Problem Understanding CONFIG SUBMODE = NEW
njepsen
PostPosted: Fri Sep 13, 2019 8:38 am    Post subject: Problem Understanding CONFIG SUBMODE = NEW Reply with quote
Historically. I have been using submode = old, and I am reluctant to change because my program is 8000 lines long, with many units in the field.
But I am considering it.
I have a question- the help for submode says
When working with $include files, this requires that you insert an $include file with the SUBS/FUNCTIONS at the end of your code, and that you insert an $include file with the DECLARE statements at the start of your code.
Does this mean that when using submode = old, there needs to be TWO iterations of $include? One at the end of the code and one with the declarations?
This is confusing because the help for $include says
An include file will only be included once, even if you include it multiple times.
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.8.2 )
Neil
PostPosted: Fri Sep 13, 2019 9:04 am    Post subject: Reply with quote
it means what it says.
But there are 2 different include files. Like this :
$regfile...
$include "myheaders.inc"
your code
$include "mysubs.inc"
myheaders.inc would have content like :
declare sub test()
and mysubs.inc would have the implementation like:
sub test()
end sub
When using submode=new, there is no need for a declaration as they are extracted from the implementation. And you must put the implementation before the main code since otherwise the calling code has no idea about these subs and functions.
In that case the code will end up after your code and only the used modules are included. in the old way, the code ends up where you put it.
For that case it is needed that the implementation goes behind the code. and since the calling code has no idea in that case, you must put the declaration in front.
Otherwise consider this :
your code
sub test
nop
end sub
the main code would walk into the sub and get a return without calling.
submode=new will remove that code and put it automatic behind your code and only the modules that were actually used.
njepsen
PostPosted: Fri Sep 13, 2019 9:57 pm    Post subject: Reply with quote
Thankyou mark for taking the time to explain that.
your code
sub test
nop
end sub
and I dont understand this in the context that my code ( which I assume is what most people do) is this:
declarations etc
   my code
   call subs & functions
sub()
end sub
sub()
end sub
function
end function
etc
end
[/code]
Neil
