absolute value of difference
Arera
PostPosted: Tue Jul 02, 2019 9:12 am    Post subject: absolute value of difference Reply with quote
Hi all,
working with unsigned vars, calculating the absolute value of the difference between to vars afforts a couple of steps.
Example using byte-constants:
89-5 = 84 'OK
5-89 = 171 'not the wanted result
So what I do is to take care to always substract the lower value from the higher one.
Pseudocode:
if a > b then
result = a - b
else
result = b - a
end if
My question:
Is there a more elegant way tho achieve the same?
(BASCOM-AVR version : 2.0.8.1 )
PostPosted: Tue Jul 02, 2019 10:43 am    Post subject: Reply with quote
I test
Dim J As Byte
Dim K As Byte
J = 89 - 5
Print J
K = 5 - 89
Print K
I have an Error : 49 Line : 17 Value doesn't fit into BYTE [-84] , in File : D:\pré poubelle\soustraction.bas
it is normal ! you can't do that with bascom
if you declare K as an integer you don't have error
Dim J As Byte
Dim K As Integer
J = 89 - 5
Print J
K = 5 - 89
Print K
see the foundamentals in help
About your speudocode , you find the elegant way
JP Wink
laborratte
PostPosted: Tue Jul 02, 2019 11:49 am    Post subject: Reply with quote
Don't know if it is more elegant, but it is faster to do it in assembler by checking the carry flag and - if necessary - negate the result:
dim a as byte
dim b as byte
dim c as byte
a = 18
b = 88
gosub SubtractLowerFromHigher
print c
a = 77
b = 27
print c
end
SubtractLowerFromHigher:
!LDS r16,{a}
!LDS r17,{b}
!SUB r16,r17
!BRCC SubtractLowerFromHigher_1
!NEG r16
SubtractLowerFromHigher_1:
!STS {c},r16
!RET
Arera
PostPosted: Tue Jul 02, 2019 1:28 pm    Post subject: Reply with quote
Thank you folks for your thougts!
Laborratte:
If often used, I find ASM in a sub to be quite elegant. Not for single use, but I'm sure I'll make use of it once in a while.
Marc
laborratte
PostPosted: Tue Jul 02, 2019 5:27 pm    Post subject: Reply with quote
Just for fun as function:
dim c as byte
CONFIG SUBMODE = NEW
function SubtractLowerFromHigher(byval a as byte, byval b as byte) as byte
'Load a
!LDD r26 , y + 2
!LDD r27 , y + 3
!ld r16,x
'Load b
!LDD r26 , y + 0
!LDD r27 , y + 1
!ld r17,x
'Substraction
!sub r16,r17
'Overflow?
'Yes: negate
!NEG R16
'Save to Result
!LDD r26 , y + 4
!LDD r27 , y + 5
!ST x,r16
end function
'Test it!
c = SubtractLowerFromHigher(18,88)
print c
c = SubtractLowerFromHigher(77,27)
print c
end
PostPosted: Tue Jul 02, 2019 7:45 pm    Post subject: Reply with quote
More simple:
C = A - B
If SREG.0 = 1 Then C = 256 - C
Micha
PostPosted: Mon Jul 15, 2019 8:41 pm    Post subject: Reply with quote
What about this:
   Dim a as Byte
   Dim b as Byte
   Dim c as Byte
   a = 5
   b = 3
      !LDS r24,{a}
      !LDS r25,{b}
      !SUB r24,r25      ' Subtraction
      !SBIC SREG,2   ' Test if negative
      !NEG r24            ' conversation to positive value
      !STS {c},r24
      print c
      Incr b
[/code]
laborratte
PostPosted: Tue Jul 16, 2019 5:08 pm    Post subject: Reply with quote
@ Micha:
Testing the negative flag of SREG ( !SBIC SREG,2 ) will not work with unsigned byte vars, as it represents the high-bit of the result (=sign of signed number). So it will be set if you calculate 240 - 1 = 239, because 239 represents -17 in 2's complement.
Using !sbic sreg,0 instead of !brcc does not make a difference in terms of speed on a mega device. On a Xmega it is even slower.
@ MWS:
For this specific situation your code will work, but it is - in general - not a good idea to use SREG in that way in basic code. The compiler adds several assembler commands between the actual subtraction and the if-then directive. You can't be sure that this commands doesn't affect SREG. Obviously this variant will not work:
C(I) = A - B
If SREG.0 = 1 Then C(I) = 256 - C(I)
as the compiler will generate code for calculating the memory address of C(I), which kills the carry status of the previous subtraction.
I know that you are aware of that, but other people with less knowledge about assembler will also read the forum thread.
Micha
PostPosted: Tue Jul 16, 2019 7:04 pm    Post subject: Reply with quote
OK, this code works:
   Dim a as Byte
   Dim b as Byte
   Dim c as Byte
   a = 230
   b = 3
      !LDS r24,{a}
      !LDS r25,{b}
      !SBIC SREG,0                                ' Carry-Flag
      !NEG r24
      !STS {c},r24
      print c
      Incr b
