Posted: Mon Sep 23, 2019 7:42 am Post subject: |
AdrianJ wrote: | Compared to that, programming via the bootloader is a minor part of the job. |
An unnecessary job, if you can do it at once. Except this is your only test of UART-functionality, then it's a weak one.
Quote: | complex series of tests | does not sound like that.
If your argument however would be to test overall loader functionality, I'd give you a point.
It's up to you how to test your product, but as the issue was:
Quote: | I have been trying unsuccessfully to incorporate a bootloader at the time of programming the chip |
discussing your preferences is kind of moot.
It would be more interesting to learn about the outcome of:
Quote: | cut out manually &F000 * 2 bytes = 122880 bytes from start of the bin and save it as your loader.bin
By including this modified bin with the help of $BOOT and $INC at &hF000 you will get a working solution. |
Posted: Mon Sep 23, 2019 11:52 pm Post subject: |
@MWS
I will let the OP decide whether what I suggested is useful for what he wants to do. _________________ Adrian Jansen
Posted: Tue Sep 24, 2019 5:17 am Post subject: |
AdrianJ wrote: | I will let the OP decide whether what I suggested is useful for what he wants to do. |
The TO will surly appreciate that you allow him to decide about your suggestion. |
njepsen
Posted: Tue Sep 24, 2019 10:53 pm Post subject: |
MWS - my apologies for not replying to you earlier - ive been away for a few days on an installation. A booloader in assembler !!?? I have not done any assembly since playing with a 6502 about 35 yrs ago - and i was struggling then. (In fact i still have Leventhals book on" 6502 assembly programming" and a date in the fly says jan 1985.) So an assembly code bootloader is beyond me in skill, knowledge and time. BUT I do like your great idea
Quote: |
Another idea would be - in case the bootloader itelf is seldom altered - to create your loader regularly, then cut out manually &F000 * 2 bytes = 122880 bytes from start of the bin and save it as your loader.bin
Using a hex-editor this is done in less than a minute. |
I do not change the bootloader. What I have been doing is what Adrian described ( hi Adrian) - I program the BL using hardware then load the main using an Sd or by programming it over the air. That way i know that part of it is working. Then after running function test program which tests all I/O and uarts, i run several boards for 2 weeks fully live. But it would be great to be able to program the BL and the main in one hit. I will try your suggestion and get back to the forum. _________________ Neil |
njepsen
Posted: Wed Sep 25, 2019 12:57 am Post subject: |
Well - I programmed my normal BL into a chip, and ran it to make sure it was working correctly . On examination with my programmer, the chip was empty except for 1E000 and above as expected. I then pulled off the entire flash using the avr-usb embud programmer and saved it as a hex file. I then deleted everything from 0000 to 1E000 with a hex editor (PSad) and re-saved it as a hex file. I then pulled the file into the buffer in the programmer and saved it as MWSBL.bin
I then attached the following to the end of my main.bas
lots of code
$boot = &HF000
$inc BL , nosize , "j:\Dropbox\projects\MWSBL.bin" |
when I ran the compiler i got:
Quote: |
Error:344 Line 7713 Program will overwrite bootloader[122880 too long] .... etc
| because my bin file is 128k, which is too long.
The problem i am having trouble with is saving the hex file ( with the relative branching in it) to bin for the $inc instruction. _________________ Neil |
Posted: Wed Sep 25, 2019 9:10 am Post subject: |
njepsen wrote: | A booloader in assembler !!?? |
Open boot.bas from the samples section and tattaaa, there it is, a bootloader in assembler.
I did notice you work with a SD-card loader, so it was clear to me that assembler won't work for you.
But then, if I write something, I think about someone else will read it and thus it's good to have this issue addressed and explained why relocatable ASM code works, while others won't.
Quote: | But it would be great to be able to program the BL and the main in one hit. |
That's what I thought too and it was the original topic.
Adrian's message is surly valid in its own context, but has no connection with the technical question: Can I do it? If yes, how can it be done?
That's what I wanted to discuss here, and not Adrian's message of Do not drive over 40mph within city limits!, while the question was How do I drive my car safely at 140mph on a closed race circuit?
Quote: | I then pulled off the entire flash using the avr-usb embud programmer and saved it as a hex file. I then deleted everything from 0000 to 1E000 with a hex editor (PSad) and re-saved it as a hex file. I then pulled the file into the buffer in the programmer and saved it as MWSBL.bin |
You've meant 1E000 bytes, or to address :10E00000 in the hex-file?
For the first, you've created a mess with this approach, for the second the reconversion will again add fill-bytes.
