rafael_jimenez
Posted: Wed Nov 20, 2019 11:20 am Post subject: Locomotive controller with Bluetooth HC-05 |
Hello friends of the forum,
I'm testing a locomotive with a controller that works with 3.5 volts.
My program works as it is, but I want PWM signals to be controlled faster.
I made an application with MIT App inventor,
could someone please help me the best way to make PWM signals more controllable?
your collaboration is appreciated
[/code]
'** Electric Locomotive Version 1.0 *
'** PORTC 1,2,3,4,5 = Relay
'** PORTC.0 = Led Signal monitor
'** PORTB.2 = PWM for Motor driver
'** Bascom version 2.0,8,1
'**___________________________________________________________________________
$regfile = "m8def.dat"
$crystal = 16000000 '16000000
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 9600
Dim A As String * 2
Dim Pwmval As Byte
Config Portb.0 = Output 'Signal OK
Config Portc.0 = Output ' Main switch
Config Portc.1 = Output 'Emergency Motor Batt. on/Off
Config Portc.2 = Output 'Direction
Config Portc.3 = Output 'Licht
Config Portc.4 = Output ' Horn
Config Portc.5 = Output
Config Timer1 = Pwm , Pwm = 8 , Prescale = 1 , Compare B Pwm = Clear Up ' , Compare A Pwm = Clear Up
'Start Timer1
'Enable Interrupts
Led_blink Alias Portb.0 'led blink Microcontroller loop
Button_1 Alias Portc.0 'relay 1
Button_2 Alias Portc.1 'relay 2
Button_3 Alias Portc.2 'relay 3
Button_4 Alias Portc.3 'Relay 4
Button_5 Alias Portc.4 'relay 5
'Ocr1b = 0
Pwmval = 0
Toggle Portb.0
Waitms 40
If Ischarwaiting() = 1 Then
A = Inkey()
'Main Switch For Modul
If A = "1" Then
If Button_1 = 1 Then 'Master Switch
Button_1 = 0
Print "1_ON"
Else
Button_1 = 1
Print "1_OFF"
'Button Switch Modul
If A = "2" Then
If Button_2 = 1 Then 'If Button_2 = 0 Then ' motor schaalter Bat.
Button_2 = 0 ' Button_2 = 1
Print "2_ON" ' Print "2_ON"
Else 'Else
Button_2 = 1 'Button_2 = 0
Print "2_OFF" 'Print "2_OFF"
'Button for Direction
If A = "3" Then
If Pwmval <> 0 Then
Pwmval = 0 ' set motor to cero
Ocr1b = Pwmval
Waitms 500
If Button_3 = 1 Then ' direction change
Button_3 = 0
Print "3_ON"
Else
Button_3 = 1
Print "3_OFF"
'Button for Licht
If A = "4" Then
If Button_4 = 1 Then
Button_4 = 0
Print "4_ON"
Else
Button_4 = 1
Print "4_OFF"
' Button for Horn
If A = "5" Then
Toggle Button_5
'Button_5 = 1
Waitms 500
Reset Button_5
'Button_5 = 0
'__________________________________
'**** motor control Maxim 3,5.4volt Output
If A = "6" Then
Start Timer1 'timer1 loop
If Pwmval < 192 Then Incr Pwmval 'Fader Motor Up
'Waitms 100 :
Ocr1b = Pwmval '+ 20
If A = "7" Then
If Pwmval > 0 Then Decr Pwmval 'Fader Motor down
' Waitms 50 :
Ocr1b = Pwmval + 10
(BASCOM-AVR version : 2,0,8,1 , Latest : 2.0.8.2 ) |
Posted: Wed Nov 20, 2019 12:39 pm Post subject: |
I think that I tweak some of your serial receiving routines because buffered serial and moving 40ms delay into Timer2 control but Im thinking that some of the rest of code can be better.
Code: | '*******************************************************************************
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 9600
Dim A As String * 2
Dim Pwmval As Byte
Config Timer1 = Pwm , Pwm = 8 , Prescale = 1 , Compare_b_pwm = Clear_up
Pwmval = 0
'* CONFIG TIMER2 FOR TIME BASE *
Config Timer2 = Timer , Prescale = 1024 , Clear_timer = 1
Compare2 = 155 '10ms @16MHz/1024
Dim Miliseconds As Byte
'* CONFIG USART FOR BACKGROUND RX *
Config Serialin0 = Buffered , Size = 10
Enable Interrupts 'needed for buffered serial
'10ms
If Tifr.ocf2 = 1 Then 'timer sets flag
Tifr.ocf2 = 1 'clearing flag by writing one
If Miliseconds < 39 Then '40ms
Incr Miliseconds
Else
Miliseconds = 0
Toggle Portb.0
A = Inkey()
Select Case A
Case "1"
Button_1 = 0
Print "1_ON"
Else
Button_1 = 1
Print "1_OFF"
Case "2"
Else 'Else
Case "3"
If Pwmval <> 0 Then
Ocr1b = Pwmval
Waitms 500
Button_3 = 0
Print "3_ON"
Else
Button_3 = 1
Print "3_OFF"
Case "4"
'Button for Licht
Button_4 = 0
Print "4_ON"
Else
Button_4 = 1
Print "4_OFF"
Case "5"
' Button for Horn
If A = "5" Then
Toggle Button_5
'Button_5 = 1
Waitms 500
Reset Button_5
'Button_5 = 0
Case "6"
If A = "6" Then
'Waitms 100 :
Case "7"
If A = "7" Then
' Waitms 50 :
Ocr1b = Pwmval + 10
End Select
End |
Have a nice day |
rafael_jimenez
Posted: Thu Nov 28, 2019 7:29 pm Post subject: |
Hello EDC
I'm sorry, but I am in the Hospital where I have had kidney stones, I plan to be home this weekend.
Thank you very much for your answer
Regards |
