Locomotive controller with Bluetooth HC-05
rafael_jimenez
PostPosted: Wed Nov 20, 2019 11:20 am    Post subject: Locomotive controller with Bluetooth HC-05 Reply with quote
Hello friends of the forum,
I'm testing a locomotive with a controller that works with 3.5 volts.
My program works as it is, but I want PWM signals to be controlled faster.
I made an application with MIT App inventor,
could someone please help me the best way to make PWM signals more controllable?
your collaboration is appreciated
[/code]
'** Electric Locomotive Version 1.0 *
'** PORTC 1,2,3,4,5 = Relay
'** PORTC.0 = Led Signal monitor
'** PORTB.2 = PWM for Motor driver
'** Bascom version 2.0,8,1
'**___________________________________________________________________________
$regfile = "m8def.dat"
$crystal = 16000000 '16000000
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 9600
Dim A As String * 2
Dim Pwmval As Byte
Config Portb.0 = Output 'Signal OK
Config Portc.0 = Output ' Main switch
Config Portc.1 = Output 'Emergency Motor Batt. on/Off
Config Portc.2 = Output 'Direction
Config Portc.3 = Output 'Licht
Config Portc.4 = Output ' Horn
Config Portc.5 = Output
Config Timer1 = Pwm , Pwm = 8 , Prescale = 1 , Compare B Pwm = Clear Up ' , Compare A Pwm = Clear Up
'Start Timer1
'Enable Interrupts
Led_blink Alias Portb.0 'led blink Microcontroller loop
Button_1 Alias Portc.0 'relay 1
Button_2 Alias Portc.1 'relay 2
Button_3 Alias Portc.2 'relay 3
Button_4 Alias Portc.3 'Relay 4
Button_5 Alias Portc.4 'relay 5
'Ocr1b = 0
Pwmval = 0
Toggle Portb.0
Waitms 40
If Ischarwaiting() = 1 Then
A = Inkey()
'Main Switch For Modul
If A = "1" Then
If Button_1 = 1 Then 'Master Switch
Button_1 = 0
Print "1_ON"
Else
Button_1 = 1
Print "1_OFF"
'Button Switch Modul
If A = "2" Then
If Button_2 = 1 Then 'If Button_2 = 0 Then ' motor schaalter Bat.
Button_2 = 0 ' Button_2 = 1
Print "2_ON" ' Print "2_ON"
Else 'Else
Button_2 = 1 'Button_2 = 0
Print "2_OFF" 'Print "2_OFF"
'Button for Direction
If A = "3" Then
If Pwmval <> 0 Then
Pwmval = 0 ' set motor to cero
Ocr1b = Pwmval
Waitms 500
If Button_3 = 1 Then ' direction change
Button_3 = 0
Print "3_ON"
Else
Button_3 = 1
Print "3_OFF"
'Button for Licht
If A = "4" Then
If Button_4 = 1 Then
Button_4 = 0
Print "4_ON"
Else
Button_4 = 1
Print "4_OFF"
' Button for Horn
If A = "5" Then
Toggle Button_5
'Button_5 = 1
Waitms 500
Reset Button_5
'Button_5 = 0
'__________________________________
'**** motor control Maxim 3,5.4volt Output
If A = "6" Then
Start Timer1 'timer1 loop
If Pwmval < 192 Then Incr Pwmval 'Fader Motor Up
'Waitms 100 :
Ocr1b = Pwmval '+ 20
If A = "7" Then
If Pwmval > 0 Then Decr Pwmval 'Fader Motor down
' Waitms 50 :
Ocr1b = Pwmval + 10
(BASCOM-AVR version : 2,0,8,1 , Latest : 2.0.8.2 )
PostPosted: Wed Nov 20, 2019 12:39 pm    Post subject: Reply with quote
I think that I tweak some of your serial receiving routines because buffered serial and moving 40ms delay into Timer2 control but Im thinking that some of the rest of code can be better.
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 9600
Dim A As String * 2
Dim Pwmval As Byte
Config Timer1 = Pwm , Pwm = 8 , Prescale = 1 , Compare_b_pwm = Clear_up
Pwmval = 0
'*         CONFIG TIMER2 FOR TIME BASE          *
 Config Timer2 = Timer , Prescale = 1024 , Clear_timer = 1
  Compare2 = 155                                            '10ms @16MHz/1024
  Dim Miliseconds As Byte
'*       CONFIG USART FOR BACKGROUND RX         *
 Config Serialin0 = Buffered , Size = 10
 Enable Interrupts                                          'needed for buffered serial
   '10ms
   If Tifr.ocf2 = 1 Then                                    'timer sets flag
    Tifr.ocf2 = 1                                           'clearing flag by writing one
      If Miliseconds < 39 Then                              '40ms
       Incr Miliseconds
      Else
       Miliseconds = 0
       Toggle Portb.0
      A = Inkey()
      Select Case A
       Case "1"
            Button_1 = 0
            Print "1_ON"
         Else
            Button_1 = 1
            Print "1_OFF"
       Case "2"
         Else                                               'Else
       Case "3"
         If Pwmval <> 0 Then
            Ocr1b = Pwmval
            Waitms 500
            Button_3 = 0
            Print "3_ON"
         Else
            Button_3 = 1
            Print "3_OFF"
       Case "4"
         'Button for Licht
            Button_4 = 0
            Print "4_ON"
         Else
            Button_4 = 1
            Print "4_OFF"
       Case "5"
         ' Button for Horn
        If A = "5" Then
         Toggle Button_5
          'Button_5 = 1
         Waitms 500
         Reset Button_5
          'Button_5 = 0
       Case "6"
        If A = "6" Then
          'Waitms 100 :
       Case "7"
        If A = "7" Then
          ' Waitms 50 :
         Ocr1b = Pwmval + 10
      End Select
Have a nice day Wink
rafael_jimenez
PostPosted: Thu Nov 28, 2019 7:29 pm    Post subject: Reply with quote
Hello EDC
I'm sorry, but I am in the Hospital where I have had kidney stones, I plan to be home this weekend.
Thank you very much for your answer
Regards