Remember, a bin-file does not contain addresses, if you want to make something start at word address &h100, the void before must be filled with padding bytes.
I do also not understand why you use a hex-editor for editing a hex-file, which is a standard ASCII text file.
This I wrote
Quote: | Using a hex-editor this is done in less than a minute. |
because you have to work on a binary file, where a hex-editor is the correct choice.
I suggest to use the bin-file the compiler spits out, which proves working after you've flashed it.
You can also take intermediate steps if you like, but then convert the downloaded bootloader.hex completely into bootloader.bin, do not edit the hex.
Then open the bootloader.bin within your hex-editor and delete &h1E00 bytes.
You'll know exactly where the bootloader starts, as you will notice the sequence:
Code: | FF FF FF FF 8F EF 8D BF |
where FF is empty space and 8F EF the first bootloader opcode, which translates to !LDI r24, &hFF.
8F must occupy the first position within the binary, all leading FF's needs to be removed.
Save and include this bin with $INC and it will work as desired. |
Posted: Wed Sep 25, 2019 11:50 pm Post subject: |
Ok, another way to achieve the target of being able to load both main and bootloader together is to use AVR Studio. That has the facility to load several hex files, eg bootloader, and main, into one chip. Once you have that, you can use Studio to read the entire flash back into another hex file. This becomes your master.
Saves a lot of fooling around patching bits of hex together.
AVR Studio is a bit of a beast.
Maybe some other programmers offer the facility to do the same thing. Note that many programmers do an auto chip erase before loading a hex file. That will wreck things. You need the facility to do one erase, then load several files separately. _________________ Adrian Jansen
njepsen
Posted: Wed Sep 25, 2019 11:53 pm Post subject: SUCCESS !!! |
MWS,
thank you for your patience. We (I say we, but really you) got there in the end. My problem was not the editing, which i was doing correctly as it is very easy with PSPad to see where the BL starts, but when & how I saved it. Opening the original .bin file using a 'hex' editor was the secret; I didn't actually try editing a .bin file with a hex editor.
I understand the issue (now) that is due to the BL assembler using relative addressing.
On my first trials, I got an err msg "Wrong Flash Size" when I ran the BL, but this was because I had the $boot & $Inc instructions after the "End" which was easy to diagnose.
So here is a step by step of what worked:
1. Test the bootloader (myBL.bas for example) until it is working when uploaded to the chip normally with the programmer.
2. Pull the myBL.bin file that the programmer generates into a hex editor like PSPad
3. Using edit/cut, delete all the FF from the beginning of the file until the start of the actual bootloader, which is easy to find (it starts at byte addr 1E000 for the atmega1284) being sure to leave the beginning of the BL code, which starts with 8F EF
4. Save as mynewBL.bin or whatever.
5. At the end of the main program before the "end" statement, include this code:
$boot = &hF000 ' boot reset word addr from data sheet
$inc BL,nosize,"mynewBL.bin" 'the full pathway is needed
Thanks again MWS for your help in getting this working.
njepsen
Posted: Thu Sep 26, 2019 4:17 am Post subject: |
Addendum
The earlier error "Wrong Flash Size" was due to the fact that in my BL (which is a clone of Vogel Franz Josef's code) there is code on line 280 that checks the size of the "main". Because my "main now includes the length of the bootloader, this will cause an error.
The position of End was a red herring.
This code:
Lfilelen = Lfilelen + Blinebytes
If Lfilelen > Loadsize Then
Print #1 , " Se" ' Wrong Flash Size
Berror = 1
Exit Do
End If |
should be changed by deleting the first line of code, to:
' Lfilelen = Lfilelen + Blinebytes
Berror = 1
Exit Do
End If |
Posted: Thu Sep 26, 2019 6:41 am Post subject: |
njepsen wrote: | that in my BL (which is a clone of Vogel Franz Josef's code) there is code on line 280 that checks the size of the "main". |
Does that tell you feed your bootloader via SD-card with the now combined bin?
You should be careful disabling security measures, as you won't like the bootloader trying to overwrite itself. |
njepsen
Posted: Tue Oct 08, 2019 4:43 am Post subject: |
Hi MWS,
sorry - its taken me a week to get back to this and do some more testing.
There is a problem, and it caused by the fact that Josef's bootloader uses filelen(filenamehex) as part of checking that the file is not too big; and of course the main (with $boot = &HF000 and $Inc BL,nosize, name ) is now suddenly very large and the line "flash wrong size" of the bootloader will think that the BL section is being overwritten and stop. (excuse the anthropomorphism)
So - because I have over 70 units in the field with this bootloader installed (copied below), I wont be able to use your new cunning method (that works perfectly in the shop), because they will all stop at &HF000*2.
thinks ----Unless i can bootload the new bootloader using the old bootloader, but I can't because the old bootloader thinks the new BL is 363855 bytes long- that's the hex file length. still thinking ...
