Yokablasta
Posted: Sun Dec 01, 2019 5:43 pm Post subject: Issue with glcdSSD1306-I2C-Buf.lib |
I have been using the glcdSSD1306-I2C-Buf buffered library for SSD1306 OLED screens. I have 2 units that have the .96" oled that I wanted to use this code with. On one of the screens, I have no issues. The library drives the screen perfectly and the buffer is super fast. However on another SSD1306 .96" OLED, there appears to be a strange issue. When I run the test program for the glcdSSD1306-I2C-Buf library, the image is shifted up by 8 pixels whenever one of the graphics commands (LINE, BOX, PSET etc) is used. If I print a line of text using lcdat 1,0 , "EXAMPLE" BEFORE I call one of the graphics commands, then the text appears in the correct place. However, once I call a graphics command, the text shift up by about 8 pixels and the top 8 pixels of the screen get chopped off. I have tried altering the library in every way I can think of according to the data sheet, but to no avail. I also noticed that when I type CLS, that the bottom 8 lines of the screen never get cleared. It seems to write the graphics intended for PAGE 7 where PAGE6 would be, thus entirely chopping off PAGE 0. So to sum it up, text will appear in the correct spot, as long as no graphics are being called. The second I call a graphics command, all text shifts up by about 8 px, and the graphics get drawn shifted 8 pixels up, with the bottom row of 8 pixels getting no updates on the screen.
It appears that with the one OLED screen, the contents of the 1024 byte buffer are shifted up a row. This means that when I update the screen using the buffer, including when I clear the screen, only the top 56 rows of pixels get updated, with the top 8 pixels getting cut off. If I write a line of text in the bottom row of the screen (without a graphics command that uses the buffer being called) the text will apper in the correct place, however when I clear the screen, the bottom row of 8 pixels doesn't get cleared.
Any insights or help would be appreciated. Thanks!
(BASCOM-AVR version : 2.0.8.2 ) |
Posted: Mon Dec 02, 2019 10:26 am Post subject: |
Quote: | I have 2 units that have the .96" oled that I wanted to use this code with. On one of the screens, I have no issues. |
why want to change the Bascom library since one of them works correctly ?
I think it's a hardware/software problem on the second one.
I use it too without any problem
JP
[/img] _________________ pleasure to learn, to teach, to create |
Yokablasta
Posted: Mon Dec 02, 2019 4:52 pm Post subject: |
I only want to figure out how to make the other screen work, because I have units in the field that also use that screen. I'm trying to add a firmware update to my units that allows for better graphics, so had switched SSD1306 libs to do it. The old library worked perfectly on all of my products. The new buffered driver has an issue with the screen used on one, so I'm pretty motivated to figure it out.
I did make more progress on this though. It appears that the translation of the software buffer (1024 bytes in sram) and GDDRAM in the display is offset by a certain amount. I'm just looking at the assembly to figure out how to adjust that so I can properly plot the GDDRAM points and display them. When I use text with AUTO mode, wverything works fine. It's when I need to use the buffer that the offset happens. If I figure it out, I'll post here. |
Yokablasta
Posted: Tue Dec 03, 2019 10:06 pm Post subject: |
I did end up figuring this out. I had to adjust the SETSTARTLINE parameter in the OLED library. One helpful hint for anybody making adjustments to the library, is to be sure to cycle power, not just RESET, when you are making adjustments to the library. Otherwise, an old variable value may linger, causing results to appear differently than they will upon a power cycle. Setting the new start position in the buffer solved my issue. |
Posted: Wed Dec 04, 2019 9:48 pm Post subject: |
i assume you altered this value : .db &H40, &H8D ; SETSTARTLINE , CHARGEPUMP
what was the new value for &H40 ?
odd : why would it work different for your other display? 2 of the same lcd should behave exact the same.
altering software is only required when the lcd are not really identical. _________________ Mark |
Yokablasta
Posted: Tue Dec 10, 2019 11:49 am Post subject: |
The two displays were not exactly identical. They were both .96" SSD1306 types, but from different vendors. These were the settings that worked.
.db &H78, &HAE ; DISPLAY OFF
.db &HD5, &H80 ; SET DISPLAY CLOCK DIVISION
.db &H00, &H3F ; SETMULTIPLEX , 128x32
.db &HD3, &H00 ; SET DISPLAY OFFSET , 00
.db &H12 ; Setstartline
.db &H20, &H00 ; DISPLAY MODE |
