Odd compile (lack of) error
njepsen
PostPosted: Thu Oct 10, 2019 5:51 am    Post subject: Odd compile (lack of) error Reply with quote
This typo, arrowed in the code below, compiled without an error, and the only thing that alerted me was that the vertical sub - end sub automatic indentation line, and the one between the If - endif did not get drawn
 sub  do_something()
     do          code
                  code
                  Select Case _min
                          Case 5 To 14
                             exit sub
                         Case 20 To 29
                            exit sub
                         Case 35 To 44
                           exit sub
                         Case Is > 49
                          exit sub
                  End Select
                 if fileCount >0 then
                       tempstr = "sent "+ str(filecount) +" files from SD card"
                      call write_err_message(tempstr)
                 endif      '<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<TYPO
End Sub
and this code ( with the correction to endif ) also compiled ok, but this time the indentation lies were all present and correct.
sub do_something()
      do
                  code
                  code
                  Select Case _min
                          Case 5 To 14
                             exit sub
                         Case 20 To 29
                            exit sub
                         Case 35 To 44
                           exit sub
                         Case Is > 49
                          exit sub
                  End Select
                 end if                                               '<<<<<<<<<<<<<<<<< TYPO FIXED
End Sub
(I'll now go & put my ear defenders on ) :D
Neil
PostPosted: Thu Oct 10, 2019 8:40 am    Post subject: Reply with quote
maybe you think the forum rules do not apply for you?
when posting code, it must be complete, not some fragment that needs work.
when posting, it should be clear what it is you want. is this a question? or you want to share your project? or you reply to someone with help?
And more important, consider who can answer. is it a forum cry for help or should you write to mcs support?
in your case it seems like a question to get an error?
well it is actually there when you check the Code Explorer
Why not at compile time? Well it was there some versions ago but lot of users like to use endif instead of end if. So the compiler accepts it. Like always, you can not make everybody happy.
The IDE can reformat your code when you type endif it will change into End If.
