Advice on setting up Eram for an array
snow
PostPosted: Fri Nov 01, 2019 8:02 pm    Post subject: Advice on setting up Eram for an array Reply with quote
Hi
I've got a project on and it will be needing to store data in the eeprom.
What i need to do is store X and Y data in a memory locations so it can be read back in different orders. EG get data from point 17, X=105, Y=236.
I would like to store the information in order EG point 1 to 255. What would the code to undertake this be??
I haven't done a lot with Arrays and EEproms. Is this the best way to achieve this??
Thanks
Snow
snow
PostPosted: Fri Nov 01, 2019 9:01 pm    Post subject: Reply with quote
This is what I've got which works. Is this the recommended way to do this??
'name                     : EEPROM_Testing.bas
'purpose                  : Writing and reading to EEPROM
$regfile = "m48def.dat"                                     ' specify the used micro
$crystal = 8000000                                          ' used crystal frequency
$baud = 19200                                               ' use baud rate
Declare sub StorePosition(W_Point as byte,PosX as integer ,PosY as integer)
Declare sub ReadPosition (R_Point as byte)
Dim X as integer
Dim Y as integer
Dim Point as byte
'---Main---
X=0
Y=100
For Point = 1 to 10                           'Store 10 lots of data into the EEPROM
   X=X+1
   Y=Y+1
   Call StorePosition(Point,X,Y)
Next Point
For Point = 1 to 10                           'Read the 10 lots of data back from the EEPROM
   Call ReadPosition(Point)
   Print "X:";X; " Y:";Y
Next Point
Sub StorePosition(w_Point as byte,posX as integer ,PosY as integer)
Local eeprom_position as byte
   eeprom_position = w_Point * 4                ' Each stored position uses 4 bytes of data
   eeprom_position=eeprom_position-3            ' Don't use EEPROM location 0 as per instructions. This is not realy needed just wastes the first 3 memory
                                                ' locations of the EEPROM if not used
   Writeeeprom posX , eeprom_position           'Use a variable as the pointer to eeprom location
   Incr eeprom_position                         'Skip one byte as the stored data is an integer (2 bytes)
   Writeeeprom PosY , eeprom_position         'Use a variable as the pointer to eeprom location
End Sub
Sub ReadPosition (r_Point as byte)
   eeprom_position = r_Point * 4
   eeprom_position=eeprom_position-3        ' Set the start read point in eerom
   Readeeprom X , eeprom_position         ' Use a variable as the pointer to eeprom location
   Incr eeprom_position                    ' Skip one byte as the stored data is an integer (2 bytes)
   Readeeprom Y , eeprom_position         ' Use a variable as the pointer to eeprom location
End sub
PostPosted: Sun Nov 03, 2019 9:04 am    Post subject: Reply with quote
I think this can be much easier with ERAM and OVERLAY for some four byte variable.
$regfile = "m48def.dat"                                     '4KB FLASH, 1KB SRAM, 256B EEPROM
$crystal = 8000000
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
$sim
'256B/4=64 max cell for four bytes
 Dim Myeeprom(64) As Eram Long
 Dim Mytype As Long
 Dim Myx As Integer At Mytype Overlay
 Dim Myy As Integer At Mytype + 2 Overlay
 Dim N As Byte
 'test write
 For N = 1 To 64
  Myx = N
  Myy = N
  Myeeprom(n) = Mytype
 'test read back
 For N = 1 To 64
  Mytype = Myeeprom(n)
  Print "X=" ; Myx ; " Y=" ; Myy
snow
PostPosted: Sun Nov 03, 2019 9:50 am    Post subject: Reply with quote
Thanks for your input. That makes the code a lot shorter.
One question
Where does the MyType get the address value assigned? When this is sim'd up and the code line 'Myeeprom(n) = Mytype ' is executed
MyType is loaded with the value 65537. Where does this value come from for the overlay address at the start of the EEprom?
Thanks
Snow
PostPosted: Sun Nov 03, 2019 10:13 am    Post subject: Reply with quote
I dont know if I understand your question but value you present is quite expected Very Happy
Value 65537 DEC is 00_01_00_01 HEX. Two times for our Myx=1 and Myy=1. Value of Mytype dont mather cause we watch for two bytes in our order.
I dont know how Bascom handles those adressess for Me but it does Very Happy and I know I can do this that way.
I can gues that for Myx=2 and Myy=2 value of Mytype will be 131 074 Very Happy