' Bootloading from MMC/SD or CF
' (c) Vögel Franz Josef / MCS Electronic
' Bootloader works with HEX or/and BIN files from a Mass storage device
' supported by AVR-DOS (http://members.aon.at/voegel or www.mcselec.com)
' DOSBOOT 3
' following features are implemented:
' - check a Pin for activating bootloading
' - Check for file "BOOT.BIN" in root directory
' If Exists
' - Check File-length to fit in Program-area
' $prog &HFF , &HCE , &HD6 , &HFF ' generated. Take care that the chip supports all fuse bytes.
' - Program Content of "BOOT.BIN" to Flash
' - Rename File "BOOT.BIN" to "BOOTDONE.BIN"
' - Leave Bootloader and start Main Program
' - Check for file "boot.hex" in root directory
' If Exists:
' - Check the Hex-File(record-format) with file-length
' - program flash with content of the Hex-File
' - Rename File "BOOT.HEX" to "BOOTDONE.HEX"
' In Case that a checked point fails, the main program is started immediately
' The program to flash must be stored either in HEX-Format (BOOT.HEX) or in BIN-Format
' (BOOT.BIN), in the root Directory of the card at start time.
' The Bootloader has a size of appr. 7300 Bytes, so Boot-loader size of 8192 Bytes
' has to be set.
' Set bootloader-start to &HF000 at M128 and &H7000 at M64,&HF000 for M1284P
' Output of bootloader on RS232
' B ... Boot loader started
' C ... Check Card
' D ... Init DOS File System
' d = error reading DOS file system
' e## . Error occured with errorcode in hex-format(##)
' F ... Checking HEX-File
' I ... DOS-Error during file-opening
'L Line error
' M ... Start of Main program
' N ... No boot file found
' P ... Programming Flash
' R ... Renaming file
' S ... Size-Error of Flash-File
'sd = sd init error
$prog &HFF, &HC7, &HD0, &HFD
Dim Starterr As Byte
Starterr = Peek(0)
Writeeeprom Starterr , 80 'save MCUSCR (Register 0) to eeprom
Starterr = 125
Writeeeprom Starterr , 100 'confirm that BL is present
$regfile = "m1284pdef.dat"
Const Loaderchip = 1284
$loader = &HF000 ' 4096 words, starts at HF000
Const Maxwordbit = 7 ' Z7 is maximum bit '
Const Loadsize = &HF000 * 2 ' highest Number of bytes to load
$crystal = 9830400
$hwstack = 128
$swstack = 128
$framesize = 128
' Define here name of Hex-File
Const Filenamehex = "Boot.hex"
Const Filenamehexdone = "BootDone.hex"
Disable Interrupts
Open "comc.3:38400,8,n,1" For Output As # 1 'jepsen debug port
Print # 1 , "start BL" ' B = Boot-loader Started
Waitms 500 ' Time for Card to settle
Dim Btemp1 As Byte
Print # 1 , "chk SD" 'Checking SD card
'ver boot2
$include "config_mmcsd_hc.bas" 'set up the high capacity SD card comms ver boot2.1
' Check success of card initializing
If Gbdriveerror <> 0 Then
Print # 1 , "sd err" 'sd init error
Print # 1 , "e" ; Hex(gbdriveerror ) ' Error during card initializing
Goto Startmain
' Include AVR-DOS Configuration and library
$include "Config_AVR-DOS_boot.BAS"
Btemp1 = Initfilesystem(1)
' use 0 for drive without Master boot record
If Btemp1 <> 0 Then
Print # 1 , " file sys err" ; Hex(btemp1 ) ' Error at reading file system
Goto Startmain
Const Maxword =(2 ^ Maxwordbit ) * 2 '128
Const Maxpages = Loadsize / Maxword
Const Fn = 10 ' file-number
'Dim the used variables
Dim Strline As String * 80 ' input line from file
Dim Blinebytes As Byte ' data bytes in hex-line
Dim Blinedataposition As Byte ' first/current position of hex-data in line
