2.8inch 65K FullColorLCD 240x320dot [ILI9341]
O-Family
PostPosted: Tue May 28, 2019 2:56 am    Post subject: 2.8inch 65K FullColorLCD 240x320dot [ILI9341] Reply with quote
The graphic instructions (LINE, BOX, LCDAT, etc) of BASCOM-AVR are limited to byte addressing (0-255) for LCD.
Because of that limitation, other users have created a function for the [ILI9341] (240x320 dot) LCD.
However, I and some users would like to use BASCOM's standard graphics instructions.
Thereat, for LCDs with more than 256 dots, we added offsets to the screen addressing to enable BASCOM standard graphics instructions.
Although there are restrictions on instruction execution, this is another approach to large screen LCDs.
how to use
To specify a position where the screen address exceeds 255, put (1) in the variable [Offset256].
An address can not be drawn across 255 and 256.
If the address specification of each instruction is 256 or more, the description of the address value is the same whether 256 or 0.
Circuit diagram
https://drive.google.com/file/d/1e-ByaqDKedDtw5EJp9cQcHmUnOcFMrbn/view?usp=sharing
PostPosted: Tue May 28, 2019 8:53 am    Post subject: Reply with quote
Hello O-Family
Thank you for sharing this smart solution.
Maybe it would be a good idea to add an option so the compiler can pass words instead of bytes. This would only work with custom libs like this.
If you think this is a good idea then please contact me.
O-Family
PostPosted: Tue May 28, 2019 3:05 pm    Post subject: Reply with quote
Hi, Mark
Graphic LCD functions created by other users have many functions and high performance, which is very nice.
However, the instructions (function names) and parameters differ depending on the author of the function and the LCD, so learning and understanding are required for each.
This loses the advantage of the standard command language, which is an advantage of the BASIC language, and is similar to how to handle C language.
Furthermore, I think that it will be necessary to have a detailed manual for each beginner.
It is probably the best option for the compiler to pass the graphic LCD instruction's word address and word color information to the library.
I think that will create a new library, so I want that option.
O-Family
matjazs
PostPosted: Sat Jun 22, 2019 6:44 pm    Post subject: Reply with quote
Hello O-Family.
I tryed to use this LCD display (IL9341) and probably I did't understand your instructions. After compile file I get an error message:
Error : 5 Line : -2871 No more space for BIT [OFFSET256] , in File : C:\_MS PROGRAMS\BAS-AVR\LIB\GLCD-ILI9341_2R8_240X320.LIB
Error : 320 Line : 185 [syntax error, token = '{'] , in File : C:\_MS PROGRAMS\BAS-AVR\LIB\GLCD-ILI9341_2R8_240X320.LIB
Please would you be so kind and explane again, maybe more detail, what I have to do, that LCD will running. Where I have to change "Offset 256"? For test I took your example file. Different are only aliases for ports. I tryed this on ATMEGA328P and also ATXMEGA128 (using Virtual port), but error message is the same.
Best regards M.
O-Family
PostPosted: Sun Jun 23, 2019 2:53 am    Post subject: Reply with quote
The error has weird things.
Error: 5 Line: -2871 No more space for BIT [OFFSET 256]
I do not think that the line number of the error will be minus [-2871].
Error: 320 Line: 185 [syntax error, token = '{']
Error code [320] does not have its number in the BASCOM manual.
This little information is difficult to solve.
Is the latest version of BASCOM?
matjazs
PostPosted: Sun Jun 23, 2019 2:21 pm    Post subject: Reply with quote
Hello.
I use version of Bascom 2.0.8.1.
I fixed a problem.
On ATMEGA328PU after a combination of pins start work. I forget to make
Dim Offset256 As Byte
On XMEGA128A3 I have still problem. (something with VPORT)
Thank you and
Best regards. M.
O-Family
PostPosted: Sun Jun 23, 2019 3:23 pm    Post subject: Reply with quote
You said the same error would occur in my sample code, so deleting [Dim Offset 256 As Byte] did not give the error you presented.
This library has been modified for the ST7735R, so it will be solved if you check the thread corresponding to the ST7735R XMEGA.
matjazs
PostPosted: Tue Jun 25, 2019 5:49 am    Post subject: Reply with quote
Error accure because [Dim Offset 256 As Byte] missed.
I try to use another LIB (ST7735R) on ATXMEGA128A3U but I'm not successful.
I don't know, how can modify LIB file.
O-Family
PostPosted: Tue Jun 25, 2019 11:46 pm    Post subject: Reply with quote
If you can not solve with the forum information, you need to present what kind of error you will get or the source file where the error will occur.
Otherwise you can not get help.
matjazs
PostPosted: Wed Jun 26, 2019 7:14 pm    Post subject: Reply with quote
Hello.
I can compile file without error, but nothing is shown on display.
In attach is modified your file on ATXMEGA128A3U.
Best regards. M.
O-Family
PostPosted: Sun Jul 07, 2019 3:02 am    Post subject: Reply with quote
If the virtual port connected to the LCD is the same port, it will operate normally.
The problem with multiple virtual ports is unknown.
I do not know I am not familiar with Xmega.
O-Family
PostPosted: Mon Jul 08, 2019 1:44 am    Post subject: Reply with quote
A bug was found in the original [glcd-ST7735R.lib].
It does not work if A0=[DC] and Sclk=[SCK] are assigned to another port.
* Sbi _glcd_port_scl, _glcd_a0 -> * Sbi _glcd_port_a0, _glcd_a0
* Cbi _glcd_port_scl, _glcd_a0 -> * Cbi _glcd_port_a0, _glcd_a0
This bug also occurs in the ST7735R library and the same symptoms occur on both regular AVR and Xmega.
Attach the corrected [glcd-ILI9341_2R8_240x320.lib].
matjazs
PostPosted: Mon Jul 08, 2019 5:51 pm    Post subject: Reply with quote
O-Family thank you, thank you very much.
It works now perfect also on ATXMEGA128A3U.
But I have one question more:
How can I transform my fonts (I use them on monocrome LCD) like color fonts. I tryed to do it with TT Font maker (EDC), but unsucsessful.
It works only with color8x8.fonts and color16x16.fonts.
Best regards M.
O-Family
PostPosted: Tue Jul 09, 2019 1:05 am    Post subject: Reply with quote
It was good to work well!
The font for monochrome and the font for color are different in data arrangement.
It is due to the structure of the internal memory of each LCD.
Furthermore, BASCOM's early color LCD library and the original ST7735R library created by "Mrshilov" do not support through type fonts.
It takes a great deal of effort to make this possible, so expect other users' efforts.
