Heat(los) = 1
'Incr Active
'End If
Case 1
If Helpb > 0 Then
Decr Helpb
Color(1) = Helpb
Color(2) = Helpb
Color(3) = Helpb
Rb_setcolor Los , Color(1)
'Rb_send
Else
Heat(los) = 2
Case 2
If Color(1) < Snow_max Then
Helpb = Rnd(snow_max)
Helpb = Helpb / 4
Color(1) = Color(1) + Helpb
If Color(1) > Snow_max Then
Color(1) = Snow_max
Color(2) = Color(1)
Color(3) = Color(1)
'Rb_send
Else
Heat(los) = 0
If Active > 0 Then Decr Active
End Select
Rb_send
If Countdown > 0 Then
Decr Countdown
Else
'-------------------------------------------[SNOW]--
'time to time spark one pixel
If Running = 1 Then
Sparked = Rnd(numleds)
Color(1) = Rb_getcolor(sparked)
Rb_setcolor Sparked , Spark(1)
Rb_send
Wait_time = Rnd(200)
Flash = 1
Countdown = Wait_time
'end if 2ms
