Function added to OLED library 'glcdSSD1306-I2C.lib'
O-Family
PostPosted: Thu Dec 06, 2018 8:24 am    Post subject: Function added to OLED library 'glcdSSD1306-I2C.lib' Reply with quote
The following functions have been added to the I2C OLED display library "glcdSSD1306-I2C.lib".
1. Added option to rotate display 180 degrees.
Const Ssd1306_rotate = 1 'Display rotation. [connection cable is lower side = 0, upper side = 1]
2. Control byte added to the "GLCDCMD" instruction.
Normal/Inverse Display [A6:Normal , A7:Inverse]
Display ON/OFF [AE:OFF(sleep mode) , AF:ON(normal mode)]
3. Contrast can be changed.
_contrast = 0 : Glcdcmd &H81 'Change contrast of the OLED [0:dark - 255:bright]
4. Underline option added to the "LCDAT" instruction. [2:Solid , 3:dotted]
'                       SSD1306-I2C_V2.BAS
'                     (c) MCS Electronics 1995-2015
'          Sample to demo the 128x64 I2C OLED display [V2]
$regfile = "m88pdef.dat"
$hwstack = 32
$swstack = 32
$framesize = 32
Config Clockdiv = 1                                         ' make sure the chip runs at 8 MHz
Config Scl = Portc.5                                        ' used i2c pins
Config Sda = Portc.4
Config Twi = 400000                                         ' i2c speed
I2cinit
$lib "i2c_twi.lbx"                                          ' we do not use software emulated I2C but the TWI
$lib "glcdSSD1306-I2C_V2.lib"                               ' override the default lib with this special one
#if _build < 20784
  Dim ___lcdrow As Byte , ___lcdcol As Byte                 ' dim these for older compiler versions
#endif
Dim _contrast As Byte                                       ' Contrast value of OLED. [0-255]
'Const Ssd1306_rotate = 1                                    ' Display rotation. [connection cable is lower side = 0, upper side = 1]
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
Setfont Font8x8tt                                           ' select font
   Lcdat 1 , 1 , "BASCOM-AVR"
   Lcdat 2 , 10 , "1995-2015"
   Lcdat 3 , 5 , "MCS Electronics" , 1                      ' Optional invert
   Lcdat 5 , 1 , " ABCDefg012345678 " , 2                   ' Optional solid underline
   Lcdat 7 , 1 , " ABCDefg012345678 " , 3                   ' Optional dotted underline
   Wait 3
   Glcdcmd &HA7                                             ' Normal/Inverse Display [A7:Inverse]
   Wait 3
   Glcdcmd &HA6                                             ' Normal/Inverse Display [A6:Normal]
   Wait 3
   _contrast = 0 : Glcdcmd &H81                             ' Change contrast of the OLED [0:dark - 255:bright]
   Wait 3
   _contrast = 255 : Glcdcmd &H81                           ' Change contrast of the OLED [0:dark - 255:bright]
   Wait 3
   Glcdcmd &HAE                                             ' Display ON/OFF [AE:OFF(sleep mode) , AF:ON(normal mode)]
   Wait 3
   Glcdcmd &HAF                                             ' Display ON/OFF [AE:OFF(sleep mode) , AF:ON(normal mode)]
   Wait 3
   Showpic 0 , 0 , Plaatje
   Wait 3
$include "font8x8TT.font"                                   ' this is a true type font with variable spacing
Plaatje:
   $bgf "ks108.bgf"                                         ' include the picture data
PostPosted: Sun Dec 09, 2018 1:38 pm    Post subject: Reply with quote
Thanks for adding these useful options and sharing them Very Happy
BoA
PostPosted: Tue Jan 15, 2019 5:11 pm    Post subject: Reply with quote
Thanks a lot... it work .. Wink)
mrak
PostPosted: Mon Sep 09, 2019 11:03 pm    Post subject: Library support for two SSD1306 displays on I2C bus Reply with quote
The SSD1306-I2C displays enable configuration to have two devices on the same I2C bus under different addresses. Does the current "glcdSSD1306-I2C.lib" can be configured for such a setup? If no, do you plan to include such functionality?
O-Family
PostPosted: Tue Sep 10, 2019 9:22 am    Post subject: Reply with quote
I think that is possible by adding and modifying the library.
I will consider a fix when I have time.
mrak
PostPosted: Tue Sep 10, 2019 4:23 pm    Post subject: Library support for two SSD1306 displays on I2C bus Reply with quote
That would be excellent!
Users could get the most out of the "glcdSSD1306-I2C.lib" library and enjoy the experience of having full capability provided by two SSD1306 displays working in pair when one display is insufficient, like in my project.
PostPosted: Tue Sep 10, 2019 11:39 pm    Post subject: Reply with quote
There are also I2C switces that enable multiple devices with the same address on a buss
I am using one with two ADCs that only have one address.
Regards paul
