Posted: Mon Nov 04, 2019 4:55 pm Post subject: EA DOGM204 nice 20x4 ultraslim display
Hello. I got such a display
It is :
* extremely compact at 66 x 40 mm at the standard font size of 4.8 mm (4 x 10)
* ultra-flat at 2.0 mm without backlight or 5.8 mm including LED backlight
* 4-bit, 8-bit, SPI interface (2-/3-/4-wire) and I²C (2-wire)
* typical power consumption of only 250µA in full operation (LED white backlight as of 3mA)
* easy installation by simply soldering into the board
* A whole range of design variants can be supplied as of single units
* Changing background color
Unfortunatelly I dont have backlight yet so first Im using flashlight and then some Rainbowled`s
Backlight will arrive soon I think.
I have modified "4_anypin.lib" with some needed initialisation, and then anyone can use Bascom`s dedicated functions like Lcd and Locate.
Remember to choose 20x4A because adressess for rows are &H00, &H20, &H40 and $H60
Library and datasheet attached.
Tested on the 3V3 circuit. Not tested with Xmega but oryginally "4_anypin.lib" support Xmega so it should work.
$regfile="m1284def.dat" $crystal=16000000 $hwstack=64 $swstack=16 $framesize=64 Config Submode = New
Hello. A small update.
This LCD`s are great. They have three internal ROM`s of your choice (ROMA, ROMB & ROMC).
By default ROMC is enabled but "non english-japanese" ROM have some cool icons so you don`t need to define it.
Maybe you need more cyrillic characters? no problem!
I wrote a sub that allow you to select rest of ROM`s.
Yes, contrast is great. It is temperature compensated from -20 to +70
