Printpix52
Posted: Mon Nov 18, 2019 7:12 pm Post subject: ERROR - CODE EXPLORE |
Hello all!!
When I write 16 * 2 I get an error.
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.2 ) |
Printpix52
Posted: Mon Nov 18, 2019 7:13 pm Post subject: |
When I write 16x2 error disappeared and corrected
Printpix52
Posted: Mon Nov 18, 2019 7:17 pm Post subject: |
Now the other program had them working well and why does it make me wrong? It doesn't let me study well !!
Printpix52
Posted: Mon Nov 18, 2019 7:24 pm Post subject: |
I have compiled today with a different program with version 2.0.8.2 and the problems started and the previous version there was no problem, something very strange 2.0.8.2 .....
Posted: Mon Nov 18, 2019 7:51 pm Post subject: |
Just compile the code and see what Errors the Compiler Displays.
The code Explorer/Errors is very sensitive and Displays alot of false positives.
Posted: Mon Nov 18, 2019 7:54 pm Post subject: |
Printpix52 wrote: | I have compiled today with a different program with version 2.0.8.2 and the problems started and the previous version there was no problem, something very strange 2.0.8.2 |
If you code like you write, then I understand why your compiler is going nuts.
Trying to find out a meaning by splitting the sentence:
Quote: | I have compiled today with a different program with version 2.0.8.2 |
You have compiled with another Bascom 2.0.8.2 on a different computer?
You have compiled different code with the same Bascom 2.0.8.2 on the same computer?
Quote: | and the problems started |
What problems started?
Quote: | the previous version there was no problem |
Does that mean none of your problems, even the unspoken ones, existed in version 2.0.8.1? |
Posted: Mon Nov 18, 2019 8:01 pm Post subject: |
you should start reading the help and the history.txt
And it will also help if you read the forum rules.
You hijack posts, you post unrelated things without actual questions.
This is not a blog where you can dump your stuff.
This is a forum. And when you want help, add sufficient info and be clear about the problem. pictures are a great way to show what you mean but we can not extract code from pictures so you need to include it. _________________ Mark |
Posted: Mon Nov 18, 2019 10:40 pm Post subject: |
Try use CTRL+SPACE for proper syntax. After some word make space, eual sign =, next space and then call for hint CTRL+SPACE
Printpix52
Posted: Tue Nov 19, 2019 12:51 am Post subject: |
hello all!
Quote: | i.dobson:
Just compile the code and see what Errors the Compiler Displays. |
There is no error
Quote: | i.dobson:
The code Explorer/Errors is very sensitive and Displays alot of false positives. |
It is the first time that active code explore is very sensitive.
albertsm:
This is a forum. And when you want help, add sufficient info and be clear about the problem. pictures are a great way to show what you mean but we can not extract code from pictures so you need to include it. |
Sorry and excuse me I was testing the issue of fellow EDC and there was a doubt I stopped and it worked well in 2.8.8.2
EDC:
Clarified and understood thank you very much everyone. |
Printpix52
Posted: Tue Nov 19, 2019 12:58 am Post subject: |
MWS wrote: | Printpix52 wrote: | I have compiled today with a different program with version 2.0.8.2 and the problems started and the previous version there was no problem, something very strange 2.0.8.2 |
Problem solved and thank you very much. |
Posted: Tue Nov 19, 2019 1:42 pm Post subject: |
EDC. Like the clear way you explain it. _________________ Mark |