Dim Blineendposition As Byte
Dim Blinestatus As Byte
Dim Blinelen As Byte
Dim Strtemp As String * 4
Dim Berror As Byte ' error byte
Dim Strname1 As String * 12
Dim Strname2 As String * 12
Dim J As Byte , Spmcrval As Byte ' self program command byte value
Dim Bprog As Byte
Dim Z As Long 'this is the Z pointer word
Dim Vl As Byte , Vh As Byte ' these bytes are used for the data values
Dim Wrd As Word , Page As Word 'these vars contain the page and word address
Dim Bcrc As Byte
Dim Buf (128) As Byte
Dim Bufpointer As Byte
Dim Lfilelen As Long
Disable Interrupts 'we do not use ints
'---- Start Boot loader
'Check if boot.hex is there
Lfilelen = Filelen(filenamehex )
If Lfilelen > 0 Then
Gosub Flashhex
Print # 1 , "No hex file" 'No boot file found
Startmain :
Print # 1 , "Start Main" 'start Main
Goto _reset
Flashhex :
' 1. check Hex-File
Bprog = 0 ' check Intel Hex File
Print # 1 , "chk hex" ' Checking hex file
Gosub Bootload
' 2. Flash from Hex-File
Bprog = 1 ' program flash
Print # 1 , "Prog flash" 'Programing Flash from Hex file
Gosub Bootload
#if Varexist ( "FileNameHexDone")
Strname1 = Filenamehex
Strname2 = Filenamehexdone
Kill Strname2
Print # 1 , "Rename hex" 'Renaming boot.hex file
Name Strname1 As Strname2
#endif
Goto Startmain :
' Boot loader part (same for File-Checking and Flashing)
Bootload :
Open Filenamehex For Input As #fn
If Gbdoserror > 0 Then
Print # 1 , "DOS err" ; Hex(gbdoserror ) 'I = DOS error during file opening
Berror = 1
Goto Here :
Page = 0
Wrd = 0
If Bprog = 1 Then
Spmcrval = 3 : Gosub Do_spm ' erase the first page
Spmcrval = 17 : Gosub Do_spm ' re-enable page
Berror = 0
Bufpointer = 1
Blinebytes = 0
Lfilelen = 0
If Blinebytes = 0 Then
Gosub Loadhexfileline
Select Case Blinestatus
Case 0 ' read normal data line
Print # 1 , " wrong flash size" ' Wrong Flash Size
Berror = 1
Exit Do
For Blinedataposition = Blinedataposition To Blineendposition Step 2
Strtemp = Mid(strline , Blinedataposition , 2)
Btemp1 = Hexval(strtemp )
Buf (bufpointer ) = Btemp1
Incr Bufpointer
If Bufpointer > 128 Then
Gosub Writepage
Bufpointer = 1
Decr Blinebytes
Case 1 ' address extend record
Blinebytes = 0 ' prepare for reading next line
Case 2
' EOF Line read
If Bufpointer > 1 Then
Gosub Writepage
If Wrd > 0 Then
Wrd = 0
Spmcrval = 5 : Gosub Do_spm
Exit Do
Case Else ' Error
Print # 1 , "Line err " 'Line error
Berror = 1
Exit Do
Close #fn
Here :
If Berror > 0 Then
Goto Startmain ' restart in case of error
Loadhexfileline :
If Eof(#fn ) <> 0 Then
Blinestatus = 8 ' no regular end of File
Line Input #fn , Strline
If Gbdoserror <> 0 Then
Blinestatus = 7 'DOS error
Strtemp = Mid(strline , 1 , 1) ' check for starting ":"
If Strtemp <> ":" Then
Blinestatus = 6
' Check Checksum
Blinelen = Len(strline )
Bcrc = 0
For Btemp1 = 2 To Blinelen Step 2
Strtemp = Mid(strline , Btemp1 , 2)
Bcrc = Bcrc + Hexval(strtemp )
If Bcrc <> 0 Then
Blinestatus = 9 'checksum error
' Number of bytes
Strtemp = Mid(strline , 2 , 2)
Blinebytes = Hexval(strtemp )
If Blinebytes > 0 Then
Blinedataposition = 10
Btemp1 = Blinebytes * 2
Blineendposition = Btemp1 + 8
' Type of Record
Strtemp = Mid(strline , 8 , 2)
Select Case Strtemp
Case "00" ' normal data record
Blinestatus = 0
Case "01" ' address extend record (> 64KB)
Blinestatus = 2
Case "02" ' EOF record
Blinestatus = 1
Case Else ' unknown record type (Error?)
