Arera
Posted: Sun Jun 23, 2019 11:07 am Post subject: PCINT does not work on every input-pin |
I'm working on pin-change-interrupt to get SW-Uart to work. I'm encountering problems, so I stripped down the thing to the essenrtial.
As you can seen, I achive to trigger PCINT on pulsed outputs, that makes it easier to set up the test.
Every second I pulse out some OUTPUTS with delays, just to see things clearer.
What I expect ist to trigger an PCINT by pulsing an output, which triggers the corresponding PCINT.
It works fine if I pulse PINB.0.
My issue: It does not work if I use PortB.1. Not shown here, but the same issue on PortB.2. No other pin tested.
The pulsed outputs work, leds are connected. Only one of the remarked snippets is to unmark at a time, of course.
It seems not to be that complex, what's wrong here?
regards
Marc
$hwstack = 120
$swstack = 120
$framesize = 120
$baud = 9600
'$prog &HFF , &HE2 , &HD7 , &HFD
Dim Tick_1s As Bit
Led_pwr Alias Portb.0 'Power-Led green
Rel_ss Alias Portb.6
Led_ch4 Alias Portd.7
Config Pinb.0 = Output
Config Pinb.1 = Output
Config Pinb.2 = Output
Config Pinb.6 = Output
Config Pind.6 = Output
Config Pind.7 = Output
'**** Timer1 1s ****
Const Timer1reload = 7812
Config Timer1 = Timer , Prescale = 1024
Load Timer1 , Timer1reload
On Ovf1 Timer1_isr
Enable Timer1
Start Timer1
Declare Sub Uart_in_service
'#### this toggles Rel_ss in Uart_in_service ISR:
'Pcmsk0 = &B0000_0001
'On Pcint0 Uart_in_service
'Enable Pcint0
'#### This does not:
'Pcmsk0 = &B0000_0010
'On Pcint1 Uart_in_service
'Enable Pcint1
'**** Main Loop ****
If Tick_1s = 1 Then
Reset Tick_1s
Pulseout Portd , 7 , 250000
Waitms 250
Pulseout Portb , 0 , 250000
Waitms 250
Pulseout Portb , 1 , 250000
Pulseout Portb , 2 , 250000
Pulseout Portd , 6 , 250000
'**** Interrupt Routines ****
Timer1_isr:
Set Tick_1s
Uart_in_service:
Toggle Rel_ss
Return |
Posted: Sun Jun 23, 2019 11:50 am Post subject: Re: PCINT does not work on every input-pin |
Arera wrote: | It seems not to be that complex, what's wrong here?
Code: | '#### This does not:
'Enable Pcint1 |
If you understand how PCINT works, i.e. that any pin of one port, selected by PCMSK, triggers one PCINT-vector, then you understand what's wrong with your code. |
Arera
Posted: Sun Jun 23, 2019 12:22 pm Post subject: |
MWS, I got it.
PCMSK0 relates to Pinb.[0...7].
ATMEGA328PU has 23 PINT-pins, masked by PCMSK0, PCMSK1, PCMSK2.
Got that fron the datasheet bevore. What mislead me, is the fact, that bascom alowes to type PCINT23. PCINT24 is rejected.
Thus I thougt bascom would to the right settings, if i use i.e. PCINT18.
So what is
meant for? |
Posted: Sun Jun 23, 2019 1:57 pm Post subject: |
Arera wrote: |
So what is
meant for? |
This symbol abuse means nothing.
Only because you can type frzgblrmfogl , it does not mean anybody understands it.
The symbols PCINT18, PCINT19, a.s.o. exist because they describe the PC-interrupt pins according the data sheet, thus it is valid to write:
for enabling PCINT18-pin (PD2) to trigger vector PCINT2. |
Arera
Posted: Sun Jun 23, 2019 2:15 pm Post subject: |
OK. Got it.
In difference to "sjgfjhasgfuzawgu" (will not be compiled), "ON PCINT18 my_ISR" will compile. That lead my to assume that this is a valid Interrupt. That lead me to use PCINT1, expecting to Interrupt on PCINT1 (pinb.1).
"on gfgfjdjdhdhz my_ISR" will not compile too, enforcing my erroneous assumption.
Thank you, MWS!
Marc |
Posted: Sun Jun 23, 2019 3:30 pm Post subject: |
You need to read the datasheet, as you are responsible for correctness of your code.
If you address the point of 'it did not complain, thus it was supposed to work': there are tons of occasions in micro-controller programming, in Bascom and other programming languages to write something that looks ok, but won't work.
Even it would be possible to ask why you was not warned about using an improper interrupt vector, you need to ask how many man-hours or -years of work have to go into catching up simple user errors and report them.
This can be a hole without bottom, so catching up errors needs to stop somewhere and that's where user's responsibility starts. |
Posted: Mon Jul 01, 2019 10:05 am Post subject: |
Quote: | "ON PCINT18 my_ISR" |
yes it will compile since ON is not only used for interrupts but also for data sets.
ON value ...
And since PCINT18 is a numeric constant it will be seen as valid. _________________ Mark |
