Differential ADC on Atmega88
P_Santos
PostPosted: Wed Nov 27, 2019 1:02 am    Post subject: Differential ADC on Atmega88 Reply with quote
Hello,
I need to connect a device with differential output to the Atmega88 ADC. Never used the ADC differential, I do not know what pins connect as not found any sample code to read the ADC in differential mode.
Gratefull if anyone can help with schematic and sample code
Regards
P_Santos
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.2 )
laborratte
PostPosted: Wed Nov 27, 2019 2:43 am    Post subject: Reply with quote
atmega88 does not have differential inputs on ADC
P_Santos
PostPosted: Wed Nov 27, 2019 6:09 pm    Post subject: Reply with quote
Hello Laborratte,
Thanks for the information, have than will to use an external differential Amp OP
Regards
P_Santos
Paulvk
PostPosted: Thu Nov 28, 2019 4:39 am    Post subject: Reply with quote
Have a look at the MAX1238 I have written code here
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=11496&highlight=adc
Much better than the 10 bit avr adc
Note Also the artwork for a circuit board is there if you want it
it can use the Max1238 or ADC128D818
Regards Paul
P_Santos
PostPosted: Mon Dec 02, 2019 1:05 am    Post subject: Reply with quote
Thank you, Paulvk,
I need a instrumention differential amplifier, now i find the MCP6N11, this device works beetwen 1,7v and 5V and that it's what i need, the board use a 3V battery
Anyone use the MCP6N11 ?
Regards
P_Santos
