Bascom Terminal Emulator malfunction ? Win 10 ?
autoguider
PostPosted: Wed Sep 11, 2019 9:54 pm    Post subject: Bascom Terminal Emulator malfunction ? Win 10 ? Reply with quote
Dear All,
I cannot get the build in Terminal emulator operating. I am running a 328 p on an Arduino UNO R3 hardware environment. I removed the Arduino bootloader and installed the MCS. Running very well.
The 328 p send messages to the PC that I can document e.g. with Putty. PC runs on Win 10 64 bit.
The Bascom Terminal emulator ran one tim and showed huge letters.
I restarted Bascom with the result that I have a yellow vertical line on the left hand side flickering.
Resizing of the window did not help.
A good advice is highly appreciated.
best regards
Christian
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.2 )
KenHorse
PostPosted: Thu Sep 12, 2019 6:46 pm    Post subject: Reply with quote
I've noticed that the Terminal Window background is black when you first bring it up but does change to the selected background color if you clear it
autoguider
PostPosted: Thu Sep 12, 2019 10:51 pm    Post subject: Reply with quote
I have the blue background color.
In the window I do not see the data sent from the MCU
There is a vertical yellow line on the right hand side of the terminal emulator window e.g. after clearing the window.
But no data.
PostPosted: Fri Sep 13, 2019 9:05 am    Post subject: Reply with quote
either configure properly, or reset the settings. or update.
in this cases a small screen shot will help to show what you mean.
KenHorse
PostPosted: Fri Sep 13, 2019 4:06 pm    Post subject: Reply with quote
3 screenshots
1st is right after opening Terminal Window
2nd is after some serial data is received
3rd is right after CLEAR is done
Win 10, 64 bit Home Edition, Bascom 2.0.8.2
PostPosted: Fri Sep 13, 2019 7:11 pm    Post subject: Reply with quote
that is odd. for me it is blue all the time.
can you send the xml settings file? (zipped) so i can check with your settings?
KenHorse
PostPosted: Fri Sep 13, 2019 7:21 pm    Post subject: Reply with quote
Which xml file? I only seem to have ones in the PINOUT directory
Evert :-)
PostPosted: Fri Sep 13, 2019 10:43 pm    Post subject: Reply with quote
Click on help, then about, then on the link left of app data dir.
Mark needs the bascom-avr2082.xml file.
KenHorse
PostPosted: Fri Sep 13, 2019 10:57 pm    Post subject: Reply with quote
Ahh thanks
It's attached
PostPosted: Tue Sep 17, 2019 9:56 am    Post subject: Reply with quote
ok, i see. you are using vt100 emulation. with your settings i get the same black screen.
i changed it.