Blinestatus = 5
'write one or more pages
Writepage :
For J = 1 To 128 Step 2 ' we write 2 bytes into a page
Vl = Buf (j ) : Vh = Buf (j + 1) ' get Low and High bytes
Spmcrval = 1 : Gosub Do_spm ' write value into page at word address
Wrd = Wrd + 2 ' word address increases with 2 because LS bit of Z is not used
If Wrd = Maxword Then
Wrd = 0 ' Z pointer needs wrd to be 0
Spmcrval = 5 : Gosub Do_spm ' write page
Page = Page + 1 ' next page
If Page <= Maxpages Then ' avoid to erase first page of bootlaoder
Spmcrval = 3 : Gosub Do_spm ' erase next page
Do_spm :
Z = Page 'make equal to page
Shift Z , Left , Maxwordshift 'shift to proper place
Z = Z + Wrd
If Bprog <> 1 Then
Bitwait Spmcsr.0 , Reset ' check for previous SPM complete
Bitwait Eecr.1 , Reset
'wait for eeprom 'add word
! lds r30, {Z }
! lds r31, {Z +1}
#if Loaderchip = 1284
! lds r24, {Z +2}
! sts rampz,r24 ' we need to set rampz also for the M128
#endif
! lds r0, {vl } 'store them into r0 and r1 registers
!lds r1, {vh }
Spmcsr = Spmcrval 'assign register
!spm 'this is an asm instruction
nop
nop
Posted: Tue Oct 08, 2019 3:51 pm Post subject: |
njepsen wrote: | its taken me a week to get back to this and do some more testing. |
No problem.
Quote: | Unless i can bootload the new bootloader using the old bootloader, but I can't because the old bootloader thinks the new BL is 363855 bytes long- that's the hex file length. still thinking ... |
If you would have mentioned this info in your entry post, i.e. that you plan to use the combined hex out in the field via existing bootloader, then I would have told you at the start: It won't work.
For sure it is possible to adapt your loader the way it stops before overwriting its bootloader-section, but then you first have to flash this new loader via ISP.
Within this controller architecture - as well it is not completely impossible to update the bootloader by itself - it's rather complicated and needs space for two loaders within the available bootloader range.
Think about how a bootloader works, it does so by overwriting each page by page-erase and then refilling it.
If you have one loader which resides at &hF000 and the loader erases this page, it starts to erase itself, it finally leads to the point, where the lately executed opcode affected by a page erase is erased together with the following opcodes, leaving the program counter in a void with random further behavior.
It would be possible for a loader to replace itself, but then you need a second loader with same capabilities like the first loader, the first loader would hand over code execution to the second loader, which then flashes main code including the then new first loader.
A few options how this second loader can be installed:
- flashed at workshop via ISP
- first loader creates a duplicate of itself, this needs relocatable loader code
- it comes with the hex-file on SD-card, the first loader's first job is then to flash the second loader from hex-file
No matter how the second loader is installed, after it is done successfully the first loader forwards code execution to the second loader, which then will flash the main code and finally replace the first loader.
Is it feasible within your setup? I doubt, your SD-card loader is pretty big in size, you need a double amount of loader space.
Both loaders must reside within the bootloader area, as commands altering flash can be only executed from there.
Does this help you with your current situation? No, as your installations only have the original loader installed, a new loader with capabilities to replace itself needs to be flashed via ISP first.
Is such a new loader advisable? Maybe, maybe not. If the loader has the ability to manipulate itself, it is as well able to commit suicide. I can think of security measures to protect against a dead loader, but this makes it even more complicated.
What was your initial intention? Did you like to create only one hex-file for both production and service?
Or was it what I've described, to also update the loader in one go? |
sentinel
Posted: Wed Jun 15, 2022 7:24 am Post subject: |
Old thread, but I'm interested to know if any further progress has been made on flashing bootloader and main code at the same time.
Adrian, you mentioned that AVR Studio 7 can do this, and since this is what I use for production programming, I'd love to know more about how it's done. I've looked though the options, but can't see where that's possible.
When you have to flash 300 chips at a time, any time saved mounts up. |
Posted: Wed Jun 15, 2022 11:06 am Post subject: |
Im doing this often.
First you must compile your bootloader with "Bootonly" option...
.. then attach generated BIN into main application.
I can simply disable this for new program versions loaded by bootloader USART`s/SDCARD`s.
If you program from BASCOM IDE you can even set fuses (at programming time) like disable CKDIV8/set external crystal and protect your code by setting LOCK BYTE.
Where when you program externally by BIN or HEX you must do this yourself Im lazy
sentinel
Posted: Wed Jun 15, 2022 1:41 pm Post subject: |
Thanks for the quick reply, EDC.
After searching various forums, your method looks almost too straightforward to be true.
I'll give it a try with AVR Studio 7 and an STK500.
Thanks again. |
