Posted: Fri Jul 19, 2019 1:30 pm Post subject: |
six1 wrote: | i'm not sure, if i'm understanding you the right way... |
I for once understood him, he wants to provide
Quote: | Month = 7
Year = 19
DoW = 1 (Tuesday)
n'th DoW = 4 |
With this data my code puts out:
Quote: | Requested 4. Tuesday is the 23.07.19 |
In case of invalid n'th DoW
Quote: | DoW = 3 (Thursday)
nt_dow = 5 |
my code spits out:
Quote: | Requested 5. Thursday is invalid |
Your code does it exactly the other way around.
Posted: Mon Jul 22, 2019 8:48 am Post subject: |
Please stick to the topic. You have the option to post or not. A post should be intentionally helpful and about the code/problem.
--- added the next day---
ok, the above i wrote which was clear so i thought. but to my amazement, i found a lot of posts after it. they did not contribute to the problem. I even read some really bizarre things.
i really have no time to read each posting. if you have concerns, send an email to support.
I know that some members write in a way that others dislike. Either because there is not enough info, or no code that was tried, or the way words are used.
I read and re-read some topics and indeed some are on the edge. Others are over it and i delete them.
I know for some it is boring, but please stick to the topic. It is a lot of work to remove and edit/moderate posts.
There are plenty of other fora where you can write about anything.
The main purpose of this forum is that users can help each other.
Some members have earned some credit over the years because of valuable contributions. i need to weight that all in. It is work that i do not like because of odd accusations i get.
To be clear, there is only one MCS baby and that is BASCOM
Normally i would remove the whole topic but since it contains also good info, i let it be.
Ok, back to programming, or risk a ban. _________________ Mark
six1
Posted: Tue Jul 23, 2019 6:14 am Post subject: |
in consideration of Mark's wish to be on topic:
@KenHorse
i'm out of time, but i will make a demo Function for you, which will give you back the nth repetition of a Weekday by given month and year. It can take a while...
and of course it costs nothing. What is a forum for? _________________ For technical reasons, the signature is on the back of this message. |
six1
Posted: Tue Jul 23, 2019 10:40 am Post subject: |
Hi KenHorse,
since I have little time at the moment, it should give you an idea of how it works.
Feel free to adapt to your needs.
Code: |
$regfile = "m8def.dat" ' specify the used micro
Config Clock = Soft
Config Date = YMD , Separator =.' ANSI-Format
dim dateArr(6) As Byte
dim gd as byte, b as byte
dim wday as byte, repetition as byte, month as byte, year as byte, Strweekday as string * 10
declare Function repetition_of_day( byval wday as byte, byval repetition as byte, byval month as byte, byval year as byte) as byte
$sim
'main
for b = 1 to 12
' Get Day from 3rd repetition from JAN to DEC 2019
' in case result is "0", it is no valid Result!
wday = 6 ' 0-6 0=Monday
repetition = 3 ' nth repetition of Day
month = b
year = 19
gd = repetition_of_day( wday, repetition, month, year)
if gd > 0 then
Strweekday = Lookupstr(wday , Weekdays)
print "Search: repetition #";str(repetition);" of ";Strweekday;" in ";str(month);"-20";str(year);" is ";str(gd);"-";str(month);"-20";str(year)
else
print "Search: repetition #";str(repetition);" of ";Strweekday;" in ";str(month);"-20";str(year);" is not in month Range"
end if
next
end
'end of main
' Search: repetition #3 of Tuesday in 12-2019 is 17-12-2019
' Search: repetition #3 of Thursday in 11-2019 is 21-11-2019
' wday = 0 to 6, Monday starts with 0
' repetition = nth repetition of Weekday "wday"
local fwom as byte, ldom as byte, hb as byte, foow as byte, Lsyssec As Long
dateArr(1) = 0 'sec
dateArr(2) = 0 'min
dateArr(3) = 1 'hour
dateArr(4) = 1 'day
dateArr(5) = month 'month
dateArr(6) = year 'year
' get first Weekday of month
Lsyssec = Syssec(dateArr(1))
fwom = DayOfWeek(lsyssec)
' getting last day of month
' 1) get first day from following month
if month = 12 then
dateArr(5)=1
incr dateArr(6)
else
incr dateArr(5)
end if
' 2) substract one Day, so we've last day in month
Lsyssec=Lsyssec-86400
dateArr(4)=Date(Lsyssec)
' 3) get last Day of Month
ldom=dateArr(4)
' calculate Day of first occurence of wday (foow) in month
if fwom <= wday then
foow = wday - fwom
incr foow
else
foow = wday + 7
foow = foow - fwom
incr foow
end if
' now "foow" holds the first Weekday we're searching for as Day in Month in given month and year
' we've to check if the nth "repetition" of our Weekday is in Range of month!
