barre code reader et FT232rl how to use ?
PostPosted: Thu Oct 17, 2019 6:25 pm    Post subject: barre code reader et FT232rl how to use ? Reply with quote
Hello to all of you
I would like to use a USB barcode reader with an arduino or an Atmega 1284
I have a sparkfun module FTDI basic with a FT232rl.
The barcode reader returns characters when I plug it directly into my PC so it works.
on the other hand when I connect it in 5v I don't see any variation on the TX line on the scope, even if the reader emits a beep
I would like to retrieve these codes from the AVR with the UART
I attach the schematic of the module
how do I connect the DTR and CTS pins?
I'd try to find the right baud rate.
many thanks to your help
JP Wink [/img]
PostPosted: Thu Oct 17, 2019 6:41 pm    Post subject: Reply with quote
Hi JP,
I don't think that'll work. Your Barcode Reader is a USB slave device that Needs to connect to a USB Host (In you test your PC). The FT232rl is also a USB slave.
If you really want to do that you'll Need a USB Host on your PCB/Connected to the Atmel.
Maybe something like this might work http://www.hobbytronics.co.uk/usb-host/usb-host-board-v2, depending on what the Barcode Reader "tells windows" what it is (USB Flash Drive, USB Keyboard, USB Mouse etc.)
Ian Dobson
hgrueneis
PostPosted: Thu Oct 17, 2019 10:27 pm    Post subject: The season Reply with quote
Hi JP,
about a decade ago I used a barcode reader on a PC. But it plugged in with a split cable into the keyboard connection. So I think it might work with the AT-keyboard interface. Not sure, but you might research that.
I don't think rs232 works with it.
Hubert
hgrueneis
PostPosted: Thu Oct 17, 2019 10:38 pm    Post subject: Reply with quote
Hi JP,
youtobe.com has a few connection examples for barcode readers.
Search for "barcode reader with microcontroller"
Regards Hubert
PostPosted: Fri Oct 18, 2019 9:36 am    Post subject: Reply with quote
Hi Hubert and Ian,
Thanks for your very fast answers.
I will ordered a module hobbytronic and I let you know the result
JP Wink
matjazs
PostPosted: Fri Oct 18, 2019 12:34 pm    Post subject: Reply with quote
Hello.
Maybe you can try with this?
https://www.aliexpress.com/item/32850591519.html?spm=a2g0s.9042311.0.0.27424c4dC5TL8w
Best regards, M.