decr repetition
hb = repetition * 7
hb=hb+foow
if hb <= ldom then
' it's ok! we're inside the month Range
repetition_of_day = hb
else
' we're outside the day-Range of Month
repetition_of_day = 0
end if
end function
Weekdays:
Data "Monday" , "Tuesday" , "Wednesday" , "Thursday" , "Friday" , "Saturday" , "Sunday"
Posted: Tue Jul 23, 2019 2:38 pm Post subject: |
six1 wrote: | Feel free to adapt to your needs. |
Well, the first required adaption would be to make your code producing correct results. LOL |
KenHorse
Posted: Tue Jul 23, 2019 4:52 pm Post subject: |
six1 wrote: | Hi KenHorse,
Code: |
Config Clock = Soft
dim gd as byte
$sim
'main
' Get Day from 3rd repetition from July 2019
wday = 1 ' 0-6 0=Monday
month = 7
year = 19
if gd > 0 then
print "Search: repetition #"+str(repetition)+" of "+Strweekday+" in "+str(month)+"-20"+str(year)+" is "+str(gd)+"-"+str(month)+"-20"+str(year)
else
print "Search: repetition #"+str(repetition)+" of "+Strweekday+" in "+str(month)+"-20"+str(year)+" is not in month Range"
end if
end
'end of main
dateArr(1) = 0 'sec
dateArr(2) = 0 'min
dateArr(4) = 1 'day
if month = 12 then
dateArr(5)=1
incr dateArr(6)
else
incr dateArr(5)
end if
ldom=dateArr(4)
if wday = fwom then
foow = wday
elseif wday > fwom then
foow = wday - fwom
else
foow = fwom - wday
foow = foow + 7
end if
decr repetition
hb = repetition * 7
hb=hb+foow
incr hb
if hb <= ldom then
else
end if
end function
Weekdays:
Thank you very much! This seems to do what I needed! |
six1
Posted: Tue Jul 23, 2019 4:59 pm Post subject: |
Hi Ken,
i haven't had much time today... please have a look at source once more. I corrected calculation of first occurence of day we search...
best, michael _________________ For technical reasons, the signature is on the back of this message. |
KenHorse
Posted: Tue Jul 23, 2019 5:10 pm Post subject: |
six1 wrote: | Hi Ken,
best, michael |
I must have tried it after the fix as I have not had an entered nth occurrence of a day yet fail to produce the correct result.
Again, thank you |
Posted: Tue Jul 23, 2019 5:27 pm Post subject: |
KenHorse wrote: | I must have tried it after the fix as I have not had an entered nth occurrence of a day yet fail to produce the correct result. |
There was no fix, the previous code puts out nonsense, as well as the current code does.
My previous message from 2:38 pm was for a reason, it reflected the tests I made with this code.
At least it's truly KenHorse-style code, shooting the horse from the back.
@Six1:
I'd suggest to post new code as new and don't edit old code in old messages, nobody can keep pace with such mess. |
six1
Posted: Tue Jul 23, 2019 6:23 pm Post subject: |
@KenHorse, plz try again. Corrected above Code _________________ For technical reasons, the signature is on the back of this message. |
KenHorse
Posted: Tue Jul 23, 2019 6:37 pm Post subject: |
MWS wrote: | KenHorse wrote: | I must have tried it after the fix as I have not had an entered nth occurrence of a day yet fail to produce the correct result. |
@Six1:
Really? |
six1
Posted: Tue Jul 23, 2019 6:54 pm Post subject: |
made a loop for month and result is:
Search: repetition #3 of Sunday in 1-2019 is 20-1-2019
Search: repetition #3 of Sunday in 2-2019 is 17-2-2019
Search: repetition #3 of Sunday in 3-2019 is 17-3-2019
Search: repetition #3 of Sunday in 4-2019 is 21-4-2019
Search: repetition #3 of Sunday in 5-2019 is 19-5-2019
Search: repetition #3 of Sunday in 6-2019 is 16-6-2019
Search: repetition #3 of Sunday in 7-2019 is 21-7-2019
Search: repetition #3 of Sunday in 8-2019 is 18-8-2019
Search: repetition #3 of Sunday in 9-2019 is 15-9-2019
Search: repetition #3 of Sunday in 10-2019 is 20-10-2019
Search: repetition #3 of Sunday in 11-2019 is 17-11-2019
Search: repetition #3 of Sunday in 12-2019 is 15-12-2019 _________________ For technical reasons, the signature is on the back of this message. |
Posted: Tue Jul 23, 2019 7:38 pm Post subject: |
six1 wrote: | Search: repetition #3 of Sunday in 12-2019 is 15-12-2019 |
No one of your shown code is able to produce that result.
Either you're making things up, or finally you've found your grain of corn.
If you've found it, show it.
Edit:
Quote: | Posted: Tue Jul 23, 2019 10:40 am Post subject: Reply with quote
3rd edit and you finally got it, applause. That was hard, wasn't it?
And as you're in the way of editing, here's one more:
Code: | print "Search: repetition #"+str(repetition)+" of "+Strweekday+" in "+str(month)+"-20"+str(year)+" is not in month Range" |
returns trash in the simulator's UART0 window.
If you try it the correct way, it works:
Code: | print "Search: repetition #"; repetition; " of "; Strweekday; " in ";month; "-20"; year;" is not in month Range" |
Also I would put:
Code: | Strweekday = Lookupstr(wday , Weekdays) |
somewhere else, as if the 'in range' branch is not followed, you display an empty value.
KenHorse
Posted: Tue Jul 23, 2019 8:11 pm Post subject: |
six1 wrote: | made a loop for month and result is:
Those are the results I obtain as well (although I did change the printout to reflect the US standard of M-D-Y
thanks again for your effort and assistance |
